Question about Ovens
St George UEO-7 Inbuilt oven Has broken outer glass in door
  • 2 more comments
  • jimgail383 Mar 23, 2011
    I am located in Upper Hutt just north of Wellington New Zealand. I will look at both options of repairing it myself and also having it repaired if the cost is not prohibitive Jim.
    Thank you Rick,
    It appears that the glass is held agaist the stainless front by an adhesive as is the metal bracket that secures the front panel along the door bottom. This is where the problem started, the adhesive on the bracket let go. I tried to reglue with epiglass super strength 24 hr. it was fine untill the oven was heated then it also let go, then I broke the glass. What adhesive for stainless to glass which will cope with the high temperatures of the oven ??.
    Regars Jim
  • jimgail383 Mar 26, 2011
    Hi Rick
    Difficulty in sourcing the glass and the indicated possible cost makes the project not worth continuing with. So have ordered a new oven. Thank you for your help.
    Jim
    Costs of proceeding prevented a final conclusion of fixing the door. Thanks for the help Jim
  • 1,998 Answers
Ok how old is the unit there is a 2 year parts and labor warranty on that oven. I think that you must be in maybe austrailia if I am guessing correctly. Do you wish to repair the glass yourself? or do you wish to be put in contact with a repair company that will come to your location and fix the door for you? if you are looking for a company to repair here is your manual click here http://kleenmaid-appliances.com/use&care/FSR/SG_FSR/ueo7_ueo7r_ueo7s.pdf you would need to contact one of the distributors on page 80 of this link if you want to replace the glass yourself then you would still have to go through one of these distributors to obtain the glass but would save yourself the labor rate. I await your reply on my inquiries and look forward to discussing this matter as well as solving this issue with you. If you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks
Rick
Posted on Mar 23, 2011
  • 1 more comment
  • Rick Ead
    Rick Ead Mar 23, 2011
    hey jim,
    the cost for the glass would probably run you about 150 in dollars it is a easy repair just have to take your time and look at the screws that have to be removed in order to get at the glass and the frame to the glass accessible message me back if you have any further questions probably run about 225-250 if they come out to repair it for you this is in dollars although you could get a cheaper price as well cheaper is always better I await your reply Thanks Rick
  • Rick Ead
    Rick Ead Mar 24, 2011
    this is a bit odd dont usually see to many models that you have to glue the glass in usually when they send you the glass all the adhesive is already installed there are a couple types you can try Offering tensile shear strength of 2,100 psi, high temperature, heat-curing nitrile-phenolic adhesive
    called Aremco-Bond this is for copper to cermaic mainly so lets try this click this site http://www.intertronics.co.uk/products/d... this is used to bond glass to stainless and has a high heat resistance either dymax 620 or 625 these are both rated above 600 degrees i wouldnt use the master bond because that is only rated to 450 degrees and if you go to broil at 500 this could cause a issue really a good epoxy that is rated to tempreture should be fine if you want to get the exact type that they use click here http://ovendoorglue.co.uk/ if you need any further information message me back i would either go with the oven glue or one of the dymax types call them first at dymax if you choose to use there type although the oven door glue might be a bit easier I await your reply on any further questions That you may have Thanks Rick
  • Rick Ead
    I await your reply message me back with how you made out Thanks Rick
Broken outer glass
Please can you help to find a part number for outer door
glass or is any other outer door glass suitable for
AEG MCC3880EM I can fit in? Many thanks
glass , how much it would cost or is any other outer door glass suitable for
Dec 07, 2012 | AEG Ovens
Hi the temp on our st george oven, model ueo-8 has become unreilable?
if digital the replace the oven control / if dial then the dial is at fault . mm
Jul 12, 2010 | Ovens
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I have a wall oven, a St George single oven. The
Depending on model-
Put the door at an opening of about 100mm. You should feel an indent for thecorect position.
You will probably need 2 people, 1 each side,
Slide the door upward at an angle same as hinge, It will slide off the hinge.
If the hinge is broken, and they usually break inside the wall of the oven, it will be very difficult to slide it off the broken hinge.
Hinges are available from EDIS SPARES 1800 125 039
Sep 12, 2009 | Ovens
Replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 22, 2009 | KitchenAid KEBC101 Electric Single Oven
Broken inner glass on Model # NGSG3PZAQA
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
How do I replace the inner glass on the oven door? I have taken the door off and it is apart, but the glass assembly looks to be one piece. How do I remove just the inner glass for replacement? JenW30400W
moz-screenshot-7.jpgmoz-screenshot-8.jpgTo replace the door glass do the following:
Part here: _.gif PS2087058
Mar 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Smeg se336ss 5 some so and so has broken the outer glass door!
We removed the front glass of our oven door after a big spill between the two glass sections (by blunt force!). Since it took us 4 hours to put back together, we wanted to spread the info in case any others have the misfortune to make this mistake! Note, I wouldn't do this unless you have to, just incase you can't get your door back together again.
Assuming the back sheet of oven glass is still in position, but the front sheet is not attached -
1. Follow the manual instructions to remove the door, ensuring that both hinges are locked fully (otherwise you won't be able to get the door back on easily)
2. Once the door is removed, ensure that the plastic spacers that hold the two sheets of glass apart are in original position, resting on the inner door, at the bottom corners of the tempered glass
3. Remove the narrow metal strip at the bottom of the inner door by unscrewing the 3 screws that hold it in place. This is the metal groove that the outer pane of glass needs to rest in
4. Lay the outer sheet of glass in position in this metal strip
5. Lay the outer sheet of glass over the inner door. Slot the outer sheet into position at the top of the inner door first, ensuring it is layed flush at the top.
6. A second person needs to ease the metal strip back into place at the bottom of the inner door, so that the two sheets of glass are now held together at both top and bottom.
7. Screw the metal strip back into position with the 3 screws
8. Follow the manual instructions to replace the door. Ensure that the small grooves at the bottom of both hinges are resting in position correctly, otherwise the door will not close flushly.
Jan 17, 2009 | Smeg DO81CSS Electric Double Oven
Ovens Logo
159 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
