Question about Sport & Outdoor - Others
I open the cover and I have power, , the little green dot light is on. I took the back of the board off and when I unplug the connection, it,s sound like a relay switch. But the board eoesn't light up, it did it just for a few seconds, showing the 8 code on the incliner. Now it doesn't nothing, any sugestion? It is a Sport Craft TX 390 MODE 04039
    Guru:
  • 1,833 Answers
First check your electric outlet where you plugged in the sport craft and also the power unit of the sport craft.
There may be any fault in the circuit board. You can go to the nearest service center for checking and repairing.
Posted on Mar 23, 2011
Blank Screen on Sony KDL-46XBR4
It sounds that the back light inverter board have the fault. Replace it.
Jan 24, 2013 | Sony KDL-46XBR4 46 in. LCD Television
My LG 32LCD (32LC7D-UB) comes on every now and then. When powering up the light will flash green and then stop with no picture or sound. If I unplug and plug back in and the light goes red and it will now...
The power supply board is the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 15, 2010 | LG 32LC7D Television
Green light blinking
posible the PSU has failed or have a short somewhere inside case/MB/hardware
Jul 01, 2009 | HP Pavilion a620n (PC028A) PC Desktop
50" maxent green light no picture
WWW. maxentusa.com. Sounds like your power supply board is bad or you have a shorted board somewhere. Maxent is still in business and they are pretty good at customer service.
phone 1-888-373-4368.
Mar 07, 2009 | Maxent MX-50X5 Television
Dell E151FPb 15" LCD with power LED blinking.
The problem may be a loose connection. When I turn on my monitor, the green light blinks and a flickering white screen appears for a brief second every time. There must be a loose connection on the power board which may be causing this. The easiest solution is to tap at the back of the monitor. This will reconnect the loose end and the monitor will work fine until it gets disconnected again. I will open my monitor soon to find the real problem. But it will take some time to find it.
Aug 17, 2008 | Dell E151FPp 15" Flat Panel LCD Monitor
TV does not turn on/red led flashes 7 times in front
this is common issue with this model and through your troubleshooting is tied to y main board. blinking led on logic main in normal operation. when replacing y main always good idea to replace y upper and lowe buffer boards as they complete a circuit and sometimes replacing one without other could cause additional failure on remaining boards
Aug 10, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Philips 42PF9630A/37 PLASMA TV
Replace that board the part number is 996500032643. go to www.vancebaldwin.com for the price of the board.
No power
It sounds to me that you have a bad HV/Power Supply Board. Before opening the back of the set, always unplug the set from the wall. If you can check electronic components ( ie: transistors, capacitors, fuses etc ) I suggest you check the Horizontal Output Transistor first. If it's not that transistor, check for cold solder joints ( loose connected parts from the printed circuit board ) and re-solder all bad connections. If the set still doesn't work, you may need to seek professional help, as the problem is more deeply laden and you may need to obtain a schematic to repair the set. I hope this has helped. Good luck on your problem.
Ed
NC Electronics
Mills, Wyoming
Feb 18, 2008 | Mitsubishi VS-6041 60" Rear Projection...
Mitsubishi WS-65809 turns off right away
check 2 5amp chem fuses. in middle of tv. yellow or orange in color . if bad replace the 2 stk convergence ics and fuses.
Nov 06, 2006 | Mitsubishi WS-65809 65" Rear Projection...
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
