No heat, fan works but blows out cold air - Heating & Cooling
  • 43,501 Answers
Here is a tip that will help you try to figure out why your furnace is notworking.
BasicFurnace or Heating System Troubleshooting
heatman101
Posted on Mar 23, 2011
I have a 2005Chrysler minivan front heat does not blow back heat blows cold cold air front doesn't blow at all what could this be
If the front heater does not blow any air suspect a defective fan motor or resistor. You can try turning the blower on and banging the underside of the passenger dash to see if it begins working again. If it does, suspect a bad fan motor. If blowing only cold air, the most common problem is a low coolant level
Jan 05, 2016 | Cars & Trucks
Why would my combo A/C - Heater unit not blow air while heating or cooling is selected but will blow air just fine when set to "fan only"?
Sounds like wiring issue to me. I've delt with units like this and there is a wire lead for fan only and a separate one to run the fan when the unit is cooling or heating. I'm only speculating here but I would bet money that this was improperly installed.
Dont get discouraged though because it sounds like its working (for the most part) if you feel up to the task find the manual and check your connections. Otherwise hire a professional.
Sep 20, 2014 | Heating & Cooling
Using heater...cold air out of the back
With heat pumps that's the way they work. In heat mode they are using the evaporator as the condenser and it blows heat out the front and cold out the back. In cooling mode, a reversing valve switches the gas flow reversing the operation of the coils and it blows cold out the front and heat out the back.
Nov 24, 2013 | Soleus 10,000 Btu Portable Ac Air...
My car over heating and blows cold air had new thermostat housing done but still dont work
Trapped air you have to bleed the air ,open cap when is cold and start car until water goes up to the top put back cap.try two times.
Apr 03, 2013 | Cars & Trucks
My heat isn't working..the fan blows cold air
Depending on the year make and model, it could be a blend door problem if the heater hoses are hot.
Oct 08, 2012 | Cars & Trucks
Heater doesnt work
To troubleshoot this types of problem,click the link below :---
Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
No heat on car? http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows intermittently and temp gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heater/AC blower motor not working?
http://technoanswers.blogspot.in/2012/02/heaterac-blower-motor-not-working-on.html
A/C, heater, defroster fan, not working? http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html Heater problem?
http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
This will help.Thanks.
Mar 27, 2012 | 1994 Volvo 960
My heater is not working except on one side in my 2007 impala driver side it blows warm passenger cold
To troubleshoot this types of problem,click the link below :----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the issue.
Heater blows intermittently and temp gauge goes erratic? http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html------------Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
---------Car heater blowing warm, but not hot air? http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html-------- Heater/AC blower motor not working?
A/C, heater, defroster fan, not working? http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html Heater problem? http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html---------
Feb 27, 2012 | 2007 Chevrolet Impala LS Sedan New Cars
Air works great but no heat just blows cold air
For this types of problem,i suggest you to check this help links:----Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
---------A/C, heater, defroster fan, not working?http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
--------Heater problem?http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
---------Engine Overheats and heater blowing cold?http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
-----------Heat blows cold on drivers side and hot on passenger side?http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html----------------This will help.Thanks.
Sep 05, 2011 | 2007 Suzuki SX4
Fan is blowing cold air only
good day, you may have some heating core issues, anti freeze leakage, have it checked. hope this helps, have a nice day
Feb 09, 2010 | 2007 Volkswagen Passat Sedan
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
