Question about Flotec 3.4 Hp Floodmate Submersible Sump Pump
Submerseable sump pump works well...but, keep going after it goes throughtthe cycle. It seems to be dispurseing water at the lower rear area.
  • 43,501 Answers
The pump will usually run a little stream of water out at the rear, no worry about that...
The reason it will not shut off is because the float is stuck or the float is bad...
Tap on the float and make sure it can go all the way down...
If it still does not shut off then the float needs to be replaced..
heatman101
Posted on Mar 23, 2011
Do I have to lengthen or shorten the length of the float cord on my sump pump if I want it to kick on sooner? Thanks
Shorten. By shortening the cord, the float will trip the switch at a lower maximum depth of water. The pump will run more often as a result, but the maximum water depth will be lower.
Mar 07, 2011 | Flotec 3.4 Hp Floodmate Submersible Sump...
We have a submersible sump pump and a check valve in the line and everytime it goes off we get this thumping noise. Could it be a bad check valve?
A check valve is simply a one way flap, or a ball that rolls forward to let water flow in one direction. My guess is if it's making noise, either the pump is not producing an even pressure or the line is not properly secured and is hitting inside a wall. Make sure the line has straps every 3 foot and at any bends.
Feb 19, 2011 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
The pump keeps running
I had the same problem. After replacing the diaphram and switch I noticed a little pin hole that allows water into the diaphram area was phlugged. I cleaned it with a piece of wire and now works like a champ. Kept notes and spare parts taped to the pipe for further use.
Jan 29, 2011 | Little Giant 6 Cia, 1/3 Hp, 45 Gpm, 230V...
Same issue, one of two pumps
I'm assuming the switch in Question is a Float-switch that is positioned in-line of the Power-supply to the Pump. The hinge that activates the switch inside the Float could be faulty. You can check it by connecting a dif-
ferent device to the plug, activate the switch
(Float upright) and deactivate (Float horizontal)
Mounting the switch with zip ties is a good
idea.The Float should be dangeling about 3"
above the Pumphead, thus keeping it submersed. Hope it helps.
Jul 14, 2009 | Genius Wayne Submersible Sump Pump With ...
Sump pump over heat?
No because the water temp will keep it cool and there is a safety factor built into the pump
Jul 05, 2009 | Ace Hardware 1/2 Horsepower Submersible...
I HAVE A 8 1/2 DIAMETER SUMP.MY OLD PUMP FAILED. CANNOT FIND A PUMP SMALL ENOUGH TO FIT.HELP!
get a submersible zoeller sump pump the flaot is attached to the pump not a teather and it wilol keep less water in the pit,, this is the best pump on the market
Jun 12, 2009 | Zoeller M211 Automatic Aqua-Mate...
Hammering sound at shutdown
it has a check valve to keep the water from going back into the pit when it shuts off, depending on how high the pipe goes up when it stops pumping the water closes the check valve in which the noise, unfortuintly there is no quick fix, even changing the check valve it could still make the sound
Apr 15, 2009 | Simer 3/4 Hp Stainless Steel Sump Pump
Water backs up in the floor drain during heavy downpour even thou
the sump pump shold not be run into the sanitary sewer, but if your floor drain is hooked to a sump pump pit and it doesn';t pump the water before it gets to the drain tile it could come up in the drain,, to solve the problem get a pump that the float is lower in the pit,, suggestion zoeller cast iron submersable pump cost about 100 less the install price, great low profile pump, it keeps less waterin the sump pump pit so there is less mosture
Mar 11, 2009 | Invacare Supply Group Invacare Top End...
New water ace sump pump will run but willnot shut off
The higher you pump the water, the stronger your pump needs to be, or the skinnier your hose needs to be. A lower discharge point and / or a smaller diameter hose might help immensely.
Mar 01, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Flotec 3.4 Hp Floodmate Submersible Sump Pump Logo
95 people viewed this question
Top Flotec Garden Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
jasbo
jasbo
Are you a Flotec Garden Expert? Answer questions, earn points and help others
