Question about Mattel Handy manny fix it right motorcycle + flicker the flashlight
My son has a Handy Manny Flicker the Flashlight by Mattel. It appears that the bulb is burned out and I cannot seem to find how to replace it. Please Help!!!
  • 3,018 Answers
The light bulb is soldiered in. However, if you unsolder the bulb you can order one off the internet and soldier it in. Pay close attention to which wire is soldiered to the bottom and which wire is soldiered more on the side of the light bulb. This is the only way to replace this light bulb.
Posted on Mar 23, 2011
Snap On Flashlight Bulb Replacement
The Lens is adjustable, you unscrew the top, then pull the Cap, Insert the Bulb (make sure the 2 wires are not twisted) and go straight into the holes. The Replacement Bulb is located down at the Battery Access.
Mar 01, 2014 | Snap Appliances Snap-On 3 D-Cell LED...
Problem with light
Repair the bulb holder and refit the bulb with cover.
Aug 29, 2017 | Maytag 30" Built-In Single Electric Wall...
My flashlight just stopped working. when placed on charger, the green charged light appears. How do I know if its a battery or bulb problem?
it's telling you the battery is fully charged so suspect that either the battery is dead or the bulb is burnt out. Get a test meter and test for voltage at the battery. If yes, then the bulb is burnt. If no voltage then obviously the battery is bad
Dec 28, 2013 | Inova T4 Flashlight
Colors are bleeding into each other
if 3d looking it is a convergence problem--I presume a Toshiba but what model? Convergence is common and if you are handy can be a do it yourself fix. More info from you will result in more help from me.
Oct 14, 2012 | Toshiba Televison & Video
Looking for a manual for the Cruncher prehistoric dinosaur toy by Mattell. My son lost his manual.
Welcome to Fixya.
Please find the user's guide by following the below link :
Cruncher Dinosaur Manual
Just click on the link "R2011" and you'll be all set.
Thanks for using Fixya.
Aug 20, 2011 | Toys
How do i replace the bulb
Julio, the black bezel will unscrew from the main housing. The bulb is either a screw-in or friction fit (pushes in) type. Most hardware stores will carry a replacement bulb that works for this flashlight. Be sure to take the burned out bulb with you to match it correctly.
Hope this helps.
Apr 25, 2011 | Makita 18V Lxt Lithium Ion Rechargeable...
My son just purchased a Bell & Howell 2575C 16mm projector which seems in good working order; however, we cannot figure out how to turn on the light (the bulb appears to be fine)...we've threaded film,...
Chances are that if everything else seems fine and is coming on then most likely you have a bad bulb or it could be loose,make sure its fitted into the bulb holder assy good and snug,dont force it or you will break it at the base.Go to google and google your model number for the bell and howell projector and find out whats available and pricing.A middle of the road or average bulb should be suffice for what your doing.
Feb 09, 2011 | Bell & Howell Cameras
After a period of time, vertical lines appear on the screen. Looks like jail bars. Sometimes turning the TV off, then back on will clear it. All channels. I replaced the projection bulb about 6 months...
no solution, same sounding problem though. last year we were getting lines through the screen and flickering and then the bulb burned out. had it replaced, 2 months later it did it again (they wouldn't stand behind the bulb so we had to buy a whole new one) this time had the bulb and ballast replaced because the repair guy said usually you have to replace both (why didn't they replace them both in the first place?) .. a year later and it's doing it again.. we get the flickering of the screen going on and off and horizontal lines that flicker across it. after turning the TV off and on a few times it seems to go away (or after it warms up)
i know know if i should order another bulb and ballast and spend the money for it to happen again or if it could be something else
let me know if you find a solution.. carolynspranger@gmail.com
Sep 07, 2010 | Samsung HLP5085W 50" Rear Projection...
My son dropped the flashlight acouple times and now it wont work
Either the bulb is burn or just faulty or the switch is bad.
Jul 16, 2010 | Surefire 6P BK 6P Original Personal...
Amama Fridge lighting problem
First tighten the bulbs securely. If not loose bulbs you have a loose wire connection.
Aug 14, 2009 | Refrigerators
Mattel Handy manny fix it right motorcycle + flicker the flashlight Logo
293 people viewed this question
Top Mattel Toys Experts
Nikki  Mclean
Nikki Mclean
ray gallant
Are you a Mattel Toy Expert? Answer questions, earn points and help others
