I have a 3-in-one remote cat. no. 15-2147 I just upgraded to a Sharp Liquid Crystal TV June 2008, LC-26DV24U Serial # 806838328 on Input it states 0 TV 01 DVD 02 DTV 03 VCR 04 HD 05 Input 5 Im only getting 2 Air Anlog channels 3 and 4 need code for remote to reset
  • 12,061 Answers
Hi, well unfortunately, this universal remote cannot be used on this modern TV, you see, it has to do with the digital numbering system used. Your uses, 0 as an input, 1 as an input, 2 as an input ans so on, now this is simply incompatible with the "other' format , which starts at One, 1.
Subsequently, the devices simply cannot understand each other completely, as far as the selections go anyway.
As TV 0, 1, 2, 3..... Remote Control, 1, 2, 3, 4..... so if it were used it would always "Miss" or be unble to select, channel "0", moreover, TV 1 = RC 2 & so on....
There is no way to alter it as it has to do with the code that operates the system BIOS.
So there is only one thing that can be done, and that is to obtain a remote that is 100% compatible. To this end, one simply must see it written down, or have it demonstrated that the controller works before buying it.
to my knowledge even resetting this device will still not restore functionality, due the above explanation, even if it were able to be done.
However i do believe some variants had a small hole and a reset button inside, but in any case will only clear existing setting not alter the overall function.
Oh BTW removal of the batteries will effectively "Reset" most devices too.
Posted on Mar 23, 2011
How to troubleshoot lcd tv
If you are using the ANTENNA input mode of the TV and should be receiving a local station on a properly chosen channel then something is wrong with the RF or IF section inside the TV. If you can connect an external video source to the TV see if that works while selecting the proper input mode.
Jul 01, 2014 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
The remote won't work
Is its a Sharp Remote? or a Generic
A) Check Batteries
B) If a sharp aquos remote there is a function button on the right top side - insure that TV is selected. TV led will light
C) On left side there is a red TV power button press and insure the red led on the remote lights.
D) IF Tv does not turn on then you may have a problem with
the sensor inside the tv.
Only real way of verifying it is not The Remote sensor is by trying another remote. If you have a Cable or Universal follow the instructions for a Sharp TV and try that. If it works problem is with the Sharp Remote if it doesnt its your remote sensor inside the tv.
Hope this helps.
Aug 02, 2013 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
TAKING OFF CLOSED CAPTION WITH OUT REMOTE SHARP LIQUID CRYSTAL TV # LC-32SB24U
not possible but note if using a cable box it can also be coming from that.
May 28, 2012 | Sharp LC-32SB23U 32 in. LCD TV
Is the Sharp LC-22DV17UT (combination liquid crystal tv and dvd/cd player) compatible with a MAC G5?
That TV/combo unit does have a VGA port, so it should be detected as a standard monitor from the G5 at 1366x768 resolution. I'd definitely try to upgrade the G5 to Leopard if it isn't detecting - Leopard has far better monitor support than Panther or Tiger did...
Oct 20, 2009 | Computers & Internet
I need the code for my "sony" universal remote control
SI esta utilizando un remoto marca phillip solo daja presionado code la luz se encendera luego pincha tv y con el botton de cambiar canal le das up varias veces hasta que el tv cambie de canal y luego le das enter y listo
Apr 13, 2009 | Sharp LC-26D6U 26 in. LCD Television
Luquid crystal television set - 125-240 AC
You have basically 2 options available to you:
1) Contact Sharp at the address you listed and they will instuct you on what you need.
2) Purchase a power conversion transformer. This will convert the 240AC to 110 AC and you can use the standard 110 AC cord.
Dan
Feb 13, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
