Question about Vacuums
My eureka petpal 4716 is smoking. We've cleaned out the filter and hoses and can figure out why it is still smoking.
  • 7 Answers
SOURCE: eureka 4700a bagless vacuum
I'd check the hoses again and see if there are rips or leaks. If it has a seperate motor for the suction, I'd make sure that it works.
Posted on Nov 21, 2007
  • 30 Answers
SOURCE: Burning smell and smoke
I ran into a scenario similar to this at work. With the burning smell and smoke combined, it leaves only one problem remaining; the motor. The motor and the pulley that enables the belt to spin could be malfunctioning (causing friction between the 2 parts) and thus causes the burning smell and the smoke. I'd highly advise not to touch either part after having the unit on (YOU WILL BURN YOURSELF).
The only other likely possibility is to make sure there aren't any hairs caught in or around the motor and the bearings of the agitator.
Posted on Mar 08, 2008
buffalonyman
  • 1865 Answers
SOURCE: Eureka Capture won't turn on after thermal cutoff
Return it for an exchange, under warranty
Posted on May 02, 2009
  • 8 Answers
SOURCE: my eureka smartvac 4870 has no suction at hose or
your eureka has no suction kuz the vacum hose needs cleaning
Posted on Nov 29, 2009
heatman101
  • 43501 Answers
SOURCE: Eureka upright is smoking and blowing air rather than suction
Yes the first thing that I would do is to change the belt...run it for a few seconds and then check the belt... if it is hot then you have found your problem...if it is cool then you need to keep looking...
heatman101
Posted on Apr 30, 2010
My eureka boss 5856 has suction through the hose, but the cyclone isn't spinning and it will not pick up anything. I have tried using it normally and with just the hose and it will not pick up.
Is the suction strong or weak?
Have you cleaned or replaced the filter?
A plugged filter will restrict air flow and cause vacuums to lose the ability to work properly.
Mar 10, 2017 | Eureka Vacuums
Theres smoke coming from the motor of the eureka pet pal bagless vacuum cleaner.. i dont know what to do
Some vacs have two belts. Is urs also self powered? If so, has a separate belt. With model # can give better info.
Nov 26, 2014 | Eureka Pet Pal Bagless Vacuum
Eureka Maxima 12 amp vaccum cleaner is not picking what can be done to make it pick up?
remove and clean the filter ( tap and brush filter or use a air compressor to blow out filter ) --- also check the vacume hose near the floor attachment for any dirt and debris that may be clogging the line. this should bring your vacume to full operation.
c...
Jan 22, 2011 | Eureka 4700A Maxima Bagless Upright Vacuum
My Eureka Lite speed whirlwind has a bad odor when it runs.
It is either the filter or on the roller or belt.
  1. Eureka Parts Storewww.Eurekapartstore.com Unbeatable prices on Eureka Parts Largest site for Eureka parts.
  2. Eureka Partswww.ThinkVacuums.com/Eureka Eureka Central Vacuum Accessories Find Hoses, Tools, Nozzles & More! Google Checkout
  3. Eureka Part Storewww.vacuums24x7.com/Eureka-Parts Bags, Belts, Filters, Repair Parts. Complete Selection Eureka Parts.
Jul 06, 2009 | Eureka WhirlWind Litespeed 5844 Upright...
My eureka 2961avz bagless vacuum has no suction
Usually clogs are in the dirt inlet by the brush roll, or in the hose. Take the hose off from the bottom and see if there is suction, if not, then the hose is clogged. If suction there, then it is lower. Also is the brush roll turning, if not, that could be your problem.
Jun 06, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
Vacuums Logo
29 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
