Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
GFI Plug on my Dream Maker spa is ticking when I plug it in the pump will run but it pulses.I just ran a dedicated line to it and when i plugged it in this is what I got,it also does this when plugged into an existing outlet.It was working fine two days ago.
    Top Expert:
  • Dream Maker ... Master
  • 8,688 Answers
Bad recirculation pump
Posted on Nov 19, 2017
vincob
  • 718 Answers
SOURCE: spa keeps tripping breaker. Not GFI. Ran for 2
Sounds like wiring problem, rule out GFI sometimes they just go bad or have your wiring checked in that run something is not hooked up correctly or loose. Make sure this circuit it is not shared with anything else. If not ran for 2 years could be wiring problem in spa get it checked out be safe, water and electric bad news if your not familiar with or comfortable with electrical issues. Good luck!
Posted on Oct 15, 2009
SOURCE: my dream maker spa does not work. there is
I have the same problem with a one week old x400. It was working fine last night but about 8 hours later water temp has dropped 4 degrees and the pump will not turn on, I can hear the relay in the control box make a ticking sound when I press the pump icon on the control center but the pump does not start. Is there a fuse in the control box?
Posted on Nov 01, 2009
SOURCE: how do you replace jets on dream maker spa X-500
There is a tool that comes with the spa, instructions are in the owners manual. If you don't have the manual you can download it here
http://www.dreammakerspas.com/_PDFs/0607l.pdf
If you don't have the tool you can order one from Dream Maker.
Posted on Nov 04, 2009
  • 15427 Answers
open control panel will see a small glass fuse replace if blown if 220 volt check that getting power on both lines
  • 246 Answers
SOURCE: when you first plug your dreamaker spa in the
TURN THE BREAKER OFF FOR 20 SEC THEN TURN BACK ON AND FAST TURN ON ALL PUMP FOR 30 SEC THIS WILL BLEED ANY AIR TRAP INSIDE THE SPA
Posted on Nov 18, 2009
I have a dream maker space just delivery with a 15 amp gfci plug in. Can this be plugged into a 20 amp outlet which also has a GFI on it
Yes you can plug a 15 amp to a 20 amp, but not the other way around, as long as your drawing less current (amps) then the plug is rated for you all set.
May 06, 2017 | Pool & Spa
I have a dream maker spa and the plug was clicking and know it will not run at all
sounds like the plug has gone bad it has a built in GFIC and needs to be replaced. ask your local ace hardware they might be able to help you out with a cheaper alternitive
Sep 25, 2013 | Dream Maker Spas Pool & Spa
Breaker on the end of spa plug-in trips overnight. I can unplug it and plug back in, tub runs to it's 100 degree default settings. Will stay on and maintain all day, but overnight I will find the tub off...
I have had a few troublesome units over the year that did as you describe due to 'dew' overnight collecting around the tub and the increased moiture sent the motor of the circ pump "over the edge" iinto a grounded state. A leaking pump seal was adding to the problem. Once the seal leak along with the dew got high enough the GFI would sense the grounded condition and trip. Fixing the pump seal and drying/cleaning the motor fixed the problem every time. If you find any other leak sources around the pump you will need to fix them as well.
Oct 12, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
GFI plug is heating up on spa causing motor to not come on
unless plug is bad u will need to check the motor or heater one of them is pulling high amps heating up plug--oil motor may help--but will need to check the amperage on the motor and or if heater is cause if no amp probe --when system is cooled plug in and turn down heat setting let motor for a while if plug heats up or motor goes off on over heat know problem is with motor or plug-if no change now add heater if plug gets hot and turns off when heater is applied know heater is problem
Jul 28, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
My dream maker spa sounds like it is trying to click on when I hit the switch but it doesn't come on. There is power and the topside control will adjust temp and turn on light but the pump will not come...
An electrical supply house would have, or could get your fuse. You can also contact Dream Maker and they would send one to you. It sounds like the you have a voltage issue and may pertain to other fixtures you have on the circuit (such as freezers). If you have the spa plugged into an extension cord, this will likely be the cause. You need to have an electrician run a dedicated 15 amp service to the spa.
Jan 01, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
144 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
john h
Craig Butler
Craig Butler
wadingriver
wadingriver
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
