Question about Triton Pro Three Wheel Trike Recumbent Bike Bicycle
I want to make the bike faster how would I do that its the three wheel triton pro single speed no chains
    Brigadier General:
  • 8,546 Answers
Pedal faster. Or get a bigger drive wheel. Good luck with that.
Posted on Mar 23, 2011
Difference between a fixed gear and single speed bicycle?
Single speed bikes are often known as Fixed gear or fixie bikes.
But Most people don't know the difference between a fixie and a single speed bike.
It's all in the hub
Mechanically, the difference is so small that you might not spot it even when you are looking for it. It all comes down to the rear hub and how the single cog is connected to the rest of the drivetrain. Single speeds are fitted with a freewheel cog that rotates freely one way but locks up the other. This means that the cog will turn the rear wheel when you pump those pedals, but then freewheel when the rear wheel starts turning faster than the cog - much like a geared bike.
When it comes to Fixies, it has no mechanism on the hub. The cog is fixed into the hub. If the rear wheel turns, the cog turns, and if the cog turns, the pedals turn with that. I admit the difference is not so small, but one that has a huge effect on how a bike rides and requires some consideration before you decide on a bike.
If you want to know more about Single speed and fixed gear bike
Have look on this
Gear bike review Blog.
Best Fixed Gear Bikes In 2018 Enjoy Your Ride On Cool Fixie Bikes
Mar 29, 2018 | Cycling
Tip
Identifying Your Schwinn Airdyne
How To Identify the Model of a Schwinn Airdyne Exercise Bike
  • We'd like to share some characteristics of the Schwinn Airdyne bikes that can be used to help you identify the model of your Airdyne bike.
What size/type fan does it have? Is it a spoke fan like a bicycle wheel or short wide blade fan?
Does your Airdyne bike have two chains or a chain and a belt?
  • AD3, AD4 bikes have two chains.
  • AD Pro/Comp and AD Evolution Pro/Comp bikes have a chain and a belt.
How do the crank arms attach to the Airdyne, by wedge pin or bolt?
  • AD3, AD4 and certain AD Pro/Comp crank arms attach by wedge pin.
  • Certain AD Pro/Comp bikes have crank arms that attach by bolt.
  • AD Evolution Pro/Comp bikes have crank arms that attach by bolt.
How To Identify the Model of Schwinn Airdyne Bike
on Mar 11, 2015 | Schwinn Original Airdyne
When riding the peddles slip,it appears that the chain is engaged and that the axle is slipping and make s the peddles spin, not engaged
If this is a coaster brake bike (single speed, no hand brakes) then the problem might be inside the rear wheel hub. If that is the case then you can only fix it by completely dis-assembling the rear wheel hub - or it might be simply that the chain is slipping, which would not happen unless the chain is too loose which would be indicated by the bottom of the chain hanging down too low. However, if this is a multi-speed bike, then it could be that the chain and rear-wheel cogs are worn - which can be fixed by replacing the freewheel and the chain - however, it takes a lot of use or rust and dirt before that level of wear happens.
Aug 07, 2012 | Trek Mystic 16
Chain is to loose. How do I tighten the chain tension?
LOOSEN THE 2 BOLTS HOLD WHEEL ON PULL BACK ON WHEEL WHILE TIGTHEN BOLTS BACK UP. CHAIN DONT HAVE TO BE SUPER TIGTH . ABOUT 3/4 OF SLACK IN CHAIN.
Nov 18, 2010 | Schwinn Scwhinn 26 Inch Womens Coronado...
We have an 18" boys huffy bike and the chain keeps falling off. How can I repair.
If a single speed bike loosen the rear wheel and pull it back away from the pedals to get the chain tighter
If it has multi gears the arm hanging down has a ser screw that will need to be adjusted to align the chain to stop at the last gear
May 20, 2010 | Cycling
I insralled training wheels, but now the chain does not move, why?
I'd look for unwanted contact between the hardware attaching the training wheels rear wheel nuts and the chain, wheel, gear or tire.
I suspect a screw is a tad too long.
Apr 06, 2010 | Huffy 16 In. Girls Dream Journey Single...
Where to buy a brake cable
I've never worked on one of these puppies, but from the pix it looks like a garden variety brake cable--a rear brake cable, as it's got some length to it. If I'm wrong, the guys at a decent bike shop would be able to hook you up.
Jul 06, 2009 | Triton Pro Three Wheel Trike Recumbent...
I need to set my bicycle chain on a single gear
well there is a place on the chain that can unlink. it might be hard to find but it is there. then simply wrap it around the single gear.
Mar 31, 2009 | Springer 26" Stretch Beach Cruiser
How do I reassembe the gears in the rear wheel?
Refer to Parktool.com. There are bicycle specific tools required for this repair.
Jan 03, 2009 | Huffy 12 in. Girls Disney Princess Single...
Triton Pro Three Wheel Trike Recumbent Bike Bicycle Logo
94 people viewed this question
Top Triton Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Triton Cycling Expert? Answer questions, earn points and help others
