Question about Westinghouse Refrigerators
Hi, I've got a Westinghouse fridge- model WSE6100WA*7 which i've brought 2nd hand, 12mths old. I've had the fridge on all night on the coldest settings and still not very cold. Am i missing something simple or could there be a major problem?
  • 10,319 Answers
If its running quite as it should you need to clean the rear grille work on the back of the fridge
If a sound towards the bottom of it clicks on and off when running the compressor is low on freon
Posted on Mar 23, 2011
I have a very old Danby fridge and don't have a manual. The temp dial is from 1-7. Is 7 the coldest or is 1 the coldest? It's not keeping anything cold and it's on 7.
You could try
operatingguides.com
if you need a user manual
or
servicemanuals.co.uk
if you want the schematics etc
We've used them in the past and found them very good.
Also if it is not listed then ask via the link and they
will probably be able to get it for you.
Jul 14, 2011 | Danby (DAR604BLS) Refrigerator
Hi, I've recently found that my westinghouse
if the back wall of the freezer is iced up the problem is most likely the defrost thermostat.
May 06, 2011 | Westinghouse Refrigerators
My westinghouse sid-by-side fridge is freezing
the mother board located inside the lower rear portion of the unit is bad,if you have recently had lights blow out this can cause a surge and ruin the mother board,also if there are relays clicking and lights are blinking dimly this is a good sign the board is bad
Jan 16, 2010 | Refrigerators
What is the coldest setting on an old zanussi fridge freezer 1 or 6
hi there......the coldest setting on your fridge is 6
the normal accepted working temperature of a domestic fridge is usually between 0 and 8 degrees........the numerals on your thermostat are not temerature settings ...but a guide to coldness setting....the actual temerature must be checked with a reliable thermometer...usually best done in the morning after the fridge has ran throiugh the night without the door being opened.....
regards Sir Galahad
Aug 12, 2009 | Refrigerators
Freezer not working
Your refrigerator has a Control-defrost,adaptive timer ,PC board part number 241508001
This is providing your model is the one listed above your post WRS3R3EW. The model you listed in post does not come up. Until we can determine that the freezer is not defrosting you need to unplug and remove the back panel of freezer compartment to see if the evaporator coils are frozen or clear. If frozen this alone will cause a chain reaction that keeps vents to fresh food compartment open and cause freezing in that area. Go to link below and enter model number WRS3R3EW0 Then you will see a list of diagrams on left side, chose #11 this will show the control parts. Click link below Thanks, Sea Breeze
We offer free help and assistance also.
http://servicepartstec.blogspot.com/
Apr 27, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Westinghouse Wse6100WA side by side Fridge-icing up/not cooling
This is a bad design flaw, the fridhe is cooled by fan forced air from the freazer. Two ducts vent into and out of the fridge fron the freezer and ice can block them up (which you can find if you take off all the plastic at the top and back of the fridge).
Hence, when they block up, the frindge does not cool, hence the thermostat tells the fridge to keep running which makes the freezer colder and colder, making the blockage worse.
You need to not only fully defrost the freezer (which can be done quicker by removing the plastic panel in the back of the freezer and using a hairdryer) BUT also fully dry the fridge before turning it back on.
To stop it happening again, avoid puting unvovered liquids or hot items in the fridge. Also avoid leaving the fridge and freezer doors open for long especially in humid conditions. As I said, it's a bad design.
Mar 31, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Refrigerators Logo
74 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
