Question about Whirlpool Upright Freezer EV201NZR
The solenoid on the compressor just clicks on and off without the compressor starting.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
The compressor may be faulty or the relay may be faulty. A service call will cost about $100 to find out for sure. The relay costs $26.22, so I would recommend replacing the relay and see what happens.
Kelly
Posted on Mar 23, 2011
Solenoid diagram
that sounds like the hardstart relay that energizes the start windings in the compressor . if that or more likely the capacitor fails when it is first energized the compressor will pull excessive amps and cause the overload protector to open until it cools for a minute or two.
Jan 15, 2014 | Traulsen Freezers
TSSU4812 refregirator making clicking sound and not cooling
Without a compressor analizer you will need to check the winding
resistance. or you can just cross your fingers and hope the relay
and start capacitor are the problem. Sounds like the condenser coil was plugged so you could possibly have a locked up compresor.I doubt it is low on refrigerant charge.
Jan 15, 2013 | True TSSU-48-12-ADA Sandwich/Salad Unit,...
My bottom freezer amana refrigerator is making a clicking noise. And my freezer is barely cold.
Refrigerator making clicking noise compressor not running.
The clicking could be the start relay.If the start relay is bad, the compressor will not start and you will hear a clicking noise in 2-5 minute intervals. The clicking noise is the overload cutting the compressor off when it overheats from trying to start with a bad start relay. To find out if this is bad first unplug the refrigerator. Remove the lower cover from your refrigerator. Then take the cover off that is on the side of the compressor,you will see wires going to this. Now you should be able to see the start relay plugged on to the side of the compressor and unplug it. Now the best way to tell if it's bad is to shake it. If it rattles, it's bad and needs to be replaced. If not, most of the time it's ok. But rather than saying the compressors bad, you might want to replace it anyways because it does not cost much. A quick check on the compressor is to remove the start relay. You will see 3 pins connect a multi meter set for continuity. You should have continuity between any of the 3 pins. If you do not the compressor is bad. Also check from each pin to a good ground on the cabinet. There should be no continuity if there is the compressor is bad. If you replace it and it doesn't work then the compressor is bad and you'll need to call a repairman. (Note that compressors are very costly and are normally not worth fixing).You can enter your model # at Refrigerator clicking for diagrams and illustrations or to purchase a start relay. A 3 in 1 start relay will also work fine.
Jan 29, 2011 | Amana Freezers
Compressor start for a few second and cut off and start again. whats wrong . berverage-air freezzer single door model no. ef24-1as
dirty condencer coils bad fan motor or compressor start relay on the side of compressor or turned off then back on without waiting 5 min.
Dec 09, 2009 | Beverage-Air Freezers
I want to use one condener unit to cool a freezer and a cooler at two different temperatures, how do I do that? with a head master?
You need to split the delivery and return tubing, then install a solenoid in each delivery tube. The solenoid valve will be controlled or powered by a thermostat in each compartment. You then install a low pressure switch on the suction or return side near the compressor. This will switch the compressor off when both solenoid valves are closed. Hope this makes sense.
Nov 05, 2009 | Freezers
I cleaned and defrosted my stand up freezer and you can here it call to go on (clicking noise) but does not come on
Good day,
The clicking you hear is the compressor trying to start and cannot.
It could be caused by the start components mounted on the side of the compressor.
They can be removed and tested. There are 2 or 3 components.
The start relay, the start/run capacitor(some models only) and the overload protector(which makes that clicking sound you hear).
Take the parts to an appliance parts house. They are usually more than happy to test them for you.
If they test o.k. then your compressor failed. A very pricey repair done only by a pro. However.....
If your machine is under 5 years of age do nothing. Call your selling dealer. A new compressor would be free.
You would have to pay for start components but that would maintain the balance of the warranty on the compressor.
Nov 03, 2009 | Kenmore Freezers
I have recently unplugged my upright to clean it out. Upon plugging it back in, I have noticed it will not work! It makes a small buzzing sound like it is starting then ''clicks' off ???
The clicking sound you hear is the protective overload mounted to the compressor, shutting the power off to the compressor because it will not start. Two possibilities.
1. One or more of the starting components has failed. The starting components are A. The start relay, B. The start/run capacitor(some models have them, some don't), C. The overload which is the device you hear clicking. You can pull these parts off the compressor and take them to an appliance parts house. They are usually happy to test them.
2. The compressor has failed internally and needs replaced.
3. Parts houses sell what are called "hard start kits" but that is an iffy proposition. Most appliance techs carry them for testing purposes to see if they can get a balky compressor to start, but are sold to the consumer with the understanding that it may or may not give the machine additional life.
NOTE: If this appliance is under 5 years of age, don't do anything, but call the selling dealer, because the compressor is still under warranty. You'll pay if start components need replaced but you will maintain the balance of your warranty.
Oct 28, 2009 | Kenmore Freezers
Whirlpool upright freezer making buzzing noise and not working
I had a similar problem yesterday. I woke up and the freezer was not working anymore. It would make a buzzing noise and then it would click and shut off. I looked online for some possible solutions. Here is what I did:
I unplugged the fridge. I pulled it out and took off the cardboard backing. I used an air compressor to blow out all of the dust and dirt that had accumulated on the condenser coils. A shop-vac just wasn't powerful enough to pull out all of the dust/dirt. After that, I plugged it back in....and the same thing was happening. It would buzz, and then it would click off. I figured out that the "click" was coming from a starter relay (a small plastic piece attached to the big black compressor). I detached the plug from the relay and then detached the relay from the compressor. The relay was burned out. It turns out this is a common problem with the relay. I replaced the relay for $50 (from an appliance parts store) and put the whole thing back together in about 10 minutes.
I plugged the fridge back in and the compressor started, and now the freezer works better than other. I saved about $400 doing it myself, all in about one hour. And better yet, my wife was very impressed. Not bad for a doctor.
Jun 29, 2009 | Whirlpool 20 cu. ft. / 566 liter Upright...
True freezer compressor clicks but will not start
Depends on the HP rating of the compressor, also the voltage. Generally I find that even if a hard start works you are just buying a bit of time till the compressor has to be replaced anyway.
Nov 15, 2008 | Freezers
Whirlpool Upright Freezer EV201NZR Logo
70 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
AJMAL KHAN
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
