Question about Shaw Robert RS-9420 Thermostat
Display shows "cool ** " I have never noticed two
  • 604 Answers
The issue is most likely not with the thermostat, set the temp down to 65 degrees and listen for a click at the thermostat (it may not make any sound). go outside where the condensor fan is and look to see if the fan is spinning. if it is then the thermostat is probably ok. If you still are not getting anycool air and just warm air pumping out you may need to have someonne come and check the coolant level in your system. It may just need a recharge, but if you have lost coolant there may be a leak in your system. Alll that being said, you may need a licensed professional to come out and check your system
Posted on Mar 23, 2011
Package heat pump problem.
the gauge not changing and the pipes not sweating indicates the compressor is not pumping gas
I suggest that you call in an ac specialist to properly diagnose the problem and get a quote to repair
Aug 27, 2016 | Heating & Cooling
Unit stopped cooling, inside unit runs, outside unit does not
could be a gas leak ( low gas pressure shut off switch, failed start run capacitor for the compressor , vermin problem shorting out the power board outside
The inside unit is just a fan
call an accredited ac technician to get a proper diagnosis and quote
Aug 06, 2016 | Heating & Cooling
I have a Frigidaire FFU17F5HWD upright. I noticed
Reset the circuit breaker. It too maybe a GFI circuit.
Oct 11, 2013 | Frigidaire FFU17F5HW
Wont run. It blinks
YOUR UNIT WKL 4000 CONTROL BOARD HAS THE FOLLOWING FEATURE ON START UP UNIT WILL RUN FOR 30 MINUTES IF IT DOENST BRING THE TEMPERATURE IN THE CELLAR BELOW 70DEGREES IN THAT TIME IT WILL SHUT OFF AND DISPLAY E1, YOU NEED TO UNPLUG UNIT FOR 15 MINUTES(NO LESS THAN THAT) AND THEN PLUG IN AGAIN IT WILL RUN AGAIN FOR ANOTHER 30 MINUTES ABD IF IT DOESNT BRING THE TEMPERATURE BELOW 70 IT WILL SHUT OFF AGAIN.YOU WILL HAVE TO REPEAT THIS CYCLE TILL IT GOES BELOW 70DEGREES (MOST CUSTOMERS WILL HAVE TO DO THIS CYCLE TWICE).ONCE THE UNIT BRINGS THE TEMPERATURE BELOW 70 IT WILL RUN NON STOP TILL IT MEET THE SET COOL POINT.IF YOU REPEAT THIS STEP SEVERAL TIMES AND THE UNIT NEVER BRING THE TEMP BELOW 70 DEGREES THERE HAS TO BE SOMETHING ELSE GOING ON, LIKE A REFRIGERANT LEAK.CHECK THIS LINK FOR THE INSTRUCTIONS THAT EXPLAIN THE FEATURE I TALKED ABOUT AND OTHERS ON THE CONTROL LER OF YOUR UNIT(SENTRY III)http://www.breezaire.com/downloads/sentrymanual.PDF
Sep 15, 2012 | Breezaire WKL 4000 Wine Cooler
I recently purchased a schumacher 410w inverter, while it came on right away and powered my electrical device the cooling fan never came on. Is the fan supposed to run all the time, once its connected.
I recently purchased a Schumaker 410/820 watt inverter. I immediately hooked it up to a brand new deep cell batery I had purchased just prior to receiving this inverter.
I plugged in several devices to make sure the inverter worked and to get some idea of what devices I can expect this unit to handle.
I noticed that the fan only ran when I plugged in a device that drew a certain amount of power from the unit. I also plugged in a CPAP unit to make sure the inverter would operate the unit properly, and noticed that the CPAP only drew 38 to 40 watts of power and the cooling fan on the converter never came on. When I plugged in an oscillating fan it drew around 128 watts from the converter and the cooling fan immediately came on when I turned the fan on. Based on that, I would assume that the cooling fan in the converter only runs when there is enough power being drawn through the inverter to cause the inverter to heat up enough to cause possible damage to or failure of the inverter. I haven't taken the time to find out the power draw at which the cooling fan will run. Hope this helps.
Jul 10, 2011 | Schumacher 410 Watt Power Inverter...
Samsung rsg257 showing "of" on
I had this same problem. Per the manual, it's been changed to "store display mode". To cancel this mode, press the Power Freeze and Freezer buttons at the same time for 3 seconds until a "Ding-dong" sound is heard and the unit will cool. I tried it and it worked!
Dec 05, 2010 | Samsung Refrigerators
Help!! No cooling, just fan!!!
sounds like the unit is low on charge.you will need a pro to check it
Aug 04, 2008 | Heating & Cooling
Shaw Robert  RS-9420 Thermostat Logo
261 people viewed this question
Top Shaw Electrical Supplies Experts
obsteiner
Gil Shultz
Are you a Shaw Electrical Supply Expert? Answer questions, earn points and help others
