Question about Garden
Hi, What is the part number for the bar blade for the Viking MB435M mower. I am in Australia. Thanks
    Problem Solver:
  • 14 Answers
Www.outdoorking.com/index.php?main_page=index&cPath=1_17_452_453_454
021204-4025 is the part number.
Follow the link to a website that sells them.
Good Luck.
Posted on Mar 23, 2011
  • 1 more comment
  • pcrowe421 Mar 23, 2011
    Thanks but mine is the mb435m mulching mower with the full width bar blade. Can you point me towards that one.
  • chad788 Mar 23, 2011
    Is the Viking the same as a Masport mower? If so I have found a couple of different blades available.
    Not sure. The masport blades that I found look similar, but Viking is made by Stihl.
Where can I buy replacement blade for 580 Huskylock overlocker in Brisbane?
Look on Ebay!
Cheers,
Embroidery Services
San Diego, CA
Jun 08, 2016 | Sewing Machines
I want to remove the blade bar of a Morrison Vantage Motor Mower to replace of the swivel blades. The bolt holding the bar to the direct drive shaft comes out Ok but the bar won't budge....
Most blade bars have to be driven of by hitting it with a hammer. They are spun on and off. Sometimes they go counterclockwise.
Oct 16, 2013 | Garden
I need a replacement viking blender blade (648204)
I found something on amazon, click here and take a look, it might be helpful: Amazon com viking blender blade. Cheers
Dec 02, 2012 | Viking Blenders
Husqvarna CTH180XP rideon lawn mower 42" rear
Hi Sue and welcome to FixYa, I am Kelly. You have been quite lucky to get 7 years out of your battery. Given the age of the battery that is currently installed this is most likely your problem. You have voltage but very little amperage due to thinned out battery plates.... (
Let me know how it goes.
Thanks for choosing FixYa,
Kelly
Aug 09, 2011 | Husqvarna Garden
I changed oil, blade, spark plug,air filter on tecumseh lawn boy 10685 mower...now it will not start!!! gas tank was emptied, per instructions. before changes, it started right up on first pull before...
Hi
Make sure the blade and shaft can easily be moved by hand. First, remove the spark plug wire from the plug. Reach under the mower and see if the blade will turn or if something is stuck between the blade and the mower. Also remember that you have to hold the safety bar when you are starting the mower or the engine won't turn. It is possible that the cable from the safety bar to the engine brake has come loose. Follow the cable from the safety bar to the engine and make sure it is working.Also check whether the line from the gas tank to the engine is crimped?
Also check this link to troubleshoot your problem:-
http://www.ehow.com/how_7363405_troubleshooting-push-mowers.html
Aug 04, 2011 | Tecumseh Lawn Boy Push Mowers Insight...
THIS A G1800. THE CENTER BLADE BOT CAME LOOSE FOR THE 3RD TIME. wHICH WAY DO I TURN THE BOLT TO REMOVE THE BLADE CLOCKWISE OR COUNTER? THANKS
counter clockwise, the best way to remove blades is with a impact/pneumatic drill, if you do not own either then block the blade/s with a 4x4 piece of would and use a breaker bar with a cheater bar( a piece of pipe slide over the breaker bar, give more leverage). Hope this helped Tim
Jun 04, 2011 | Garden
My flymo H33 mower has blunt blades. Are they worth repairing and where in Brisbane?
Hi Lesley, The blades on your mower are easily sharpened and if needed balanced and straightened so they are just like new if done properly. As far as Brisbane is concerned, it is located in Australia if I understand your question right. Hope this is helpful. All the best and good luck.
Feb 15, 2011 | Garden
Blade number for Ariens Zero Turn Model 1840. Need
Depending on which version of the 1840 you have and when it was built it could be several blades...
Please get your model and serial number and then enter them into the following site's search engine. You should then be able to identify the parts you need.
http://partsradar.arinet.com/scripts/EmpartISAPI.dll?MF&app=ariens&lang=EN&TF=Empartweb&loginID=ariensc&loginpwd=consumer
John
Jan 18, 2011 | Ariens Zoom 42 In 165 HP Briggs Stratton...
Need manual to see what size bolt is that holds on
Hi and welcome to FixYa. I am Kelly,
It appears your model number is 74370 There are 3 bolts one for each blade and the part number is 26-0671 or 260671 for the blade mount.
Part look up:
http://www.jackssmallengines.com
then enter part number 260671 $6.31 ea.
You can not use just any bolt for this. They are hardened bolts with an NF thread. If you use a non hardened bolt the blade will fly off when the bolt shears.
This bolt is available at most all Lawn Mower Parts Supply sources. Toro uses the same bolt on most all of their mowers.
If you do not have a Lawnmower Parts Supply near by, you might be able to go to an Autoparts supply source with yet one of the other blade bolts in hand and have them match the markings on the bolt head with yours so that you have the exact replacement bolt.
Any other parts for your mower can be found here:
http://www.jackssmallengines.com/help.cfm
Use the Search model window. each line below is a drop down window
Toro
Riding
74370 <- there are numerous models up to 74704
enter your model number if different.
Thanks for using FixYa.
Kelly
Apr 27, 2010 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
MTD bsgger/Mower 21 self propelled only number 1183AC.Need part that mower blade is attached to then to drive shaft. Can't find
The part your looking for is called the BLADE ADAPTER. The part number should be: 753-0588
These are available at most any lawnmower repair / parts store. If you walk in woith what is left of your old one they can sell you an exact replacement. I am kind of old school when it comes to blade adapters. I always match old with the new before I buy them. I have been burned too many times from on line sites mainly with blade adapters. Most anything else available on the net is fine.
Here is a whole page of adapters:
http://www.lawnmowerpros.com/MTD/MTD-Blade-adapters.asp
Kelly
Apr 02, 2010 | Garden
Garden Logo
80 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
