Question about Whirlpool Washing Machines
Hi, I've lost the manual for myWhirpool WFS1073CD washing machine. During a wash it has suddenly stopped and asks me to clean the pump. Can you please tell me where the pump is and how i can get to it. Is this also possible while it was in the middle of a wash?/ Eva
    Brigadier General:
  • 6,277 Answers
It is possible in the middle of a wash BUT I'm sorry, you need to switch the machine off to do it. You will see why!
Here are my guidance notes for checking both the drain pump filter and the drain pump motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 23, 2011
I have a whirlpool WFS1073CD and getting a red light indicator saying clean pump. It appears to be washing normally but wont go into the spin cycle. I have drained the water via the filter plug under
Hi Maureen
Wow.... at least this model has an indicator light telling you what the problem is. Many machines don't!
I think the reason it won't go into the spin cycle is that the water can't exit through the pump.
The usual cause is that a sock or something is caught or blocking the pump.
Power OFF of course.
Follow the drain hose back to the pump & try unclipping the hose off either side to feel for a blockage with your finger.
Pump blockage is a common occurrence in washing machines.
Good Luck
Nov 26, 2014 | Whirlpool Washing Machines
Washing Machine won't drain away water.
Hi, can you hear the pump running when you select a drain program?
Mar 11, 2013 | Washing Machines
How do I clean the pump of My whirlpool wfs1073cd
Above solution is correct, check with your fingers for obstructions on the pipe that branches off to the left of the opening. Objects get caught here.
Mar 06, 2012 | Whirlpool Washing Machines
Washer (total care system) is making a humming noise even though I've taken all the clothes out of it. The agitator works, but there's a humming noise. I've stopped it and re-started it, but...
Hi
1 of 2 things could be the trouble.
Does the washer drain properly if you manually turn the control knob? If not then this sounds like your pump is either plugged with possible lint and can't move or has died completely. 99% chance pump is the problem and 99% chance it can be an easy fix by cleaning the pump where the Drain Line is attached, worst case scenario pump is to be replaced, but not a overall expensive fix and most can do it without a technician.
Second problem is possibly the time itself, but if the washer is going through all cycles except spin then pump is likely the culprit, cause in spin cycle the machine has to drain the water from the unit as it spins, if it cannot the washing machine basically stops and cannot complete the cycle.
One way to tell for sure if the pump is the problem. When the machine enters the spin cycle and starts making that noise. Manually turn the dial a little bit till it passes the spin cycle, if it continues to wash till it hits the final spin/drain cycle then stops again...your pump is in need of help.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 04, 2011 | Kenmore 24032\24036 Top Load Washer
My washing machine wfs1273bw keeps saying clean pump, how do i do this. I have released the plug on the bottom right corner which lets water out but then it happens again....
Releasing the plug to drain the water won't solve your problem. Your washing machine has a pump that controls the flow of water. There might be an object like coins, or metal from your laundry that may have been included during the washing and is now blocking the pump. Try to unscrew the paddle that rotates during washing. By removing it, you can manually remove any possible obstacle that keeps blocking your pump that causes your washing machine to alert you to clean the pump.
Jul 23, 2011 | Washing Machines
I ve lost my manual for my lg turbo drum dd wt-h555th im wanting to know how to do a tub clean the washer is leaving dirt on the clothes
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Feb 21, 2011 | LG Washing Machines
Machine stops during the wash cycle.
Hi this is abhishek,welcome to fixya
over weight normally doesnt cause machine to stop during the wash cycle,,iit is actually tub gettiing stuck or a timer problem...
thank uy........
May 03, 2009 | Bosch Logixx WFR 2867 Front Load Washer
Leaking washer
Check the pump where the shaft connects. Is it wet or rusty? If so replace the pump...
Dec 16, 2007 | Washing Machines
Washing Machines Logo
622 people viewed this question
Dan Webster
Dan Webster
Sal De
