Question about American Standard Ceramix Monoblock Bathroom Faucet w/ Escutcheon Plate, w
I need the cold water stem for a American Standard washerless bathroom faucet where can I get parts
    Genius:
  • 1,739 Answers
American Standard has an on-line Repair Parts centre:
http://www.americanstandard-us.com/store/repair-parts/
Posted on Mar 23, 2011
Dripping water unless I totally shut off cold water line.
If you will make contact with George at M-One-Specialites he can track that down for you and help you get that fixed.
He has a very extensive list of repair parts for faucets.
Rod
US Parts Center
Jan 29, 2013 | Kohler K-12265-4-CP Fairfax Widespread...
Cold water handle on my American Standard cold water control just spins around with out turning on the water
There is an adapter from the faucet stem to the handle. A small gray plastic faucet part that frequently causes problems for many owners. You will need to call American Standard and ask for a new handle stem connector. The faucet came with a limited lifetime warranty and the part should be free. While you are getting one, you might as well get another for the other handle. American Standard's phone number is 1-800-442-1902.
Sep 05, 2010 | American Standard Hampton Two-Handle...
I bought a replacement Danko faucet cartridge for an american standard bathroom sink and the package said hot/cold but when I installed it on the cold side the handle turns the wrong way. How do I reverse...
Thae stem you got that said hot/cold were designed to fit old style cross handle faucets. So both hot and cold turned the same way. If the cold side you are replacing turns the opposite direction then you will need to get a cold stem. Danco does make them. Ask the retailer where you purchased the H/C stem. I hope this helps..
Dec 29, 2009 | Danco Faucet Cartridge
Apparent flow blockage
I would turn off the water then check to make sure you have good flow up to the faucet itself. If you do then there might be a proplem with the cartridge or diverter. does it have a sprayer? If it has a sprayer head for the spout of the faucet then there will be what the call a check valve inside the spray head itself that canbe removed with a skinny screwdriver or something thin and long
Apr 29, 2009 | American Standard Kitchen Faucet 6310 020...
Replace inside stem on hot water Eljer shower faucet
Sounds like you might need a gear puller -- hardware stores would have them -- or auto parts.
Spray with contact cleaner wd-40 first, then install puller, depress ring and crank away at the puller.
Apr 21, 2009 | Home
Kitchen sink keeps dripping...how and what do I need to do to stop the dripping
Is this a single handle faucet or a double handle? If it's a single handle, you have to turn the water off then remove the handle. The set screw for this should be under a little plastic plug under the handle near the base of the handle. After you remove the handle, remove the housing cap to expose the valve ball. Under the valve ball are 2 small circular washers and springs. Pull them out and replace them. If it is a cartridge style faucet like a Moen, then you remove the u shaped retaining ring and pull the cartridge out.
If it is a double handle faucet, remove the handle and using a pair of pliers or a crestent wrench remove the stem. You will find the washer at the base of the stem held on by a screw. It could also be a washerless stem and in that case you will need to replace the whole stem.
If you have anymore questions, just respond to the post and I will get back to you as soon as I can.
Mar 22, 2009 | American Standard Plumbing
Dripping faucet
Take a cloth and lay over the top of the stem so as not to damage it. With pliers, grasp the top of the stem and turn it a quarter turn counter clockwise. The stem should lift right out.
Mar 14, 2009 | Kohler Model 102704A: Fort® Centerset...
American Standard Ceramix Monoblock Bathroom Faucet w/ Escutcheon Plate, w Logo
154 people viewed this question
Top American Standard Plumbing Experts
john h
Steve Wood Plumbing...
Level 1 Expert
Mike
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
