I have a Sony EV-C25. The tape ejects after a few seconds upon insert. Unit powers up. No signal to Television evident. Any ideas?
  • Bob Buckley Mar 24, 2011
    Where can I find a mode fault switch? Are there good tutorials somewhere on the web? I'm bench trained from the military many years ago, so I can do some of the work. I don't have an Oscope or other test equipment.
  • 12,061 Answers
Hi, I have seen this fault a few times before in my shop, what usually happens is that a thing called the Mode Switch, faults and this then causes the symptoms that your unit is exhibiting.
It isn't a big repair job, and shouldn't cost too much. However often there are other problems when the MS faults, so one must get it checked out.
What you need to do, is contact a local or head office from Sony, ask them for a referral to an authorised, servicing center.
however, in any event, always ask first for a "Quote" before allowing any repair work to be done.
Posted on Mar 23, 2011
I have a used Sony SLV-920HF VCR that I am trying to set up. Every time I insert a tape it ejects it after a few seconds. Any idea why this happens?
There are two things that could be wrong. First damage to the carriage unit that holds the tape, which to me sounds most likely. The other a faulty or out of place mode switch, which could also could be caused by internal damage to any part of the mechanism.
Jan 16, 2013 | Televison & Video
Tape isn't retracted into cassette upon eject on Sony EV-C100
l would sacrifice a old or bad tape here, remove all the tape inside a cassette and tape off the small sensor holes on each side.
That way no tape to damage and you can insert it to see what is happening.
What likely is the issue is when stop it, it or if the tape does not fully load against the drum with heads, when the arms retract that pull the tape out of the cassette the mechanism is not switching to rewind it back into the cassette.
Usually this means a belt is slipping or the idler unit is not working---belts can break or stretch or even come off---belts will get slopply or bad from NO use and it is common.
Dec 09, 2012 | Sony Video Hi8 Ev-c100 Ntsc Video Cassette...
Tape loaded normally but now won't eject. The unit just powers off after a few seconds.
Unplug the power from the combo unit and give it 30 seconds, now plug back in, sometimes this will eject the tape, if not! take the top off the machine and check to see if the tape is spewed in the mechanical section and around the video head, if yes! get a pair of scissors and cut the tape carefully to avoid damaging the video head and remove all tape deb-ri, now power up and eject the main cassette. But! if you find the cassette has loaded in place and the tape is still in the vhs cassette, this would indicate a loading problem with the main carriage, broken belt, bad idler assembly and possibly sensor issues.
Feb 06, 2011 | Sony SLV-D350P DVD Player/VCR
Unit accepted cassette, won't eject
It is likely that either the drive belt has broken or is slipping. Because the unit is still in "play" mode, the mechanism won't let the door open up. If you have not opened up these units before, do not attempt it now. This unit should be taken to an experienced tech for repair. Where are you located?
Dan
Apr 08, 2010 | Sony EVC100 Hi8 VCR
Cassette stuck in Sony TC-K611S deck
Rotate loading gear with your finger until mechanism released and set on stop position. press eject button and take out tape.
Jul 01, 2009 | Audio Players & Recorders
Sony Cam DCR-PC100, "eats" tapes and when ejecting, pulls tape
The take up spool is not working upon ejecting. I would take it to a Sony Service Centre for service.
Jun 03, 2017 | Sony Handycam CCD-TRV43 Camcorder
Unit in-op
When you first power the unit on, it performs its power-on self-test for about 30 seconds. When the tape drive is ready, the top LED turns off.
If you attempt to insert a cartridge into the
tape drive during the power-on self-test, the tape drive will eject the cartridge.
So, as long as it works after a few minutes, the unit is fine.
Mar 16, 2009 | Exabyte Eliant 820 Tape Drive
Sony SLV-940HF automatically ejects tape.
1st try a different tape.
If it's the same, listen carefully for unusual noises, clunks, grinding, etc. when the tape goes in. Is something binding?
With the tape out, look inside the door, see if you can spot anything in there that shouldnt be there such as a small toy, money, playing card, sandwich, bits of food? Those are the usuals.
Turn the vcr upside down and holding the tape door open, tilt it so if there was a foreign object in there, it would fall out.
Oct 16, 2007 | Sony SLV-940HF VCR
Tape ejects just after insertion
the end-of-tape optical sensor is at fault. either it is very dirty, has failed or something else is detecting end of tape. many VCR's now will auto-eject the tape upon end of tape detect
Dec 19, 2006 | Mitsubishi HS-U760 S-VHS VCR
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
