Question about Ovens
Gorenje B3350E I cannot set the clock and the oven will not operate unless the clock is set.
  • Anonymous Nov 14, 2008
    Recently moved into house with this oven installed. Time display flashes 00:00 and Auto. Unable to set clock time or to set to manual.
  • Anonymous Jan 14, 2009
    Same problem
Briefly press the first two buttons simultaneously (the button that says Timer with a picture of a bell and button with a picture of a steaming pot). You should now be able to set the time with the jog dial. It automatically starts the time a few seconds after you release the jog dial.
I have a Kleenmaid TO400 in Australia and it's the same as the Gorenje B3350E. Thankfully I have the manual as this would be impossible to guess
Posted on Jul 31, 2009
I cannot get the big oven on my belling db90 to switch on. the clock is flashing 00:00 auto
Set the clock to manual....a hand symbol..... then try again....the oven wont work on auto unless you set time on and time off
Oct 06, 2017 | Belling Ovens
GE Wall Oven Model # JKP07G0D2BG - The clock has quit working. Any suggestions would be greatly appreciated.
I assume the display for the clock/timer is now blank. If the oven is still working the only thing you are missing is the clock. If you can't do without it you will need a new clock.
Most of the time the clock/timer stops working it affects the operation of the oven, the oven won't work. If this is the case you will need a new timer unless you can do without the clock/timer. If so a repairman should be able to bypass the clock with ease so that the oven will operate without the clock/timer.
Feb 12, 2011 | GE 24" Built-in Single Electric Wall Oven...
We cannot get the oven to work and there is no operating instructions available - can you let us know how to put the fan oven on, apparently it has got something to do with the timer?
The clock has to be set with a time. Any time. When you set the time you will hear a relay operate which will switch the power through to the oven controls. If the clock is faulty so that you cannot set a time, you will not be able to make the bottom oven work.
Look at some of my earlier solutions to see how the clock/timer should be set.
Jan 26, 2011 | Stoves 720EF Electric Double Oven
Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
Nov 23, 2010 | Stoves 720EF Electric Double Oven
How do i work the grill?
Nov 21, 2010 | Stoves 720EF Electric Double Oven
The clock on my Cambridge oven wont work, I cannot set. Therefore the oven wont light unless the clock is set. How do I fix this problem? All the buttons have stopped working so therefore unable to set the...
bad digital control board if tis just a clock and all the settings can be done with a knob and not the board then the replacement wont be too expensive but if that board controls eveything which i suspect it does then its going to be at least 150 more to repair than if it was just a clock display
Mar 30, 2010 | Ovens
How to set the clock on Westinghouse Virtuoso 70 oven
hello im not sure how to set the clock on my oven move in my houe 4 mnths ago and i cant bake in it unless i turn the grill on so would u please tell me how to set the time thankyou Sylvana
Nov 30, 2009 | Ovens
I need a handbook for a gorenje gas hob and fan oven
Hi
You need o call Gorenge and they will send it if they have it.
0845 050 8555 UK
please leave feedback
Feb 11, 2009 | Ovens
The clock & oven on my cannon chichester cooker dosent work
Hi anyone , my chichester ignition button has stopped working - is there a battery located somewhere
Dec 05, 2007 | Ovens
Diplomat Oven ADP3650 Instructions
User manuals are hard to find.
The problem I had was setting the clock on a single Diplomat oven, with no clock button. Here's my solution :
DIPLOMAT OVEN OPERATING INSTRUCTIONS
The Diplomat single oven is controlled by two knobs and a set of buttons along the middle of the control panel.
The left knob sets the temperature of the oven, while the right knob selects the function to be performed, e.g. fan oven, grill, etc.
The buttons along the middle set the cooker clock, the start and end times of cooking, and the “+” and “-“ buttons will increase or decrease the time shown on the cooker’s clock.
PLEASE NOTE THAT THE OVEN WILL NOT OPERATE UNTIL THE CLOCK IS SET.
If there is any interruption to the power supply (including manually switching off at the main switch) the oven will not operate until the clock is reset.
Here’s how to set the clock:
First press simultaneously the first two buttons to the left of the control panel. They are marked as a Bell symbol (Alarm) , and a steaming Cooking Pot (Start of Cooking Time). Then immediately press the plus “+” or minus “-“ buttons to increase or decrease the time displayed. When the desired time has been reached, leave it for a few seconds, and it will remain set at this time. Any further changes to the displayed time will require this procedure to be repeated.
Hope this helps!
Oct 10, 2007 | Ovens
Ovens Logo
3,830 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
