Question about Cameras
Kodak P712 camera on & off
When camera is first turned on it will stay on aprox. 5 sec., turn off for aprox 5 sec, it will repeat this cycle 3 or 4 times then operate normally. I use this camera professionally and i would prefer to fix it rather than replace it [ it is no longer made ]
  • bikemsgr Sep 01, 2008
    my problem is similar, what happens is that since the shutter button is in the middle of the on/off dial, when ever I rub it by mistake it turns off and it happens quite frequently, I dont know how to fix that, it wasnt like that always but is turning into a real headache at times.
  • Anonymous Sep 16, 2008
    My Kodak P712 has just started doing the same thing - cycling off & on several times - it's very frustrating!
5 Suggested Answers
  • 3 Answers
SOURCE: Kodak p712 shuts of and lens retracts
try resetting the timer to shut off the camera after a period of inactivity to a longer time. It seemed to work for me
Posted on May 12, 2009
proton77
  • 1183 Answers
SOURCE: Kodak P712 - when camera
Hi Bill,
The problem with the camera is that the BIOS, ie the onboard sofware needs to be updated. The same can be done at any Kodak authorised repair centre.
Thanks
Mandeep
Posted on Aug 03, 2008
geemarie
  • 876 Answers
Try this:
Turn off your camera.
Remove the batteries from your camera and have a close look at them.
The correct battery for your camera is Kodak rechargeable Li-lon battery 1700 MAh.
I do not have the same camera, however, I own 10 cameras and I believe this to be a POWER problem, so either you do have the wrong batteries or they are not fully charging for some reason. Batteries can look exactly the same but not be powerful enough to run your camera. You seem to be knowledgeable, but it never hurts to look at the basics. I am a photographer also and sometimes I just don't get the small things right.
Good luck
  • 11967 Answers
SOURCE: how to fix a camera that turns on then off in about 5 sec.?
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 04, 2010
Why does the kodak p712 camera shuts on and off will not let lens stay out?
Your P712 has the P-series powerswitch problem. Can be solved. Look here: http://www.dpreview.com/search/forums?query=p712+power+switch&forum=1011
Use WD40 or Deoxid to solve it, mostly for the longer duration. If necessary use again.
Aug 12, 2014 | Kodak EasyShare P712 Digital Camera
Won't turn on
Maybe Powerswitch problem. Go here and read the solution:
Otherwise suspect battery and/or contacts
Jan 17, 2014 | Kodak EasyShare P712 Digital Camera
Shutdown suddenly
. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
If this doesn't solve the problem please note that due to spare part shortage this model is no longer repaired. Instead KODAK offers a trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
In order to organise your repair or Trade up please Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 09, 2009 | Kodak EasyShare P712 Digital Camera
The Kodak P712 turns off and then on when I try to use it.
Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. Before you pay for expensive repairs that you may or may not need, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Jul 15, 2009 | Kodak EasyShare P712 Digital Camera
Camera turns on and off repeatedly. Battery is
I think the problem may be in the camera software. I reset the timer for auto shutoff from 5 mins to 10 min, This seems to have solved the problem, but it will take a longer time to be sure. I would suggest everyone with the problem try this and post the results. A easy fix if it works long term.
May 12, 2009 | Kodak EasyShare P712 Digital Camera
Apr 06, 2009 | Kodak EasyShare P712 Digital Camera
Kodak easyshare p712 has problem in the on/off switch. When I turn the camera on, it will come on, but then will shut itself off, then turn itself on, then off again, etc. If I find just the right place in...
push down hard on the power switch when you turn it on,mine is bad enough that it doesn't turn on,If i push the switch down hard when i turn it on,it always works fine. Hope that helps,P Waters
Mar 28, 2009 | Opteka (OP-HD2W-P850) for Kodak Easyshare...
Cameras Logo
70 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
