Question about Refrigerators
Ice maker tray is getting too much water and freezing in a sheet over the cubes. When it dumps, we have crushed ice rather than ice cubes. Thanks for any help on adjusting water fill up.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
You don't specify, but I suspect this is a Whirlpool built refrigerator. If so, the module is likely faulty. Remove the plastic cover from the icemaker to expose the white gear. Look closely at it for any discoloration or burn marks. If you see anything, you will need to replace the module.
Kelly
Posted on Mar 23, 2011
Help! Our ice cubes are frozen but not dumping and our tray is filling up with water fitting a solid sheet of ice. Can anyone help? Thanks
Hello;
My name is Peter. I am a retired field refrigeration technician.
It sounds like your ice maker has a bad motor module/circuit board.
It is like a control board. This module reads a temperature sensor that indicates the water is frozen and ready for harvesting the ice cubes. Then it turns on a electric heater under the ice cube mold, then turns on the motor to harvest the ice cubes. After the ice cubes are harvested, it opens the water supply solenoid valve to fill the mold with water. The ice maker needs to be replaced.
Feb 27, 2016 | Liebherr Refrigerators
I have a Maytag frid m#PBF2255HEW (bottom freeze w/ice maker. My ice marker currently works but after dumping a tray of ice it "leaks" water into the tray causing all of the ice in tray to be one...
Sounds like the water inlet solenoid is getting stuck open, this is assuming you ice cubes are normal to large in size, Small would indicate the ice maker is leaking, You can try just replacing this valve , It's the valve that connects to the water hose behind your refrigerator and is fastened to the lower corner of refrigerator. Otherwise you can purchase the entire ice maker and solenoid kit for around 65.00 Hope this helps
May 18, 2011 | Refrigerators
Ice maker has ice motor doen't dump the ice
Your ice-maker may need to be "hard-reset". To do this, perform a manual-defrost by emptying out the freezer (and fridge) and shutting all power off to your unit for several hours (at least half a day unless you can be sure the temp in the freezer has fully reached ambient. Next, with freezer empty, restore power, make sure the "ice" setting is set to off, then set the forced power-freeze mode (you can refill the fridge, but leave the freezer empty for now. When the power-freeze completes (at least 2.5 hours) you can refill the freezer, set the "ice" mode to block/crushed (IE something other than off) and then hit the "black reset button" to restart the ice-maker. IF it still will not dump the cubes then the ice sensor/control board may have failed.
May 24, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
Ice maker no longer makes ice; water still comes for the filered water outlet but there appears to be no water going to the ice maker;
THE WATER VALVE IN THE BACK IS A TWO PART SYSTEM. EVEN THOUGH YOU GET WATER FROM THE DOOR THE ICE MAKER SIDE OF THE VALVE COULD BE BAD. CHANGE VALVE. B4 YOU SPEND THAT KINDA MONEY--DO A SELF CHECK FIRST--POUR WATER IN THE ICE CUBE TRAY. IF IT FREEZES AND DUMPS THEN CHANGE THEWATER VALVE. IF IT FREEZES BUT DONT DUMP CHANGE THE ICE MAKER.
Mar 16, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Whirlpool is not making ice cubes and the tray is dry, no water inside the ice maker but the water dispenser is working fine.
Most likely the water control valve on the rear of the refrigerator is defective on the ice maker side. Fill the ice maker with tap water and if it dumps the ice and does not refill then the water control valve is the reason. Usually an ice maker that still had cubes and will not dump the problem would be the ice maker. Hope that helped you, Thanks, Sea Breeze
Nov 22, 2009 | Refrigerators
Ice freezes into one solid block and won't dump out of the tray
remove cube tray from ice maker. clean with limeaway adn rinse. Spray with a light coating of PAM cooking spray. wipe dry and reinstall. be careful not to damage the sensor ( in center of tray)
Aug 26, 2009 | Samsung RS2578BB Side by Side Refrigerator
Cubed Ice selected, crushed ice comes out
ice maker works. water thru the door works. lock works. light works, alarm works.
when i try to get crushed, ice cubes or quick ice.
nothing happens
Aug 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice Maker frost and freeze where ice drops into refrigerator door
You need a service guy to look at it. It could be water leaking or a simple case that the flap isnt sealing and the ice melts and then freezes the flap open
May 14, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Ice Maker not working
Get me the model number. Put tap water in ice maker tray and make sure arm is down. Let it freeze. Wait and see if the ice will drop, this should allow water to come into the ice maker for another run. Let me know, Thanks, Sea Breeze
Apr 27, 2009 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
77 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
