Question about Frigidaire Washing Machines
I have a Frigidaire ftf2140es front load washer. There was a power outage, the washer was not on. After power was restored, the Door Lock light is continuously blinking, cannot run the machine anymore. Any suggestions on troubleshooting this issue?
5 Suggested Answers
SOURCE: FRIGIDAIRE FRONT LOAD WASHER
I too had the same problem, I closed the soap tray and a magnet popped out and got stuck to the door. Same problem with it acting like it was going to start and then beeped. This is where the magnet goes, just stick it back in, its held in with pressure (barely) :)
I took the whole control panel off to locate the magnetic reed switch, then just reverse engineered where the magnet is supposed to go on the soap drawer.
Posted on Sep 26, 2008
SOURCE: Maytag front loader washer--door won't open but lock light off
Open the soap dispenser. Look down in front of the fabric softener dish.
You should see a yellowy-green plastic cord (like weed-whacker line). Pull it.
The door should open.
If you don't see the cord, remove the four screws that hold the dispenser lid in place to find it. Just don't lose it when you put the cover back on.
Posted on Apr 16, 2009
SOURCE: Frigidaire front load, ERR LOC, washer won't run
Just had same problem. After removing boot/rubber gasket around opening, and replacing door lock assembly it still would not work giving the same ERR LOC message! Another site directed me to press the "Options" and "Select" buttons at the same time. BINGO! My husband was quite proud of me!
Posted on Aug 05, 2009
heatman101
  • 43501 Answers
SOURCE: My Frigidaire model FTF2140ES
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Aug 13, 2011
My frigidaire front load ftf2140es washing machine washes through compete cycle but clothes still come out soaking wet
Onthe front panel there is a clean out pump cover I am willing to bet ther is $.53 in the pump and or 1 or 2 tooth picks blocking the pump!
Nov 06, 2016 | Frigidaire FTF2140ES Stacking Front Load...
Door lock light won't come on
Good Afternoon Friend,
I understand that the "Door Lock" light is not coming on, on your Frigidaire Affinity washer, model# ATF7000E. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer light status has changed successfully. Hope this is helpful.
-Best regards-
WP
May 31, 2014 | Frigidaire Affinity ATF7000E Front Load...
Lights come on, door is closed, light load, but door will not lock so machine can begin filling with water. LFT7000ESO MODEL.
I understand that that you are having trouble with your Frigidaire washer, model# LFT7000ES0, and the door will not lock and begin filling with water. The model number you have provided, comes up as an invalid number. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. If you do need more assistance, I will please ask for the model number of your washer. Typically you should be able to find this located inside your appliance around the edges where the door meets your washer. Hope this is helpful.
-Best Regards-
May 26, 2014 | Frigidaire ATF6000ES Front Load Washer
WASHER WON'T LOCK DOOR
I understand that that you are having trouble with the door locking on your Frigidaire Affinity dryer, model# ATF7000E. I also see that the lights come on the dial but the door will not lock when you press the button for it to lock. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. When power is restored, run any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 26, 2014 | Frigidaire Affinity ATF7000E Front Load...
FTF2140ES won't spin
How old is the machine ?
if about 3years old check carbon brushers
Dec 14, 2013 | Frigidaire FTF2140ES Stacking Front Load...
Mdl#FTF2140ES washer will not start, door lock light will not light up. Machine will not run diagnostic for codes. Used multimeter on door lock assem. it is fine.
Make sure the controls are not locked. There is a button that you will have to hold to unlock...it will have a padlock icon by it probably.
Kelly
Mar 22, 2011 | Frigidaire FTF2140FS Front Load Washer /...
I have a Affinity frigidaire front load washer and need to replace part number 131763202. The model number of the washer is ATF6000FS1 Thank you in advance
Disconnect power then open the door and remove the spring-hoop assembly that secures the door gasket. Peel off the part of the door gasket near the door lock and switch assembly. Remove the screws securing the door lock and switch assembly to the front panel then pull the door lock and switch assembly out. Transfer the wires to the new door lock and switch assembly then install into place. Put the door gasket back and secure it with the spring-hoop assembly. Click on the link below for the detailed procedure.
Replacing the Door Lock and Switch Assembly on Frigidaire Affinity and Gallery Front-Load Washing Machine
Nov 12, 2010 | Frigidaire ATF6000ES Front Load Washer
Dl error message on front loader
This is the info from the error code for your washer DL/F
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the
door 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken.
• Check Door Lock/Switch Assembly for foreign objects
• Check Wire Harness connections to the Door Lock/Switch Assembly and Central
Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Note: The Door Lock/Switch Assembly can be manually unlocked. See Section
Seven, TECH TIPS
Mar 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
