Question about Amana ALG443RAW Gas Dryer
I have a Amana gas dryer ALG443RAW. Dryer lights up but then shuts off after 3-5 seconds. I replaced the gas coils and also the flame sensor still the same thing. Should I try to replace thermostat or is their a thermal fuse somewhere?
  • 403 Answers
Clean the vents, replace thermostat
Posted on Mar 23, 2011
Gas Dryer Ignition Issues
did you try bypassing the cycling t-stat also?
Aug 25, 2012 | Samsung Dryers
Dryer flame keeps going out
replace the gas valve coils on the top of the gas valve,they get weak and can no longer hold the valve open,then they cool and repeat the same condition,they may appear warm after shutting off,remove 2 screws off bracket holding them on and unplug each coils harness and replace coils,there are plastic pins for getting them in the right position,so its hard to reverse them
Jul 23, 2012 | Amana NGD7200TW Gas Dryer
I turn on my drier and the coil heats up the gas comes on only sometimes then the gas shuts off shortly afterwards. Then i try to restart it the coil turns red with no gas.
The dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a video at this will walk you thru troubleshooting a gas dryer.
Sep 22, 2010 | Amana ALG443RAW Gas Dryer
Amana NDG2335AW Gas Dryer runs but doesn't heat
Check the spark ignitor when firtst starting the dryer up. It should click within the first 15 seconds to light the pilot up
May 31, 2010 | Amana NDG2335AW Gas Dryer
Amana Dryer LG8409W2 - The dryer heats for a few seconds then runs cold. The dryer has been cleaned as well as the vent and still no heat.
karenl46 -- Flame sensor has to "see" proper flame in order for gas burner to stay on. Safety solenoid engages (shuts off gas) when flame light not detected. Check window on sensor (1:30 CW position) on burner tube. If you still have problem after cleaning it, then refer to URL below. -- SWT
http://forum.doityourself.com/kitchen-laundry-home-gas-appliances/350993-another-gas-dryer-no-heat-failure-rates.html
Aug 18, 2008 | Amana Dryers
No heat-gas dryer--Amana
There is a flame sensor on the side of the flame housing. Jump the 2 wires out and see if the ignitor glows then. If so you need a flame sensor.
Jul 25, 2008 | Amana ALG331RAW Gas Dryer
CUTS OFF BEFORE IT FINISHS DRYing cloths
Check your venting, this could be causing the thermostats to pop and shut down the flame. The complete venting line.
Sgt 48
Jun 05, 2008 | Amana ALG443RAW Gas Dryer
Amana DLG330RAW gas dryer.
try cleaning or replacing the flame sensor ( optical unit mounted on the side of the burner tube. voltage flows though that optical eye that proves flame.
Mar 29, 2008 | Amana DLG330RAW Gas Dryer
Gas dryer
HI. the problem. is with the coils on the gas valve They will only open, the first time . then they over heat, and wont open. So replace the coils. thanks the appliance doc
Feb 11, 2008 | Amana ALG443RAW Gas Dryer
Amana ALE643RAW Gas Dryer
.hi with gas dryers the parts to look for are . the blower . will take longer to dry and noisy .The venting very important. The coils on the gas valve .Will cause the flame to only come on for a few minutes . then nothing so for that problem . replace the coils. Thanks the appliance doc
Dec 05, 2007 | Amana ALG443RAW Gas Dryer
Amana ALG443RAW Gas Dryer Logo
105 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
