Dear Sir, My I.O Data portable hard disk series HDCS is not functioning, even i've tried changing the adaptor, the cable, still not dectectable to the PC.
dodgecharger
  • 254 Answers
SOURCE: Data recovery from External Usb Hard Disk
Fixya has received a growing number of USB connected Hard disk failures in recent months. It would appear they are a poor backup device, at least over the long term.
A couple of possibilities: First, disassemble the drive enclosure, and check the connections to the drive itself. I've seen one instance where an internal connection was just loose enough to cause a problem.
2. You could try removing the hard disk from the enclosure, and installing it as a second drive in a standard desktop PC. Interfaces must of course match- assuming it is an IDE interface, install it in a desktop with that drive connect system.
Master/slave jumpers must be also set correctly.
After this, using the drive management tool in Computer Management, try mounting the drive.
Beyond this, data recovery could be difficult at best. There are data recovery services available, but such is fairly pricey. You will have to decide just how valuable your missing data is.
Posted on Nov 27, 2007
SOURCE: system not detecting hard disk
how to recover data from corrupted external hard disk???????
Posted on Jul 31, 2008
SOURCE: Portable hard disk corrupted
try chkdsk /f <drive>
Posted on Aug 31, 2008
kamal1984
  • 1383 Answers
SOURCE: Transcend 160GB Portable Hard Disk is not recognized by computer
when you power up the computer press F2 or "del" key to enter in bios then go to usb option and enable usb 2.0 legacy. then save settings .
then check.
some times usb speed make issue so try this.
Also check your usb cable working fine try with other usb cable.
Also check harddisk jumper settings.
If still face problems then you need to repair it.
You shuold take it to service shop becasue you try with 10 computers and all gives same error then your harddisk has hardware issue.
try above solution .
Thanks for using fixya.
Please rate my solution if it helps you.
Posted on Jul 20, 2009
bschilz
  • 2049 Answers
SOURCE: Data Recovery from Seagate Desktop Expansion 500GB External Hard
This is a solution I have used in the past and it has worked. It's a Seagate Recover utility for end users.
https://services.seagate.com/diysoftware.aspx
If the data is absolutley critical and very valuable, you can send it to Seagate and they are very good at recovery as well. It gets a little pricey at $800, but I too have had to use that as well for mission critical data I could not afford to lose.
https://services.seagate.com/consumer_standard_services.aspx
Posted on Nov 06, 2009
External Hard Disk
1. External powering try changing the adaptor 2. Powered by USB try changing the USB cable 3. Try connecting to other computer 4. Check for any specific error displayed by Mac or ur PC 5. Try changing the disk name assigned to ur external HDD using disk management in PC 6. Hardware problem if under guarantee get it changed else go for data back up and solve if any bad sectors have come up in the HDD 7. You can check for software a that try to repair bad sectors in a HDD but it takes lot of patience for the same
Jan 01, 2014 | Western Digital Computers & Internet
How to recover deleted video from toshiba rd xv48dt hard disk?
try hard drive data recovery software, recommended Asoftech Data Recovery which helped me before. You may take a look at this hard drive data recovery guide that helped me before
How to recover deleted video from hard drive
good luck!
Dec 07, 2012 | Toshiba rd xv48dt
When i switch my pc on i have no display?
your graphicscard not working properly, broken.
monitor cable is fitted in the graphics port?
Mar 23, 2012 | Biostar P4M900-M7 Fe VIA P4M900 Socket 775...
Is there a hard drive cable adaptor available from an old sp1203n samsung to a barracuda 7200.9
Hello
this type hard disk needs ATA-66; 40 core cable for data transmission, and four core supply cable [+5V - 0V - 0V - 12V] supply cable. The data cable only has to be bought, because, supply pin will be with the power supply unit. You can buy this cable from most of the electronic spare part shops, or computer spare part shops at your town. The picture of the cable is given here.
gopakumarg43_26.jpgATA-66 [DATA CABLE]
Aug 28, 2011 | Samsung (SP1203N) 120 GB Hard Drive
What cable or adaptor do I need to transfer all data from the hard drive of my Toshiba Satellite Pro A200 via USB port? Thanks.
you do not need any special adapter or converter just use portable hard disk to take back up of data
seagate, transcend
Mar 14, 2011 | Toshiba Satellite Pro A200-EZ2204X...
Hi I cannot access my buffalo portable hard drive series HDPX320U2 can you help please?
If you have already attached your external hard drive to the computer and already installed the driver disc that comes with your portable hard drive (if one is provided, sometimes one is already installed in your harddrive) and you get nothing when looking in the "my computer" for your portable harddrive, it could be a issue with your portable harddrive, First check to see if proper connection are made and are fully connected. Check your portble hard drive if you turn it on and the power light is on. If you still get nothing then your harddrive disk is either bad or your harddrive enclosure is bad. If you know how to take your harddrive disk out, and connected to a computer usually via a sata cable and see if the computer detect it that way. If you done this and get nothing, then yup your harddisk is history. If you have extermly important files, such places as bestbuy, office depot, will do a recovery for you, which can cause up to couple of bills large for the amount of recover data they get you. More data, more money.
Jan 27, 2011 | Computers & Internet
Problem with Iomega Portable Hard Drive
Sounds like the drive is dead, even though it powers up the disk might not be spinning or the read heads could be stuck. Depending on the data you have on it and if you have it backed up or not, you could send it out for to have the data pulled off it but I warn you it is not cheap.
Dec 31, 2009 | Iomega Computers & Internet
Hard disk not dectecting
Is your Hard disk running at all ?
Can you hear some spinning noise and vibrations when it starts running?
Check the jumper settings (Master/Slave/Single).
If you have another device connected on the same cable (HDD/CD), check jumper settings on that device too.
You may first try to disconnect other device (if connected).
It is a very old PC, try replacing the data cable of your HDD, and pay attention of the correct connection of cable to the motherboard and HDD, too !
Check BIOS settings if both IDE channels are enabled.
Regards.
Mar 28, 2009 | Intel Motherboard
Portable Hard Disk not being recognised
If you cannot get the USB connection working, you can recover the data by taking the drive out of the case and connecting it directly to the PC as a second drive.  Make sure the jumper settings are correct for use as a second drive.  You can get the drive information and jumper settings from the web site of the drive manufacturer.
Oct 16, 2007 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
