Question about Garden
I have a Hunter SRC Plus Sprinkler System and I need how too tunn it on and set times Thank you
    Problem Solver:
  • 14 Answers
Http://www.hunterindustries.com/Resources/PDFs/Owners_Manuals/Domestic/lit185w.pdf
Try the manual at the link above. If you can't get it let me know.
Posted on Mar 23, 2011
I need to turn off one sprinkler head of my Hunter Pro C unit.
you can turnoff the solomoid which opens and lets water thru. Sprinkler heads are not wired, they open with water pressure
Nov 18, 2017 | Hunter Garden
How do I get my Hunter ICC irrigation control box to turn on?
Check batteries with tester. Check internal fuse (sometimes same compartment as batteries. May have have to spend the $20.00
Jan 18, 2015 | Hunter ICM-400 ICC 4 Station Sprinkler...
Current year on my Hunter SRC Sprinkler is set at 02 14. Only the 14 will change.
MONTH AND DATE DUH will go t the MONTH which now is 02
Oct 05, 2017 | Garden
My hunter SRC lawn sprinkler controller sprinkles t
First thing to check is the power supply. Are the batteries fresh? Most likely you need to reprogram. There is likely a previous program that is causing the errant watering. Here is a good video on how to program.
Oct 22, 2011 | Nelson Sprinkler: Traveling Tractor
How to wire hunter rain clik rain sensor to r8816p101c
1) There are different rain clik model numbers shown in manual
Open 24 volt Rain clik manual:
http://www.hunterindustries.com/resources/pdfs/instructions/domestic/lit358w.pdf
http://waterheatertimer.org/pdf/Hunter-rain-clik-instruction-manual.pdf
2) The rain sensor has two wires.
And two additional wires are needed to run from rain sensor to sprinkler timer. For example, buy thermostat wire from local hardware store if wire is not supplied.
3) The rain sensor has a terminal block where wires are connected. .
Open manual above to identify markings on your terminal block.
For example Figure 1 shows SRC model, and with this model number, the rain sensor wires connect to terminals RS and C, and then two wires going to timer connect to terminals RS and and 1.
4) R8816P101C is 208-240Volt 24-hour irrigation timer.
Timer has two separate terminals for attaching rain sensor.
5) Timer power connections have 4 terminals. Do not connect rain sensor to power terminals.
Connect wires from sensor to the two sensor terminals.
6) Timer slide-switch must be set to ON position for rain sensor operation.
Sensor sends continuous 24Volts to irrigation timer.
When it rains, the rain sensor stops sending 24Volts to timer. Timer responds by not turning on power to irrigation pump.
To by-pass rain sensor, move timer slide-switch to off position.
7) Open following link for Intermatic replacement parts:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
8) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 05, 2011 | Intermatic R8816P101C -...
Hunter XG sprinkler timer not working
https://www.hunterindustries.com/sites/default/files/OM_XC_EM.pdf
https://www.hunterindustries.com/sites/default/files/LIT-397-RevG-OM-X-CORE-EN-web.pdf
REPLACE the alkaline battery can be used to program the controller in the absence of AC power. Even without a 9-volt battery the EC will keep track of time for up to 1 month and retain the program indefinitely in the event of a power outage.
Oct 06, 2017 | Hunter Ceiling Fan Control Switch
Orbit sprinkler system
Have you programmed the new one with all the info for date and time? Did you set the zones for the days you want and watering times?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 16, 2009 | Orbit Sprinkler System Power Source...
Hunter sprinklers vs rainbow sprinklers
I work with both Hunter and Rainbird irrigation components. Both companies have good products. But, I prefer Hunter for the sprinkler heads and Rainbird for the controllers and valves.
Oct 30, 2008 | Ace Hardware Hunter& Low Profile III...
Hunter PGP Sprinkler Problem
For a small price, it's worth it to replace it with another Hunter PGP. Don't settle for cheaper products as the PGP is the best in the industry, bar none.
Jul 09, 2008 | Ace Hardware Hunter& Low Profile III...
Garden Logo
259 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
