Question about Apple iPod touch
My ipod says its disabled and that it needs to connect to itunes...wat do i do? i have tried pressing the lock button and the menu button...it didnt work...UGH!!
  • 881 Answers
Maybe you're doing it wrong. Here's one way of putting your ipod touch to DFU mode:
  1. Plug/connect your device to a computer (PC or Mac)
  2. Turn it OFF
  3. Press and hold the POWER and HOME buttons together for EXACTLY 10seconds
  4. Release the POWER button but keep holding the HOME button until the computer beeps indicating that a USB device is recognized.
  5. Open iTunes and restore your device.
Warning: Restoring will delete all data on your device but this is the only way for you to recover it.
If you don't get it at first, try holding the buttons for lesser time.
For the other procedures and to see some screenshots, go read the complete instruction (link below):
http://www.fixya.com/support/r5541493-put_iphone_ipod_touch_dfu_mode_restore
For more iPhone / iPod touch tips like jailbreaking and unlocking, CLICK HERE.
Posted on Apr 05, 2011
Password forgotten now say's disabled
Unlock a Disabled iPod
If you own an iPod Classic or iPod Nano, you can set a four-digit security code on your device and then lock it to keep other people from accessing it.
Disabling your iPod is a good way to protect the data on your device, but if you lose or forget the four-digit code, you will need to manually unlock it in order to access your music and other content.
Plug the iPod USB cable into the bottom of your iPod.
Plug the other end of the iPod USB cable into a free USB port on your Mac or PC.
Open the iTunes application by using the dock icon on a Mac or the start menu on a PC.
Click on the name of your iPod under the "Devices" list in the main iTunes window.
Click on the "Sync" button to create a connection between the computer and the iPod.
Click on the eject symbol after the syncing process is complete, and then unplug your iPod from the computer.
The lock code has been reset; when you go to disable the iPod again, you will be prompted to choose a new four-digit code.
Or
Hard Reset a Disabled iPod Touch
A hard reset restores your iPod Touch to its original factory settings.
This is useful when your iPod Touch is disabled and won't turn on or off, but all your data is erased.
Luckily, you can restore your data with iTunes after you've performed the reset.
Once you've performed the reset, your iPod is wiped clean and iTunes prompts you to restore the settings from your last sync.
Plug the iPod into your computer and wait at least 10 minutes.
This allows the battery to recharge in case it has drained.
This could fix your disabled iPod, if the problem was caused by a dead battery.
Click "OK" if your computer opens a "Connect to iTunes" alert box.
Depending on your version of iTunes, the message may indicate the iPod is in "recovery mode" and you need to restore the device.
ITunes opens and resets your iPod for you.
Unplug the iPod from your computer if you don't see the "Connect to iTunes" alert box.
Make sure the iPod is charged before you attempt the hard reset.
Press and hold both the On/Off/Wake button and the Home button on your iPod.
Keep the buttons pressed.
Wait for the Apple logo to appear, it may take 10 seconds or longer.
When you see it, release the On/Off/Wake button but keep the Home button pressed.
Release the Home button when you see a picture of a USB cable with an arrow pointing to the iTunes logo.
Plug your iPod back into the computer.
The iTunes "recovery mode" message will appear.
Click "OK" to complete the reset.
