Sir, i am getting jam problem error code ps14 sensor error
How to fix dot matrix printer Printer paper jam?
If you wish to get some details about printers an copiers error codes and repair ; check the site linked here. Pull up older posts...
http://electro-medical.blogspot.com/
May 21, 2016 | Matrix Office Equipment & Supplies
0F54H Fatal Error
Witam,
An error occurs on the toner level sensor for each color:
0F52H Toner level sensor /Y malfunction
0F53H Toner level sensor /M malfunction
0F54H Toner level sensor /C malfunction
0F55H Toner level sensor /K malfunction
Relevant electrical parts:
Toner level sensor/Y (PS13)
Toner level sensor/M (PS14)
Toner level sensor/C (PS15)
Toner level sensor/K (PS16)
Printer control board (PRCB)
Step Action:
1 Check the connector between each sensor- PRCB PJ21 for proper connection and correct as necessary.
2 Replace the toner level sensor of the corresponding color.
3 Change PRCB.
Feb 11, 2014 | Konica Minolta Magicolor 3730 Dn Color...
How can I correct SC29-04 on Konica 7255?
The sensor is located on the left side of the drum cartridge it is a sensor that is covered with a white cover to the rear of the drum you must remove the drum to see it clean with cloth not a vacuum cleaner Static from vacuum can destroy it. The clear glass sensor is for paper jams! Located in the middle of the cartridge. Mite also want to know when the last 250K copies PM was done?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 28, 2012 | Konica Minolta TN601K Toner for 7155,...
Dear sir when i start machine ir3300 i get code
I.e. Teflon problem if u getting the paper jam in fusing unit every time teflon is cutted in fuser unit is getting prints after meachine on and off, problem with the sensor u cleam it that's work fine. for any information plz mail me e-Mail : meda.purushotham@gmail.com, 919290062654
Feb 23, 2010 | Canon imageRUNNER C3200 Copier
CANON GP 405 ERROR E 051
My machine gave me an error E051 and it could not start. when i restarted, it still ended at that.
i decided to switch it off and wait for the technician to come and fix it.
the next morning i arrived before the technician came and when i switched on, it was very fine.
what could have happened.
Tonny Obwin Telecommunications engineer.
May 02, 2009 | Canon imageRUNNER 400S Copier
Error message shows e2 but there isn't a paper jam anymore
Hello sir; try to turn off the power and turn on, if still don't work, you have to check the sensor it located where the paper got jam,
Jan 10, 2009 | Xerox WorkCentre XD120f Copier
Code 200 Paper Jam Error
Hi Mike,
This error can be caused by many reasons, some of them are:
Caused by Paper Stuck Under the Second Transfer Roll
Sporadic or Intermittent 200 Paper Jams
"200 Paper Jam" Resulting from a Possibly Damaged Tray
"200 paper jam" When Attempting to Print from Tray 2
To troubleshoot this problem, please click the links with their respective causes.
Please rate it fixya if it was helpful.
Thank you
Dec 19, 2008 | Lexmark C750 Laser Printer
Error codes 051
it is around the horizontal registration home position switch (ps14) Check out the paper feed real good
Dec 18, 2007 | Canon imageRUNNER 210S Copier
Paper jam, and check film error messages
dear sir the film sensing sensor and paper path sensors are abnormal or dusty pleaz check them
Sep 19, 2007 | Panasonic KX-FP121 Plain Paper Thermal Fax
19 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
