Question about Maytag Washing Machines
Washing machine comes on but water not filling tub
  • Maytag Master
  • 43,501 Answers
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Posted on Mar 23, 2011
Where would the water come from if it is draining from the bottom of the washer when trying to fill tub
more than likely the pump is cracked and as it fills its leaking out. If I had the model number off the machine I could give you a better answer
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 05, 2012 | Washing Machines
To fill tub with hot it makes humming noise only, turn to cold to fill tub cold water only
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
heatman101
Mar 31, 2011 | Washing Machines
No water in tub,water supply is conected but it doesn't fill the tub
heatman101
Mar 08, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Water will not come into the tub.
heatman101
Jan 04, 2011 | Kenmore 3.5 cu. ft. Front Load Electric...
THE TUB OF THE WASHER GETS REALLY LOW WHEN IS FILLED WITH WATER. NOW, ALSO THE WATER DOSENT COME IN WHEN I TURN IT ON
All top suspend tub washers drop down when they fill with water. And they rise again when they have pumped the water out. This is normal.
What is not normal is water not coming in.'
check following:
Water is turned on
Remove inlet hose and run water to see if it is blocked.
Clean the inlet filters.
If you hear a buzz but no water goes in the inlet valve needs replacing.
If yu use only cold water try swapping the cold hose onto the Hot inlet. Then select Warm Wash.
Then only turn on the Cold Tap.
This will allow you to fill the machine and do a wash.
Watch out though when it comes to the Rinse position......some machines only do a cold rinse, and because you have swapped the hose over to hot it will not fill to rinse the clothes. Until you can get a Tech to do the repair you can just use either a bucket to add cold water for the rinse or use the garden hose to fill the tub with cold water for the rinse.
Have yu got all that?
Oct 25, 2009 | Speed Queen AWS75NW Top Load Washer
Kenmore Series 90 top loading washing does not fill with water
Well you eliminated the fill valve when you said it does fill with water. More than likely its a bad connection on the control board. I wouldn't betmy paycheck on it but thats where I'd start. Take the cover off the control board and while machine is on being really careful wiggle each wire until the water starts in the tub and you have found the problem.
Aug 23, 2009 | GE WVSR1060A Top Load Washer
Hot water stream when tub fills & how full tub gets super wash
there should be a knob connected to your water lines that come from the wall, turn the hot to the left.
Jun 22, 2009 | Estate Washing Machines
Waher
quite possiblethat the tub itself is sitting to far foward, this machine fills from the back section above the tub, very possible as it fills its deflecting off the tub cover and unto the floor
Nov 26, 2008 | Washing Machines
Washing Machines Logo
102 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
