Question about HP P5302M Computer Speakers
My hp s2031 built in speakers have no sound - HP P5302M Computer Speakers
  • HP Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 23, 2011
Hp s2031 goes dark, and sleep light goes out as if it.s unplug.
if the sleep light goes out, its probably not the inverter...
I'd suspect a fault with the power board.
It may not be viable to replace, unless you can find someone experienced to disassemble and diagnose the fault on this board.
May 15, 2012 | HP S2031 20-inch Diagonal Lcd Monitor -...
I cannot hear sound. Does the monitor come with built in speakers? I have a HPw1707.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01289551&cc=ca&lc=en&dlc=en&product=3686798
HP support addresses Low Sound or No Sound from monitor with built-in speakers. Copy and paste the address above into your browser.
Dec 05, 2009 | HP W1707 LCD Monitor
The built-in speakers on my HP w2408h do not work. I checked the sound generating electronics in my HP computer with a headphone. That worked. I plugged in the sound patch cord to the headphone jack in the...
hello bill.. i have a 190 B and not getting sound... checked all sound generating electronics as well.. i wonder are the internal speakers 'gone'? in mine i.e...??
Oct 26, 2009 | HP Computers & Internet
No sound
If speakers are built into the monitor, then there should be an audio cable that connects from the monitor to the green speaker out jack on the back of the computer.
If speakers are NOT built into the monitor, then buy a set of speakers from a store.
Mar 27, 2009 | HP Pavillion s7420n PC Desktop
Built in speakers don't work.i have sound only when i plugg the headphones
Looks like there is some problem with the stereo headphone connector. As its a hardware issue, I would recommend sending it to the service center.
You may also use external speakers temporarily.
Apr 15, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
NO SOUND!
Hi
Pls check if the audio cable from the monitor is connected to the tower. Make sure it is connected to the green port at the back.
Also check the volume button on the side of the monitor and set it to maximum.
If this doesnt work, then try with another pair of external speakers and check.
Jan 22, 2008 | HP vs17
My hp speakers wont work
Sample testing is usually a firmware built into the monitor amplifier ie the monitor is testing itself. you problem possibly lies with the computer sound system. Tell me more about this. Is it an 'On-board' sound card or separate PCI card. You can determine this by looking at the back of the computer- if all the connectors - sound- PS2 and USB are in the same panel - then it is an on-board system. If the sound is separate in one of the card position then it is a PCI card. The possibility is the sound system needs setting up- check your computer paperwork/manual and utilities disk for Audio drivers. Come back with some answers
Jun 23, 2007 | HP P5302M Computer Speakers
HP P5302M Computer Speakers Logo
557 people viewed this question
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
rfredey
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
