Question about Audio Technica AT-PL120 Turntable
Start/stop switch does not move turntable. it is plugged in. what could problem be?
    Sergeant:
  • 298 Answers
Most likely a broken drive belt - find a replacement online
Posted on Mar 23, 2011
Technics SL-220 not turning (although it seems to be trying!)
I'd suggest to unplug it from power for 5 minutes push a couple of times on power button (while unplugged) then plug it back.
Jul 10, 2015 | Technics Audio Players & Recorders
Hi having a problem !!
If it has a belt drive, the belt has to be replaced.
Mar 22, 2015 | Technics SL-1210 Turntable
How do I get the power switch to flip to the "start" position? It seems to be stuck.
like i told before, you can at electronic stores and just a turntable dealer
Oct 04, 2014 | Audio Players & Recorders
Turntable comes on when plugged in but stops when record is cued, should work the other way around
When the arm moves it pushes on a contact switch. It seems that this contact switch is simply out of place, so needs adjusting.
Jan 25, 2014 | Crosley 0187SST Turntable
Sony turntable ps-lx250h won't stop turning it has to be unpluged. what do i do?
When the arm moves it contacts a switch which should start and stop the motor. Clearly this switch has broken and the contacts are now in the on position.
Jan 18, 2014 | Sony PS-LX250H Turntable
Stop spinning
If it used to start spinning when the arm was move towards the record, then it's likely that the arm is connected to a switch which is now faulty and the contacts have closed and wont open. You might be able to get to it from underneath the deck. It might have just gone out of shape and could be bent back.
Aug 27, 2013 | Technics Audio Players & Recorders
Hi, I've had this turntable for about 10 years. I have moved a few times and this may be the cause. The problem is that the platter starts spinning once the unit is plugged in. It won't stop until its...
I suspect that you might have dislodged some of the mechanical parts in the move. Or something plastic has broken. The only cause of action is to remove the bottom of it and look around it.
Aug 18, 2013 | Sony PS-LX250H Turntable
Turntable won't stop spining
If it is a turnatable that starts spining when the arm is moved to the record, then more than likely the start/stop switch inside the turnable is broken and is fixed in the on position. Or the leaver mechanism has become detached from the arm when the record was playing and left the other part pressing on the same switch that turns the motor on or off.
Removing the bottom of the turntable should should show the trouble.
Apr 03, 2012 | Philips WMM142211 Turntable
I have just bought 2 1200 mk2 ,the seller has told me the start/stop buttons where powered by a mixer and will either need to be reconnected this way or reconfigured is this a problem??
who ever told you that is a ****, start n stop are tied into the power of the turntables motor etc. if you plug the turntable in turn it on n hit start. it should start. if not who ever sold it to you made a BS lie to get rid of them cause the motor was burnt out. start n stop have nothing to do with the mixer what so ever. so try just hooking up the turntable and turn the power on. see if anything lights up then his the start button and see if the platter starts to move if not its your motor.
May 30, 2011 | Technics SL-1200MK2 Turntable
Start/stop button doesn't move platter
nakered switch then needs replacing
Aug 07, 2009 | Numark Pro TT-2 Turntable
Audio Technica AT-PL120 Turntable Logo
166 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Paul Bade
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
