Question about Sport & Outdoor - Others
My cs 2250 s Jonsered keeps having the same problem. It runs great for a few gas tanks & then it starts to **** air & therefore doesn't get enough fuel. It has been worked on for this problem 3 times during warranty time. Now warranty is no more but I still have the same problem. I have eliminated the bubble-primer & it has helped a bit still not quite enough. What should I do from there ?
  • 41 Answers
SOURCE: 1996 bayou runs for short time ,keeps stalling out
Hello, I would start first, make sure ex pipe is open . Then I would check the pick up coil, ohms should be 390-590 on a 300 KLF. Do this test before u start the bike Then start the bike and when it quits running check the pick up coil ohms. If good move on to the coil, If good then I would say good chance CDI is bad I hope this helps
Posted on Nov 26, 2008
  • 109 Answers
SOURCE: weedeater lawn mower shuts off, but still has 3/4 tank of gas
On some mowers...if the gas cap vent is not working properly, it will run fine for about 15 or 20 minutes, start spitting and sputtering, if you loosen the cap, and let air back into the tank it starts running normally again.
Posted on Apr 16, 2009
  • 6982 Answers
SOURCE: 2003 OLDS ALERO WONT START
find the buzzing noise...likely its the fuel pump relay.
Posted on May 28, 2009
SOURCE: I have a polaris sl 700 jet ski. After winterizing
ok, dont know if this will help but, I had a sl 780 that did the same, if you have a newer sl 700 with the multi-function display, and electric readout for gas and oil levels on display this could relate to you.. my float inside the gas tank compromised to the gasoline it was surrounded by and become saturated and wouldn't float anymore, which in turn caused the low fuel sensor to ****** the motor and keep it from reving up.. i had the same thoughts as you as it was a mechanical error, but turned out to be electrical.. and instead of buying a new $250 fuel level sensor.. i just opended the electrical box and unplugged the grey wire and it reved right up.. and if not electrical.. a carb kit is in need
Posted on Jul 21, 2009
rwvanlue
  • 486 Answers
SOURCE: Fuel starvation on Husqvarna 322l trimmer.
Gunner, you may want to;
inspect the lines for pinches or cracks,
clean or replace the fuel filter
replace the carburetor fuel pump diphragms/gaskets, and inlet needle
remove any adjustment needle for cleaning with a spray carb cleaner
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 08, 2009
Oil ratio for my Swedish made jonsered chain saw model 625=2
Using only a high quality 2 cycle oil mix 2.6 ounces of oil to a gallon of fresh gas.
Sep 30, 2014 | Oregon Jonsered 13" Chain Saw Repl. Chain...
Fix vapor lock
Hi, This sounds like the fuel pump needs replacing. Please leave me feed back: Malcolm Campbell, Thanks.
Oct 24, 2017 | Ford Crown Victoria Cars & Trucks
I have a 1998 Dodge Caravan. I got a "tune up" approx. 2 weeks ago with new spark plugs, fuel filter & air filter. It did fine driving around town & on a 130 mile trip. I filled up with...
Sounds like you got a tank of bad gas. That would easily cause your issues. Start by draining as much as you can, put a can of Seafoam in there, add a few gallons of fresh gas, drive to the gas station and tank up, and run that tank down until your gas light comes on before adding more. You may end up needing a fuel filter or plugs again, but with minimal run time on the bad gas, you'll probably be fine.
Jul 29, 2011 | Dodge Caravan Cars & Trucks
Changed fuel pump, sock filter, rinsed tank...still keeps acting like its running out of gas, stalls out, then takes anywhere from a few to hours to restart...what could this be? Sensor? At times, it will...
could your fuel tank be causing a vacum
check gas cap and breather if there is one on tank when fuel is going out air has to get in otherwise cause vacum
Apr 04, 2010 | 1997 Jeep Grand Cherokee
Jonsered cs 2250 fixed flow oiler can the oiling rate be increased i think its not getting enough as the chain is running almost dry
Remove the housing that covers that bar and sprocket. There are two plates on each side of the bar that set over the studs.They may be identical or slightly different depending on the saw but at least one of them will have a hole in it for the oiler. If you remove the bar and both plates you will see the oiler hole on the saw housing. This oiler injects oil through the plate and into a small hole in the bar where the chain picks it up and carries it around the saw. If this hole becomes plugged with sawdust it will keep your saw from oiling the bar proplerly. This hole should be cleaned out periodically. It's not a bad idea to remove the whole chain periodically and clean the chain guide all the way around the bar and get any sawdust buildup out so the oil can flow better.
Dec 03, 2009 | Garden
MY GX 240 starts fine runs great any where from 30
Can your gas tank breathe? Is your fuel filter clogged? Might there be something in the tank that would obstruct the flow of fuel?
Check the tank by loosening the top to allow air to enter.
Let me know what happens
a
Sep 23, 2009 | Honda 8 HP Engine
Car stutters like it's starving for gas. Have a few issues that I could use help on. 1. Car runs great in the morning (1 hour drive). In the afternoon on my way home (about a half hour in), it starts to...
Gas cap has no bearing,lol. Check the wiring under the battery tray. They're notorious for corroding through the wiring & cause a short to the ecm. This results in retarded timing & wierd stuff going on. Write back if you need more. Old car,lots to check.
Jul 16, 2009 | Dodge Dynasty Cars & Trucks
Weedeater lawn mower shuts off, but still has 3/4 tank of gas
Apr 05, 2009 | Garden
Sport & Outdoor - Others Logo
146 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
