Question about Sony Playstation 3 (PS3) Console
When I turn my ps3 on I get no video on my tv and I just bought the wire so its not the wire... How can I fix this?
    Scholar:
  • 78 Answers
There are several things that can cause video to not show up on your TV.
First, check to see that you wire is plugged in correctly. Whether you are using A/V component or HDMI cables, the connections that enter the TV will be color coded. You must plug these wires in to the receiver with the same colors as the ones on the cables (ie. red plug's into the red hole, yellow plugs into the yellow hole). Take the plugs out of your TV and then plug them back in, ensuring you are plugging the same color cord into the same color hole.
Once that is done, determine what component channel your PS3 is connected to. Usually this can be done by finding the name of the channel printed on your TV next to the connection itself. It will usually be something like "Video 1" or "Component 2." Alternatively, you can simply turn your console on and scroll through channels or components (depending on how your TV is set up) until you find the video from your PS3 playing on one of them.
If this doesn't work then there is either something wrong with you TV or PS3. Make sure that the connection to the PS3 is snug and that the cord does not "jiggle" easily. If it does, move it around untill you find a position where the video appears on the TV correctly, then figure out a way to hold the cord in place in that position (placing an object under it, taping it, etc.).
If the connection is secure on your PS3, try doing the same thing with the connection going to your TV.
If that doesn't work then your television or your PS3 likely has internal damage, which requires an expert to fix as doing it yourself would be unsafe.
If you need any further support with this matter, feel free to leave a comment and I will get back to you as soon as I can.
Posted on Mar 23, 2011
    Novelist:
  • 102 Answers
Obviously, first make sure the PS3 and television/projector are actually on. Then confirm the television actually works, and that the port you're connecting to on the TV works (connect another console, for example).
You should then make sure all cords are firmly attached to the PS3 and you television.
If the cables are snugly in place and you still have the issue, you should make sure the PS3 is outputting the correct video. To do this, power off your system, then press the power button to turn it on, but keep it held down for a couple of seconds (around 5 seconds I believe). It should beep and your video settings will be reset.
Still nothing? Make sure the cables are working. Swap them out with cables you know that work, or test the cables in question on something else (another PS3 or old PS2 for the regular cable, anything that has HDMI out for the HDMI cable). I know you said it's not the wire but you should confirm it because the next solutions are kind of a last resort...
You might have to send it in to Sony, which can be done here. They take forever to send it back though, and if you're out of warranty it costs $150 (it's free if you're under warranty though!).
Alternatively, if you're awesome and feeling adventurous, you can fix it yourself. Here's a guide, and more can be found online.
Regardless, hope everything works out!
2 Suggested Answers
SOURCE: what can i do to fix my ps3,the sound and video input wont come on,ive tried 3 tv's and 2 different wires
hold the power button down until you hear two clicks and it should be good.
Posted on Jan 20, 2012
I have a 47 lg lcd tv bought in 09. When i use hdmi for xbox 360 i get picture and sound but with ps3 no pic no sound. I just bought a sony bluray and get pic but no sound. I bought a lg bluray and get no...
To clarify, your TV is working correctly, since you get sound and video from all devices - Only your PS3 has no sound or video?
If your PS3 was previously used with regular AV cables (Red/White/Yellow) then you most likely need to do a PS3 video reset t output video over HDMI.
With the PS3 OFF, press and continue holding the power button until it turns on, beeps twice, and then turns back off. Do not release the power button during this process.
You may have to try the video reset a few times if it doesn't work right away.
After video reset, you should get sound and video over HDMI.
Nov 08, 2017 | LG 47LF11 LCD TV
I bought my ps3 and when i hooked it up my tv just turned off and its all glitchy when i play
Dont worry i will tell you a easy and efficient idea to fix this. first download repair guide and go through it , it has many solutions for your ps3 console....
click here to download repair guide
Dec 22, 2010 | Sony Playstation 3 (PS3) Console
In a hotel with a tv that only has coaxial input. bought a rf modulator video converter from rca to coaxial. Was running hdmi at home. current set up does not work? console should automatically switch to...
Unfortunately it does not automatically switch. Turn off the power to your PS3 and then turn it back on again. But when you turn it on, hold down the power button until you see something on the screen. When you hold down the power button of the PS3 when you are turning it on, it completely resets the video settings to the most basic settings (480p I think) so that it'll work on any TV or monitor. You can then configure the video settings to match the TV you are hooking up to. You'll have to do the same thing when you take it back to your original location.
Dec 01, 2010 | Sony Playstation 3 (PS3) Console
Bought sony home cinema to with sony tv briliant
just use HDMI or SCART not both may fix ur Problem
Mar 17, 2010 | Sony Playstation 3 (PS3) Console
Theres a wave going across the tv screen whenever my ps3 three is on i tried different av cables a new power cord and nothing helped
has nothing to do with your tv or ps3 or xbox ive had this problem and fixed it...you are simply running to many things in the house or on that specific circut at once and the ps3 and tv are not getting enough juice.
Oct 28, 2009 | Sony Playstation 3 (PS3) Console
Ps3 as no video or sound i bought 3 wires for the tv and no color or soud sows we even used a ps2 cable
Excerpt from the PlayStation 3 Manual:
There is no picture on the TV screen.
*Check that the input mode of the TV is appropriate for the connector in use on the system.
*There may be a problem with the AV cable in use. Try using another cable that is compatible with the PS3 system.
*If the video output settings on the system do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system. Then, with only the system and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
*If the resolution of the video content is not supported by the TV in use, when the video is played the screen may go blank. If this happens, go to the screen for selecting the resolution in the system's video output settings, select "Custom" and then select all the resolutions that are supported by the TV.
Jul 29, 2009 | Sony Playstation 3 (PS3) Console
PS3 Video Connection--Lines on TV
this may be due to the fact that your ps3 will be set up to hd. go into video settings when you switch it on and this should solve the problem. i had similar problems and bought a hdtv until someone pointed this out to me. however once you have experienced ps3 in hd you will not go back!!! hope this helps
Jan 13, 2009 | Sony Playstation 3 (PS3) Console
No video output
well it might be the tv you are using because this happend to me but when i bought a plasma tv with built in hd it started to work perfectly.
Jul 28, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
97 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
