I have an Acer H223HQ monitor. When I turn the computer on, the tower itself appears to be running fine, but my monitor switches on for a few secs, showing the acer logo & then goes black. The light on the power on button, turns from green to amber.
Bogdan
  • 198 Answers
SOURCE: Acer AL1916W 19" problem
Hello mat78, Unfortunatelly the problem is hardware based. You will need to have the monitor repaired in a service center. Here's why: LCD/TFT monitors don't produce light themselves. They are composed by a matrix of transistors (TFT - thin film transistor) that have the property to reflect or allow some light (certain wavelenghts)to pass through them. They don't produce light by themselves. Instead there is a fluorescent tube (neon like) light inside the monitor and that's the light source used in order for you to see what's on the screen. A flourescent light is suposed to last pretty much, i don't think yours has a problem, you say it works for some seconds or so. Instead your problem is most probable with the inverter circuitry that powers on that light. It's a common problem among these types of monitors but in your situation i don't think it will be an expensive repair. In the case that the screen is dark (in a dark place you can't read or view anything on it) but if you apply light to it ( a flashlight or something) and you see something, then the problem is most likely to have occured with the invertor. Try to ask at a local service center for a repair, this shouldn't be an expensive procedure. Hope this helps.
Posted on May 24, 2007
Fix-4U
  • 293 Answers
SOURCE: Monitor goes black and won't come back
Hi! Trish,
It's seems your Acer monitor backlight inverter are burnt out. Need to replaced a new inverter. Since is a company monitor asked your boss to get you a new one.;) Hehehe...
Posted on Oct 04, 2008
Fix-4U
  • 293 Answers
SOURCE: ACER AL 1714 SM MONITOR
Hi...there,
Well...your backlight inverter are busted.... need replaced a new one or repaired it.
Posted on Oct 12, 2008
  • 47 Answers
SOURCE: Monitor comes up shows "acer" then says no signal and goes black
The interface between the monitor and the cable might need replacement. Please check it.
Posted on Jan 12, 2009
SOURCE: at power up tv displays Acer logo then goes to black
will not turn off power with out unplugin it
Posted on Mar 01, 2009
Can you connect a set of speakers to the acer h223hq monitor
There is a sound cable that plugs into the blue sound hole on the back of the computer, and the other end plugs into the monitor.
Apr 22, 2010 | Computers & Internet
Monitor just turns itself off after 2 sec.
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
Apr 16, 2010 | HP w1907 LCD Monitor
Acer AL1711 LCD Monitor goes repeatedly black after bootup after just a few secs picture and has to be turned on & off at least 6 times thereafter with picture staying only 2 secs each time until...
cpburn, It's BROKEN!!! SHUT IT OFF AND LEAVE IT OFF!!! The "switch-mode-power-supply" has DETECTED a fault and then goes into full or partial SHUTDOWN to save itself from a catastrophic, nonrecoverable failure. eg. sparks, smoke, fire. The good news is you stated "picture staying only 2secs" !!! It can be fixed! Just how you do it is the question only you can answer. If you know how to replace components on a circuit board (unsolder&solder) you might do it for less than $12 in parts. To understand exactly what is involved I suggest a visit to www.ccl-la.com/badcaps.htm run by another guy on fixya with nickname "buddymc"! He's GOOD! If "do it yourself" is not your thing, then here are your options: Acer refurb swapout. ??? Contract to local TV/Monitor shop.?? Contract to a distant Repair shop.??? But before doing any of the above try YOUTUBE and search out and view some of the longer (6-12min) vid clips of "LCD monitor disassembly""Lcd monitor repair". If you require further assistance I can be accessed through [removed by staff] or on fixya. I'm 12fixlouie If this response was of some help please rate on fixya. Bye fo now.
Nov 09, 2009 | Acer Computers & Internet
Monitor will not stay on
HOw about the light on the tower? if its stedy green then the tower is ok then run a self test on monitor if it passes the monitor is also ok then unplug the power cable from the monitor and data cable also and press and hold the power button for 10 sec and then connect the monitor to the system
Jul 02, 2009 | Computers & Internet
ViewSonic VX910 monitor appears to have power supply issue. The power light comes on for less than 1/2 sec, then goes off for about 1 sec, then just flashes green. If you play with the switch and the A/C...
try running the self test on the monitor
Self Test:
turn off the system disconnect the data cable from the tower and connect only the power cable to the monitor and trun on the monitor if you see colour full bars then the monitor is ok then try to go BIOS and see if the monitor is working
Jul 01, 2009 | ViewSonic VX910 19" LCD Monitor
Jan 12, 2009 | Acer AL2016 W 20" TFT LCD Monitor
Monitor or pcu problem
It appears that your graphics card is defective. If the monitor works on your laptop and reinserting the graphics card did not help, I would suspect the card itself.
Aug 19, 2008 | Acer AL1716 17" LCD Monitor
Monitor control lock problem
Replace the small 78L05 regulator 5V supply to micro.
Jan 13, 2008 | Computers & Internet
Computers & Internet Logo
128 people viewed this question
David Payne
David Payne
