Question about Coleman Cable Coleman 1000 Watt Power Inverter - 2000 Watts Peak Power #PMP1000
Have a coleman 2000 watt 24v dc power inverter. When using it for a short period the temperature light and alarm sounds. The can just be a tv. The watt meter on the panel don't event light up. What the problem?
  • 604 Answers
If you are only tring to run a TV off this inverter, it appears you may have a defective unit. If you have had this inverter for only a short time, contact the dealer/store where you bought it and seek their advice. If you have had it for 90 days or more you can still contact the dealer, but maybe it would be best to contact the coleman company. You can go to their website nad find out how to contact the division that deals with this particular type of product.
Posted on Mar 23, 2011
COLEMAN INVERTER PMP1200 JUST BEEPS WHEN TURNED ON
It is most likely the low voltage alarm. Suggest connecting when the car is running with no load (110 volts not connected). If the alarm continues turn the unit off and on to reset.
Hope this helps?
Inverter Protection Features
• Short Circuit Protection. The inverter will automatically shut down until short is removed.
• Low Voltage Alarm. An alarm will sound when the voltage from the battery discharges to 10.5 +/- 0.5 volts DC. This is an indication that the battery needs to be recharged.
• Over Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input exceeds 16.5 +/- 1 volt DC.
• Under Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input is less than 10.0 +/- 0.5 volts DC.
• Overload Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the continuous draw of the equipment being operated exceeds 1200 watts or the surge draw of the equipment exceeds 2400 watts.
• Thermal Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the circuit temperature exceeds 150° F
Sep 13, 2016 | Electronics - Others
What is the 12 volt dc current draw in amps or watts of a RM2350 caravan fridge
recommended fuse is 20 amps according to the operating manual.
recommends car has to be running to have fridge running and having a relay to turn off power to fridge if ignition turned off as it will flatten a car battery in a very short time period.
power is 175 watts
Feb 05, 2016 | Watts Electronics - Others
Hi. I plugged a 600w oven grill and a kettle which is 110w into a 1000w Ring power 1024 inverter 24v-240. And now it dont seem to work. The inverter is wired straight to the battery.
Does it work if you plug in just your smallest appliance 110W?. How about just your 600W appliance What size wire are you using to supply power to the inverter? The inverter will draw about 30 amps from the battery with your load. You need to use wires as large as a number 8 from the battery to the inverter. The length should be as short as possible but could be 20 ft away. My inverter is a 2000 Watt continous and I use welding cable size 0 at about 3ft max between the battery and the inverter.
Jan 29, 2012 | Electronics - Others
How can I operate my LG 26LE5300 LED LCD TV in my motorhome the most direct way possible (i.e....without an inverter)? This low power (40-50 watts) TV has an external brick to convert 120 AC to it's...
1) You need to look at the output current rating (AMP) of this AC to 24dc adapter, this 24vdc adapter is a regulated switching power supply that will maintain 24vdc output up the maximum current rating and also has shutdown circuits if the over current draw is detect and also if the output voltage goes up beyond 24vdc to protect the load (TV).
2) To use 12vdc to 24vdc DC-DC booster, it should have the following spec:
A) The output current rating should be at least 20% higher than the load requires to give its head room.
B) It must have regulated output that will maintain the 24vdc when the input (12vdc) will vary from 10vdc ~16vdc or higher since your batteries will not maintain exact 12vdc all the time.
C) It must have good protection circuits that will protect it self from reverse polarity connections, shorted output protection, over voltage output protection.
D) It should provide AC ripple spec on the 24vdc output, it should be in the milli-volt range (you will always get AC ripple riding on top of DC when you rectify the AC into DC).
These are the minimum requirement for your DC to DC booster, which you need to protect your TV and your motor home from burning down.
I hope I explain it OK to you.
Please leave rating if it helps.
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jan 15, 2011 | LG 26LE5300 26 in. LCD HDTV
I check do not power DC24v input inverter how to fit it?
first you have to check 24v dc on power supply board.if power board 24v ok then there is one ic link on inverter board.check is this ic link ok or not if its open then replaaced it.check one end of ic link 24v dc come?
Oct 16, 2010 | Emerson LC320EM8 32 in. LCD TV
My inverter is in alarm and won't produce 110 power. Checked input voltage and it is correct.
I have had this happen a few times.
Sadly replacement is the Best option.
Repairs can be %75 the cost of a new one.
The best invert we have been using is a Pure Sine 1500 watt inverter.
Sad news but hope this tip helps.
R/
David
Jan 26, 2010 | Coleman Cable Coleman 1000 Watt Power...
My aims 2000 pure sine wave inverter is pluged to 2 240amp/h 6 volt batteries. When | plug in a 1800 watt hairdrier i get an alarm as if the batt. were to low. they are new and at full charge. is the load...
Your inverter has a peak of 3000 watts rating and should power that hair dryer. Make sure your batteries are in good shape. The inverter can only put out what it takes in. 1800 watt demand on the inverter requires 1800 watts from the batteries.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 14, 2009 | Inverter Aims Pure Sine Wave Power...
2000 watt cobra inverter keeps saing olp, overload
2000w means is out off rang load 2000w plus then alarm beep have running.
Mar 24, 2009 | Cobra CPI 1000 DC to AC Power Inverter
How many batteries do I need to run a coleman 1500 watt power inverter
It would depend on the load being driven by the inverter (which would determine the current drawn by the inverter), the capacity of the batteries and the shutdown voltage of the inverter.
Oct 01, 2008 | Statpower PW-1750 Triple Outlet 1750 Watt...
Coleman Cable Coleman 1000 Watt Power Inverter - 2000 Watts Peak Power #PMP1000 Logo
189 people viewed this question
Top Coleman Cable Electronics - Others Experts
Are you a Coleman Cable Electronics - Other Expert? Answer questions, earn points and help others
