Question about Microwave Ovens
I am looking for the installation guide for our old FB11 garbage disposal showing the sequence of installation steps
  • 1,998 Answers
Hello and welcome to fixya,
could you please provide the make of the garbage disposal? it will help me to narrow down my search alot of units seem to be fb11 garbage disposal I await your reply Thanks
Rick
Posted on Mar 23, 2011
My dishwasher didn't drain the water out on the end of the clicle? What could be the problem?
Hello, Thank You for using FixYa. I will be helping you today.I would start where your drain line connects to the house drain,This is where most blocked drains happen. Disconnect the drain line and put it in a bucket and try to drain the dishwasher. Chances are its blocked somewhere you just have to find it.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 02, 2011 | Microwave Ovens
Garbage disposal is not working. There doesn't seem to be anything in it and resetting and unplugging/replugging hasn't worked. Do I have to take it apart?
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
Apr 25, 2011 | Microwave Ovens
Never have used a garbage disposal, now after 4 month and using it only about 30 times the water in the sink will not drain. When I turn on the garbage disposal the water in the sink swirls so I know it is...
hello fowl..... you have a blockage in the garbage disposal. you can use a chemical drain cleaner and pour it into the sink where the disposal is located. you should also look into that drain with a flashlight to make sure that there is not a fork or some other object causing the blockage. If you do not choose to use the chemical, you can also disconnect the disposal using the wrench that should be under the sink where the disposal is located. if you choose this method, have a pail handy to catch the water. also unplug the disposal before you work on it. Joe
Apr 24, 2011 | Microwave Ovens
I bought a used home and the garbage disposal does not turn on
REPLACED WILL BE SHEAPER THEN REPAIRING AN OLD ONE.
Feb 18, 2011 | Microwave Ovens
Is there a reset button on a emerson garbage disposal model e404?
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
heatman101
Jan 05, 2011 | Emerson Microwave Ovens
Ge model JES1142SJ06 just cut out. No power. Outlet works. it was working and then shut down
Open garbage can lid, and dispose of GE microwave unit. Then buy a replacement.
Jan 03, 2011 | GE Microwave Ovens
Garbage disposal is not clogged: I can freely turn it with my socket when placed on the center nut. However, when I flip the wall switch to turn it on I can hear the motor trying to "fire" up but...
Your motor is damaged and is not worth repairing on a garbage disposal. Recommend you get online and look for a good waste king disposal. They have the best warranties, incredible prices, lifetime corrosion warranty, have 1000 rpm's faster than the other brands so the food is liquified for the septic systems, and I have never seen one that was jammed in 36 yrs. of service! Good Luck, Appliance Specialists
Dec 03, 2010 | Microwave Ovens
All of a sudden, the water is coming back up on my garbage disposal instead of going down, it also swirl. I tried to see if the blades are moving and they are free, not stuck, also there is nothing that I...
The drain out of the disposal is plugged up...
Take the drain piping apart and clean it out and then you will be good again...
heatman101
Aug 29, 2010 | Microwave Ovens
Chronic garbage disposal oder
Cut a lemon in a 2-4 pieces and 1/2 cup or so of baking soda in the disposal to clean it. Use cold water to rinse.
Hope this helps.
Jul 28, 2010 | Microwave Ovens
Dishwasher doesn't drain
Check air gap located next to faucet line is likely plugged, especially if the machine is not used often, Try running 1/2 cup bleach through cylce about once every few months. Also if new garbage disposal was installed, make sure knock out was removed at d/w connect point.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Jun 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
41 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
