Question about Timex Watches
How do I reset the time for a timex WR5OM? - Timex Watches
How to set the time on timex WR30M watch?
hi Janet.
You may also need to change the time when traveling or to adjust for daylight saving time.
  1. What to Look For. Locate the MODE button, the SET/INDIGLO button and the START/STOP button on the side of your Timex Indiglo WR 30M.
  2. Setting the Hours. Press down the MODE button until "TIME" appears. ...
  3. Setting Minutes and Date
https://oureverydaylife.com/how-do-i-change-the-time-on-a-timex-indiglo-wr-30m-12421830.html
How to set the time on timex WR30M watch Google Search
Dec 13, 2017 | Timex Watches
How do i reset date after battery change? or where can i cet a pdf file a9no calliber number on case or movement but its a timex perpetual with indigo light approx 30 yers old
to reset the date manually, pull the stem out to the second position to reset TIME; manually continue setting time until the date is on the correct day/date.
I had to do this to get back to the proper date when my timex was off by a week. Nothing else worked. 14 times around (twice per 24 hour day) and each time I passed "midnight" the date advanced.
blessings!
Mar 12, 2011 | Timex Watches
I have a timex exped. that looses time i changed the battery twice can you give me some suggestions on fixing this problem ?
Generally speaking if a Timex needs more than a new battery (cell) it is new watch time. Anything else is either too expensive (more than a new watch) or can't be fixed. Make sure you have the cell in correctley, if there is a reset, reset the movement. This is often a matter of shorting out a small pad to ground with metal tweezers.
Mar 10, 2011 | Timex Watches
My timex watch is on military time and I can;t get
After much frustration, I found the solution...
Push the set button while on time mode. Push mode until the hour is flashing.Push Split/Reset.
That should be your solution!
Mar 15, 2010 | Timex 40131 Wristwatch
Trying to reset time on timex 1440 sports watch
Here's a link to some Timex watch manuals. I looked at the one for the 1440 but I couldn't tell if it was for your watch or not.
http://assets.timex.com/manuals/
The following site has Timex manuals also.
http://www.manualsonline.com/ex/thread/view/idThread/1136892
If you can't find your watch on these sites, perhaps some of the similar watches will give you a clue as to how to set the time.
Mar 14, 2010 | Timex 1440 Nylon watch
Help to reset date, day and time on Timex T5G341
Go to timex.com choose country then click on the help tab at the top of the page. You will find a tab for manuals and downloads on the left hand side.
May 01, 2009 | Timex T5G341 Sports Radio Control Watch
My timex watch is not right because the time is 24 hour time and i want to know how to change it to normal time
Select Time reset button (right lower side) until seconds flash
Select Start button on face and cycle through until 24-HR
Select Lap/Reset
Apr 13, 2009 | Watches
Have a timex Ironman triathlon 50lap can not reset time
http://www.timex.com/gp/node/n/255235011/178-1795200-7359408?ie=UTF8&timexBrand=core
This link will take you to the official Timex page where you can download the instruction manuals for any of their watches. All you need to know is the model number.
Jan 12, 2009 | Timex Ironman Triathlon 50 Lap Digital...
Timex 1440 sports
usually there may be an option for reseting time in ur watch
Nov 06, 2008 | Timex 27191 Wristwatch
Watches Logo
236 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
