Question about Kenmore 77632 Gas Dryer
Fuse is blown. does that mean a further problem?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
Check your venting and lint filter housing to assure no lint building up inside. This is the primary cause of fuse failure.
Kelly
Posted on Mar 23, 2011
  • jzolata Mar 23, 2011
    all was clear on the venting...just cant believe that is all it can be. can i get away that easy?
  • Smitty Mar 23, 2011
    Probably....the operating thermostat may be faulty and allowing overheat, but this would NOT be common. However, that thermostat is cheap, so you may want to replace it anyway.
Ford f250 brake light short
means that the melted wires are not damaged up to where you found them,but went further into the circuit wiring . cut the outside cover to further up til you find the ***** wire which surely are connected and that's why you are having blown fuses.
Oct 16, 2012 | Ford F-250 Cars & Trucks
My dvd wont turn on
is there any power indicator? if none,look for the power supply board replaced blown fuse. if the fuse is blown with darkened color that was mean their is a shorted component parts in the PSU or in the main board.usually rectifier diode and regulator ic.hope this can help just let me know if you need further solution.
Jun 25, 2012 | Televison & Video
No power fuse blown replaced fuse new fuse blown
It shows that there is shorting in the further circuit,check MOV (metal oxide varistor) used for protection in the mains supply,MOV is mounted parallel to the main input supply,if o.k check further bridge rectifier and finally switching device used for SMPS power supply either transistor or STR by replacing the same.
Feb 04, 2011 | Emerson TS1997 19" TV
Won't heat
Well first of all you can check out the power from the house - Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Then you can check the heating element -Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it, electric heating elements are not repairable. Further you can check the thermal fuse -
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse which is about an inch long is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it.
Good Luck!!
Thanks for using FixYa!!
Jul 06, 2010 | Kenmore 63942 Dryer
It wont turn on
You give us littel to go on here. Can you describe what happens (if anything) when you attempt to turn on the set? Is there a click? Is there a standby light on the set before you try turning it on? Is there sound or nothing at all?
While possible, dead sets are not usually caused by a blown fuse. If the fuse is blown, then the power supply will need work. If not blown, the power supply may still be the problem. Please update this with any other symptoms and we'll try to assist further.
Thanks,
Dan
Apr 08, 2010 | Panasonic Viera TH-50PZ85U Plasma TV
Power to back of oven going in and out of the oven but nothing happening not even the clock is coming on. please help.
Hi
Thanks for using FixYa. When microwave oven doesn't work at all, it means interior fuse inside the microwave has blown (usually a part inside the microwave makes this fuse blow). Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well. If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work. It can also be due to a stuck or faulty door switch which might have blown the interior microwave fuse.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 13, 2010 | Belling Microwave Ovens
No power to microwave
Hi
When your microwave oven doesn't work at all, it means interior fuse inside the microwave has blown (usually a part inside the microwave makes this fuse blow). Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well. If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work. It can also be due to a stuck or faulty door switch which might have blown the interior microwave fuse.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 14, 2009 | Microwave Ovens
Airbag lt on
Hi!
Code 51 means: Air Bag Diagnostic Monitor Internal Thermal Fuse ä Fuse Blown Due to Intermittent Short to Ground. It means that the computer controlling the airbags sensed a short in the wiring and disabled itself by tripping an internal fuse for safety reasons so that the air bag cannot be deployed accidentally. To repair the car, the wiring problem must be fixed, and then the airbag module replaced. Look for smashed wires, wires that are rubbing against bare metal or other wiring damage affecting the airbag circuits. This wiring is all under the plastic cowl around the steering column.
Please do rate the solution as FixYa and revert for further clarification.
Thanks
Rylee
May 30, 2009 | 2003 Ford Taurus
Power will not stay on
Activated protection circuitry means that the amplifier is seeing conditions it does not like and is shutting down the power to prevent further damage.
Either you have a short in your speaker wires, in your speakers, or a blown amplifier.
Disconnect both speakers and turn on the amplifier. Does it still give the error message? If it does, your amp is blown. If it does not, carefully inspect your speaker wires and their connection. Make sure all looks good and reconnect the speakers and try it again. Still get the error message? You likely have a problem in your speaker cabinet(s).
Apr 21, 2009 | Onkyo HTR500 Receiver
What are meaning of the symbols on the fuse box
what is not working you should be able to see the blown fuse if not take 1 out check it if not blown replace it and repeat till you find blown one. if this helps please rate. joe
Nov 21, 2008 | 1998 Land Rover Range Rover
Kenmore 77632 Gas Dryer Logo
71 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
