Question about Lincoln Ovens
I turned the oven on and it blew the switch and the fuse, then I replaced them and it blew the fuse again. I have replaced the switch before with no problem.what should I do to fix this?
  • 416 Answers
Here's what you do.... and it's really this simple. Lets think about this simple. Check the fuse rating after removing all power from the unit and write it down. Next remember this fornula P=IV, thats Power=Current*Voltage. Now what we are looking for is something that would give us a large spike in power......so, we look for somewhere there is very high current or voltage.......but since we want to do this the safe way and without destroying the appliance in the process, we will remember another formula... V=IR, or Voltage=Current*Resistance. So now we can look for signs of extreme resistance as well. (when there is no resistance, that means there are no components between or connected to those two points an a way that would draw any power.....This is what is normally referred to as an arc.You can also have a number approaching infinity, so since your meter wont read that high, you'll see three EEEs. Now, connected the possitive and negative leads of the ohm meter (or multi meter set to read resistance) and take a reading.......then flip the switch and note the change.......you should have a reading much lower with the switch in the off possition.......if you resistance increases to the EEE mark, then you have a internal circuit problem and need to use the same concept to check the internal components. Remember your math rules, as they will decide whether you pass or fail this test........ but to make things easier, ill break down all the formulas for you
for P=I(current)V I=P/V V=P/I
V=IR I=V/R R=V/I Use these quick references to double check the readings and protect not only your appliaces and home, but your family.....you cannot continue to toy with high voltage appliance without recourse. take your time and be confident in your repairs....the only way is to be thorough and take notes and do your homework. A blown breaker means somewhere the resistance is sky rocketing. May just be an exposed wire or a board component burnt up......look for gray or black burn marks on or near components. Its may be in your best interest to simple locate and replace the main control board.....if you think will be your route pls let me know by responding to my post with your model number and ill shoot you a few good links for OEM repair parts
Posted on Mar 23, 2011
Element will not turn off
Call an electrician you can cause a house fire with this amount of amperage
Sep 18, 2016 | Ovens
Oven light blew and now no power to the oven.
If you are not knowledgable in electricity, call for service.
This is an electrical short at the light, I have seen this before.
The wiring for the light has grounded to the oven. This causes the main fuse to blow. You will need to fix the short first. Then reset the main fuse/replace.
In the case of the wall oven, you may have to remove the oven to fix it properly. Depending on the model and where the short is.
Nov 25, 2013 | Zanussi ZBF360 Electric Single Oven
Neff 1031 2
The heating element(s) may have shorted.
Apr 13, 2017 | Ovens
Are there fuses in the whirlpool flat top accubake stove that control the oven?
Yes there is a thermal fuse for the oven that if it blew all power to the oven would be cutoff,the fuse is not resettable and if it blew would need to be replaced
Aug 05, 2011 | Ovens
I have a Whirlpool double oven GMC305PRS01 when you turn on the oven it appears to me making all the right move IE it goes into pre heat and starts counting down but the elements are not getting hot.
Member Discussion on Whirlpool GMC305PRS01 Microwave Oven
Whirlpool Wall oven/microwave combo unit Door message
Does anyone know where the 15 amp fuse is? I replaced the 20amp fuse and it worked for a minute or two and then I opened the door and I blew my circuit breaker. I reset my circuit breaker, replaced the 20 amp fuse and now all I get is the Door message. I also noticed that it fused the outside switch on the right side of the door so I had to open the switch up and un-fuse it. This is for a whirlpool GMC305PRS01 Wall Oven/microwave combo unit.
Also if anyone could tell me the correct position the wire is supposed to be hooked up on the switches? I had someone help me take the switch out and they unhooked the wires and now we aren't sure how they are supposed to be hooked up. My light on the microwave doesn't work either. Is it possible the bulb blew when the fuse blew?
Nov 22, 2010 | Whirlpool GMC305PRS Stainless Steel...
Bake or broil does not work
if an element itself had shorted it would not stop the other from working and you could inspect each element and see blistering as evidence.the pop you heard has to be in common with both elements but not the cook top[burners]so thats going to be the wiring in the back of range, or switching,[thermostat,clock timer or oven selector switch,depends on which model you have]you will have to pull range and remove back pannels.you will find an obivous burn't connection.too repair all new connections must be clean and tight,or will burn again.
Jan 24, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Dacor model W305 blew an element. Replaced it. Won't work.
The fan and element rely on a supply from the thermostat, so perhaps when the element blew, it damaged the thermostat, another possibility is that there is a fuse of some sort in the oven that has blown as a result of the element blowing.
It is highly unlikely that the fan and element are faulty, you will have to look further.
Plz rate this solution.
Thanks, and merry xmas.
Dec 20, 2008 | Ovens
Oven blew a fuse
The POP sound normally indicates a short circuit fault (as opposed to overload) you need to have it looked at by a competent person.
Nov 17, 2008 | Ovens
Kenmore 790
when the wire to the element burnered it shorted to ground blowing out the switch. you should still be able to use the element but to get the light to operate normally youll have to replace the switch for that burner
Nov 20, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
216 people viewed this question
Top Lincoln Ovens Experts
Colin Stickland
Colin Stickland
jasbo
jasbo
Mike Teter
Are you a Lincoln Oven Expert? Answer questions, earn points and help others
