Question about Eclipse AVN5500 Car DVD Player
I installed my eclipse and the only problem im having is when i have the truck key turned forward it sounds good except you cant hear my subs that well and when i start it and turn it up once i get to a certain volume its usually between 55 and 60 it starts cracjling and popping and then at sixty it turns the audio completely off and i have to turn the truck off and back on.
  • 416 Answers
First off, you need to disconnect your battery immediately.. The reason for the feed back is you have a hot wire touching ground somewhere....probably a large sub speaker cable.....What will happen is the power going from the amp to the speaker or from the head unit to the sub will come into contact with bare metal and feed that current back into the system through the isolated ground. This will either reduce sound, or when the power is high enough, turn from a low hum to a heavy crackle. now if it crackles with the bass, more than likely its in your sub/amp configuration....if its constant or completely random then it could be anywhere in the system. check for bare, broken, or exposed wire.
GOOD LUCK AND PLS RATE THIS POST!!!!
Posted on Mar 23, 2011
I have 2 sony xplod 4ohm subs rated 350w rms and 1200w max, i have them in really shallow boxes because i drive a single cab toyota, i know these subs **** but i do also know that they can hit alot harder...
the premier amp is better since it has a better rms rating (360w total or 160w each sub) than the eclipse (280w if you bridge all 4 channels which isn't possible but 140w for each speaker bridging 2 channels per speaker). Neither are going to push your subs but if you get another amp wiring kit and use one amp per sub they will sound a lot better and you could just hook both power wire and ground wires from the bridged channels to the power and ground terminals for the sub. That would be my suggestion since the subs are rated at 350w and each amp is 280w and 320w which will push but not blow the subs.
Aug 17, 2010 | Sony Car Audio & Video
I have a milan mobility scooter,turn the key & it sounds a low
Hi. This sounds difficult. I have had a few scooters move slowly forward or in reverse, but not both. Normally if the speed pot ( wig wag ) is not exactly in the central position, they can do this.
It is possible for a scooter to have your problem, if the speed lever is binding or rubbing on the housing. Normally the lever is returned to the middle by a spring around the speed pot shaft. If this spring is loose or broken, then this could also cause the problem. Sometimes a small spot of oil or grease will help.
To check the speed lever is in the middle, slowly move the lever for forward untill you hear the brake solenoid release. Now release the lever and slowly pull it for reverse untill you hear the brake solenoid release. Make sure that the speed lever moves the same amount for forward as it does for reverse. If not adjust it with the key off.
If you get the machine to drive properly, then change the controller to see if it is OK.
As for the beeping, a lot of machines will go into an error mode if the speed lever is not in the central position when you turn the key on. This is a safety precausion.
Good luck. Neil.
May 12, 2010 | Electric Mobility 4 Wheel Heavy Duty...
When i turn the key in the ignition the engine clicks once and if i hold the key forward then i hear an electronic humm but the car wont start. what is wrong?
Either the battery is dead or you starter is bad.
Have someone give you a jump, does the car start now ?
If not please let me know.
Feb 08, 2010 | 2001 Mitsubishi Eclipse
Turns on but no sound
Hi just double check with multimeter for power if thats all good check your rca leads as they send the sound to amp and check that sub out put is on in cd head unit i know these a dumb things but sometimes its these that snag us hope it helps good luck
Oct 17, 2009 | Alpine Car Audio & Video
Im having trouble starting my 2001 Mitsubishi Eclipse Spyder
Josh, take the battery to Sears or a large auto parts store and have them test the condition.They do it for free. A battery will play the radio or run the lights with no trouble.It takes alot of amp power to turn the starter over. After you get it started check the volts across the battery.It should be just over 12 and less than 14 volts. If its not the alternator is not chargeing your battery,replace it.
I hope this helps you and your Mitsu.
Sep 24, 2009 | 2001 Mitsubishi Eclipse Spyder
Hello i just recently bought alpine speakers for my eclipse 2003
mostly because the subs in the back are probley using more amps than the ones in the front in the front should be used mostly for vocals and your bass in the trun so maybe trying to unhook the ones in the front from the sub and just leave then hooked up to the cd player where you can hear the vocals really good and leave your subs in the back hooked up to the amp
Jul 27, 2009 | Alpine SWS-1223D Car Speaker
2004 Eclipse won't start. When key is turned nothing happens. No electrical power to anything. No lights in dash , no ac, no power locks nothing except for blinking door ajar and ringing alarm. Even with...
sounds like you have an ignition problem, check the ignition fuse under the hood sounds like the fuse is blown, if that dosent work check your starter solinoid
I’m happy to assist further over the phone at https://www.6ya.com/expert/john_2c7bb9c157d0baa8
Jul 01, 2009 | 2004 Mitsubishi Eclipse
I have a 1990 jeep cherokee and there is no gas getting to it
first, have someone turn your key on as you listen to the gas tank. you should hear a whirring sound that indicates your fuelpump is working. if not, check your fuses.2nd, change your fuel filter. good luck. if you don't hear any sound from your fuel pump and still after checking fuses, fuel pump may need to be replaced. good luck
Nov 29, 2008 | 1990 Jeep Cherokee Limited
Subwoofer Output Not Working...
first check that the subwoofer function on the actual head unit is turned up,second check that the gain on the amp is at bout half way then check that it is on a lp (low pass setting)
then check that the boost on the amp is turned up.
please leave feedback.
cheers
Jul 02, 2008 | Eclipse CD5405
Amplifier installation
Since there's been no response in over a month, I guess I'll assume the problem was fixed!
Feb 19, 2008 | Kenwood KAC-X520 Car Audio Amplifier
Eclipse AVN5500 Car DVD Player Logo
60 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
