Red and green blinking lights when I open the electrical panel. Unit is not cooling. What do blinking lights mean? It is Ducane model #2SH13B24P-1A
SOURCE: kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Posted on Feb 20, 2008
Foxyjay
  • 13 Answers
SOURCE: blinking red power light
I think Denon designed in a "bug" as mine just "went east" today
Posted on Jul 22, 2008
SOURCE: ALL LIGHTS BLINK BUT UNIT IS DRAINED
Hi all,
I think the problem is that the A/C has tripped the electrical switch located in the plug. To correct press the black button followed by the clear button. Then try turning the unit on -it has worked for me so no reason it should not work for you.
Regards,
Tommie C.
Posted on Sep 02, 2008
SOURCE: My Toshiba 62HM15A DLP television
I just had the same problem last week I had reinstalled another lamp unit on my 62hm14 DLP, and it was doing the same thing both lights were blinking but the tv would not power up and come on.
It was simple once we figured out what was wrong the lamp unit door apparently has a safely mode switch and if the screw is not screwed into the tv to keep it from being opened it will not come on. It was just a safety feature.
We dropped our screw and god knows where it went but we found another, put it in and ta da tv came straight on.
Posted on Dec 02, 2008
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Posted on Jan 07, 2009
I turn it on and set it to 375. Why does it just keep blinking?
blinking green red light Electric Kettles Questions & Answers ...
www.fixya.com > Forum > Tags > blinking green red light
Electric Kettles blinking green red light questions and answers. Ask your blinking ...the kettle lights up but won't heat up, just bought it, the on switch shows red, but it isnot working...what to do? ... Chef's Choice 677 Cordless Electric Kettle.
red icon blinking Electric Kettles Questions & Answers - Fixya
www.fixya.com > Forum > Tags > red icon blinking
Electric Kettles red icon blinking questions and answers. Ask your red icon ... Light will not stop flashing Even after descaling and cleaning thoroughly the red lightflashes. Any ideas? ... "On" switch blinks, kettle won't heat Our 4-week old kettle juststopped working. When we ... Chef's Choice 677 Cordless Electric Kettle.
Dec 12, 2015 | Chef's Choice Kitchen Appliances - Others
Greetings Gurus. I have Makita charger model DC18RC, battery model is 18v BL1815...manual is of limited help. I'm trying to understand what the indicator lights mean, what the time is for charging,
I agree that the pictographs are not very helpful. You probably have one of the new chargers. I have an old one, which is a little easier to figure out.
From top to bottom
1. The flashing green light with the electric plug indicates that the unit is plugged in and ready to go.
2. The flashing red little fan means that the battery is too warm so it is just cooling it and not charging it at that moment.
3. The solid red empty battery outline means that it is charging but hasn't got very far, less than 80% full.
4. The mostly full battery outline with both solid red and green lights at the same time means it is 80% full or more
5. The full battery outline and solid green with the musical notes means it is full up.
6. The broken battery outline with flashing red and green means you've got a broken battery.
7. The yellow light with the wrench means the charger is "conditioning" the battery, whatever that means.
8. The yellow light with the fan means "cooling abnormality."
Hope this helps
Nov 01, 2014 | Drills
Ducane 2hp13l24p-1a My heat wont go off please
heat wont go off? what does that mean? turn the gas off and replace the valves if they're broken.
Oct 25, 2013 | Grilling
Goodman mini split model # wmh24-1a error code snowflake light stays on and 4th light from left blinks. i need to know what that means?
It's not an error. you have it set in auto mode and it is cooling. when it switches to heat the lights will switch as well. Set to cool only and it should go away.
Apr 28, 2011 | Soleus Mini Split Air Conditioner
The top light of the two is flashing green/red back and forth very fast and the light on the bottom is a solid red. how do I fix this so that way it will work normally
The steady lower light indicates the unit needs a new toner cartridge, MLT-D108S. Did you previously see this light blinking or blinking rapidly? (Those indicate the toner being low.) Replace the cartridge and check for any other error lights. Turn off the machine and let it cool. Then open the front cover and pull the old toner cartridge. Open the package with the new cartridge, remove the packing tape and paper that protects the cartridge and gently shake it (avoid touching the blue or green parts of the OPC drum). Press the cartridge into the slot until it is fully seated. Close the front cover.
The green/red blinking power light is not one I'm seen before. The printer indicates a non-toner failure (open cover, no paper, LSU failure, etc.) with a steady red light.
Aug 02, 2010 | Samsung ML-2240 Laser Printer
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Standby light blinks 6 times
i replaced the thermal fuse on my kdf-55wf655 and still have the 6 blinking lights,,any other ideas.
Nov 03, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Heating & Cooling Logo
114 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