http://support.apple.com/kb/HT1808iOS: Unable to update or restore
Jul 30, 2013 | Apple iPod touch
My ipod is disabled
Plug the iPod USB cable into the bottom of your iPod. Plug the other end of the iPod USB cable into a free USB port on your Mac or PC. Open the iTunes application by using the dock icon on a Mac or the start menu on a PC. Click on the name of your iPod under the "Devices" list in the main iTunes window. Click on the "Sync" button to create a connection between the computer and the iPod. Click on the eject symbol after the syncing process is complete, and then unplug your iPod from the computer. The lock code has been reset; when you go to disable the iPod again, you will be prompted to choose a new four-digit code. hope this helps
Attach a USB connector to the iPod and plug it into a USB connection on a computer for power, or into a stand alone USB charger plugged into a power strip for electrical power. Pick up the iPod. Move the "Hold" switch at the top of the iPod to the "Locked" position so that an orange color appears by the switch. Return the switch to the "Unlocked" position. Repeat this process. Press and hold the "Home" button and the button at the top right corner together if using a fifth generation iPod, iPod Nano, iPod Mini or iPod with a click wheel. Press and hold the "Menu" button and the "Play/Pause" button together if using an iPod Touch. Press and hold the "Menu" button and the "OK" button together if using an older iPod. Continue holding the buttons together until the screen flashes and then displays the iPod name and the Apple logo. Release the buttons. Wait as the iPod resets itself and turns itself back on. Leave the iPod connected to the USB connector so that it can fully charge the battery. Remove the iPod from the USB connector. Navigate to a song using the menu selection and play some music
Mar 01, 2013 | Apple Audio Players & Recorders
Ipod is disabled
or
hope this helps
Sep 15, 2012 | Computers & Internet
2nd generation 8gb .. ipod touch, is disabled/connect to i tunes (pin LOCK CODE)
1. Keep the power and home buttons pressed until the "Connect to iTunes" screen comes and restore (everything will be erased).
or
2. Ssh your iphonego to th path mobile/Library/Preferences/delete com.apple.springboard.plistoff and on your iPhone (MAY need to be jailbroken, not entirely sure).
Apr 01, 2012 | Apple iPod touch Second Gen (8 GB,...
Ipod disabled won't connect to itunes
  1. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPod touch to turn off.
  2. Press and hold the Home button while reconnecting the USB cable to iPod. When you reconnect the USB to iPod, the device should then power on.
  3. Continue holding the Home button while iPod starts up. While starting up, you will see the Apple logo.
  4. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
  5. Restore and it'll download ~240mb firmware and you're done
But you will lose all your data
Sep 20, 2009 | Apple iPod touch
Password solution for apple ipod
Connect the iPod to your computer and go to itunes. Then turn off the ipod. Hold the Home button and then press on the lock button until the apple logo appears. Keep holding the home button until a usb cable and a itunes icon show up. Then itunes will tell you to restore
Jun 18, 2009 | Apple iPod touch
8GB iPod Touch Disabled
you will have to restore your ipod to factory default settings in itunes.
or you can jailbreak the ipod with software like quickpwn.
Here is how to restore your ipod in itunes.
You will need to put the itouch in DFU/Recovery mode to get it to connect.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Plug the usb cable into the Ipod and NOT into the computer.
Hold the Home Button down for 5 second (do not release it)
Then Press and hold the Power Button for approx 10 secs (count them out)
Your iPod will reboot.
Release the power button and continue holding the Home button for an additional 27secs.
You may see the screen go blank or not.
Plug the USB end into the computer with itunes open.
Your ipod will mount in recovery mode.
Restore it and Your all set.
if you need any further help let me know.
Good Luck
Jun 01, 2009 | Apple iPod touch
Ugh
By "disabled" do you mean you have used the in-feature locking system on the ipod for protection?
For iTunes, Make sure you have the usb cables firmly attached to both the iPod and the computer. Go to:
1) Start bar on your computer
2) Look for "iTunes" in your programs
3) Click on "iTunes" to open it up.
If your iPod is connected to your computer, after about 20 seconds, iTunes should read your iPod and show it.
Also, if you have "disabled" it, it may just be as simple as resetting your iPod.
How to reset:
1) Move the "lock" on your ipod to locked position then quickly back to unlocked.
2) Hold then Menu and Center button down together till the Apple logo comes up. This should take only max 10 seconds.
3) It should return to the main menu on the iPod.
Hope I Helped, :-) Good luck. Don't worry, your father won't kill you, he might be disapointed, but definetly not that.
(I know from previous experience).
Feb 28, 2009 | Apple iPod MA446LL/A MP3 Player
IPOD DISABLE EVEN IN ITUNES NEED HELP!!!
put the ipod into restore mode, hold the power button down and the menu button for 20 seconds,then when you see the screen changed to the ipod usb,connect it to your itunes
Oct 23, 2008 | Apple iPod touch
Ipod is disabled
Hold sleep and home button for ten secs (or until you see recovery mode screen) then connect to itunes
May 18, 2008 | Apple iPod touch
Apple iPod touch Logo
44 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
