Question about Bosch Dishwashers
Water remains at bottom of washer after cycle
  • Bosch Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Posted on Mar 23, 2011
Whybdoes water remain in machine at end of wash?
If the drain pump malfunctions...or is clogged then it will not empty within the time cycle and the unit will time out. the pump in at the bottom of the machine
May 21, 2014 | Maytag Neptune Washer
Maytag washer # MAV5920Eww. Too much water remains after spin cycle. How to repair.
Can you create custom programs? On my top load washing machine I add additional spin cycles to the program.
Jun 06, 2012 | Maytag Dependable Clean Top MAV5920EWW Top...
Washer not cleaning contents
Either there is little or no water entering the dishwasher. As soon as it starts it's cycle, open the door to see if you can see water on the bottom. If not, then you probably have a defective fill/float switch.
May 11, 2012 | Dishwashers
Fowl odor in front loader
Clean out the small holes in the gray door gasket (at the bottom) to allow water to drain back into tub. Open access door at bottom left on front of machine, use small hose to drain remaining water from machine, remove and clean out filter there. Re-install. Run washer on the tub clean cycle if you have that cycle, or if not, use the longest, hottest cycle you can, but make sure to use a commercial washer cleaner like Affresh, Washer Magic, Whirlaway hot tub cleaner, etc., with no clothes in the washer. After cleaning tub, make sure you only use one tablespoon of HE detergent per cycle, and only one teaspoon of fabric softener per cycle if you use softener.
Feb 13, 2011 | LG WM-2277HW Front Load Washer
1. washer will not proceed to next cycle 2. water remains in washer, and can't open 3. not draining 3 won't drain even when manually advancing cycle
This is the drain cycle and it shows that the drain is not working at all. So make a test with the washer on in the drain cycle and test the voltage on the drain pump./valve, if voltage ispresetnthe drain valve/pump is faulty or cloggged. If there is no votage then the program controller is faulty. you might ahve to check if the controller can be rectified or replaced as a whole.
Sep 24, 2010 | Splendide 2000S Vented Washer/Dryer
Water remaining in the drum after cycle
Sounds like the filter needs to be cleaned
This is located at the bottom front right of washer behind drop down cover or flap.
Unscrew anti-clockwise to remove and clean.
Jan 15, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Water leaked from bottom of washer
Check the pump right where the motor shaft goes into it. The pump seal can leak right there and the water drips directly onto the floor. It will continue to run out after the cycle till the remaining water drains out of the tub and drain hose.
Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water remain in the machine
the washer has a fluid filled ring around the drum to balance it as it spins, assuming do not actually see or feel water you may be hearing that liquid.
Mar 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water won't drain, Soap Door open with soap still there and stops running at Plate Warmer cycle
Reset the washer manually. Close the machine, and slowly advance the timer till you here the fill valve start. Then let it do it's thing
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
53 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
