Question about AT&T 2.4 GHz 2255 Cordless Phone
AT&T 2255:Can not read phone display or program phone numbers due to unreadable or partial display read out.
Handset display says "Connecting" I can't deregister. How can I get the handset to display "not registered"?
The procedures to deregister are, of course, specific
to each make and model number of cordless phone.
All of them are a LOT more involved than simply
removing the battery.
For some AT&T, VTech, Uniden, & GE model numbers
you might try the following:
For many AT&T models it is simple:
1. When the handset says "Connecting..."
enter *331734 [menu]
it will soon (chirp) and display "Not registered"
For many VTech models it is a bit more involved:
1. Start by taking off the battery compartment cover.
2. press [menu]
3. scroll up/down to "Settings"
4. enter * 7 8 9 0 #
5. if display reads "Test Base",
scroll to "Test Handset", press [select]
scroll to "next page", press [select]
6. scroll to "Register Clear?", press [select]
7. display asks "Confirm?" or "Register Clear??",
press [select]
8. display reads "Ok" (chirps), press [ off ]
9. UNPLUG THE HANDSET BATTERY
(this is why the cover is off)
10. Wait ~30 seconds, re-connect the battery &
replace the cover
11. display reads "Not Registered"
For many Uniden models:
1. Press and hold the [END] and [ # ] keys at the
same time, after a few seconds the display reads
2. "System Reset, Deregister Handset"
3. scroll to "... Base Unavailable"
press [SELECT]
4. Handset (chirps)
press [END]
5. display reads "Not Registered, Place in base..." =====================================
For some GE models:
1. press "program[mute]"
2. scroll to "Handset Setup" press "program[mute]"
3. scroll to "Deregistration" press "program[mute]"
4. scroll to "Yes" press "program[mute]"
5. display reads "Not Registered"
Once you have the handset displaying "Not Registered"
you can follow the User's Manual instructions to register
the handset.
The model number for your cordless phone is shown on
a small sticker underneath the battery in the handset --
enter this number at www.manualslib.com to get a free
copy of the User's Manual if you need it.
Mar 14, 2016 | Lands Phones
Unread messages
Have you configured your E-mail program to "show only the UNREAD messages", i.e., to "hide" all the messages that you have read?
Mar 11, 2014 | Cell Phones
I have a Moultrie IR6 model DSG-160 that worked fine when I placed it this year. I go out to check it, and now the display only partially works. Not enough to read. Thru much back and forth to the...
www.moultriefeeders.com and ask for replacement LCD menu display...$14.99...they send instructions to replace...I get my parts from other defective cams.
Sep 06, 2011 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Reebok 8700es treadmill w/ Universal iPod dock & Ifit Fitness Journal. Display screen is unreadable. Light is on but unable to read the numbers on the screen Treadmill features: Custom workouts,...
If the display is unreadable, the Display resolution is faulty
Time to replace since thee are LCD, this fail.
Call to the supply treadmill manufacturer. or
Treadmill Treadmills Best Treadmill Treadmill Doctor
Blessing
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Nov 08, 2017 | Reebok 8700 ES Treadmill - Silver Service...
How do i reprogram my speeddial numbers on jazz 4400?
Hello.
From NorStar Support:
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94). that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
If the above doesn't work, try:
  1. Press [Feature] [*] [4]
  2. Enter a two-digit code from 71 to 94.
  3. Specify the external line by pressing a line button, a line pool button, or the intercom button. If you don't specify the external line, the system automatically chooses a line for the call.
  4. Dial the telephone number you want to program (up to 24 digits).
  5. Press [Hold].
  6. Record the code and number you have just programmed.
Hope this helps.
Feb 02, 2011 | NorStar Jazz Plus 4400 Corded Phone
NEED TO CHANGE TIME ON PHONE DUE TO DAYLIGHT SAVINGS PHONE IS T7316E
Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press softkey "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press softkey "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press softkey "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press softkey "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press softkey "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
Mar 16, 2010 | Lands Phones
File or directory corrupted and unreadable
The directory is like a "table of contents" in a printed textbook.
If a child's crayons have been used to overwrite those pages, making them unreadable, then the table of contents cannot be used to locate the starting page-number of a specific chapter. So, one must read through the whole textbook, page-by-page, looking & trying to recognize the start of a chapter, and then the end of the chapter.
Similarly, there exist "file-recovery" computer software programs that do such "linear" reading of the entire ZIP disk, and trying to reconstruct the "file-structure" that was recorded in the "disk-directory".
Search for "file scavenger" software, and give it a try.
Dec 08, 2009 | Computers & Internet
You need to go into lines/trunks and change the line typ from unsupervised to supervised so this will stop. How though?
Changing programming on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
3.- Press "NEXT"(bottom right arrow) - display should read "lines"
4.- Press "SHOW" (top right arrow)- display should ask for a line number
5.- enter in the line number you wish to change the supervision on in a 3 digit format. ex. line 1 = 001
6.- press the show key (top right arrow)
7.- The display should say Trunk/line data
8.- Press "show"(top right arrow) - display should read "trunk type"
9.- Press the next key (bottom right arrow) 7 times"
10.- the display should say "trunk mode: unspr"
11.- Press softkey "CHANGE" to "super"
repeat steps 5 - 11 for the remainder of the lines Press the Rls key when finished
Nov 03, 2009 | NorStar M7324 Telephone
Blackberry curve says I have one unread email, but there are NONE
You may have an unread message in one of the other folders, such as drafts.
Press the menu key and select folders and see if there are any unreads there.
Aug 26, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
AT&T 2.4 GHz 2255 Cordless Phone Logo
59 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
