Question about Garden
I have a wire pulled out of the 15 amp circuit breaker housing off of the solenoid on a 42" murray riding mower....can this be replaced and hoe difficult is it?
    Problem Solver:
  • 14 Answers
I believe from you description your referring to the 15 amp fuse. You can get a fuse holder at the local auto parts store along with a terminal end with a 5/16" hole and 1- **** connector. You will need an adjustable wrench to take the terminal loose on the solenoid and a pair of cheap wire pliers for the striping of the wires and crimping of the ends. Really pretty simple just make sure you unhook the negative terminal of the battery before doing any repairs to the electrical system. Let me know if this is enough detail for you.
Posted on Mar 23, 2011
Fuse for igntion were its located
    Riding Lawn Mower Fuse Replacement - Craftsman Lawn ...
    ? 1:51
    https://www.youtube.com/watch?v=rjFz8l8hoGk
    Aug 22, 2014 - Uploaded by RepairClinic.com
    ... instructions for replacing the fuse on a Craftsman riding lawn mower. ... Mower Starter Solenoid Replacement - Craftsman Riding Lawn ...
    14 HP Murray Mower 42813x92B Blowing the Fuse - YouTube
    ? 4:37
    https://www.youtube.com/watch?v=J8l1Ew40G7g
    Feb 14, 2013 - Uploaded by RogerASkiVideo
    Photographic guide to troubleshooting a Murray riding mower that keeps blowing the 15 amp fuse. images for Lawn Mowers ignition fuse
Dec 19, 2015 | Garden
Lawn trc murray 17.5 hp 42in cut
my specialty,but,you didnt post what the problem is,so,here goes,if it wont start,it is probably a bad safety switch,take the small black wire off of the coil,if it starts,then its a safety switch,if it doesnt then it is the coil,if it only clicks with a charged battery,it is the solenoid,turn on your key and short between the two big bolts on it if it starts it is bad,if you need a belt,i will need the numbers under the seat,otherwise i will try to find them for you,i will post a user manual for you here, Murray 425607x52A 42 34 Lawn Tractor Parts
Murray 425016x48A 42 34 Lawn Tractor Parts
Murray 425306x48A 42 34 Lawn Tractor Parts
Murray 425600x48A 42 34 Lawn Tractor Parts
Murray 425618x48A 42 34 Lawn Tractor Parts
Murray 42560x52A 2000 42 34 Lawn Tractor Parts
Murray 42820x24A 1996 42 Inch Cut Lawn Tractor Parts
Murray 425619x24A 42 34 Lawn Tractor Parts
a few manuals,find yours here or go here to find it by the numbers under the seat,all part numbers are in them, Search eReplacementParts com
Apr 24, 2015 | Murray Garden
Blowing breaker
In general house hold circuit breaker of the house is 15 Amps or 20 Amps.
Either you have defected (weak) circuit breaker and wiring or bad Microwave oven.
The 99.99 % house hold Microwave ovens pull less than 15 Amps. They may have internal ceramic 15A fuse or 15 Amp internal circuit breaker.
To isolate your problem:
1. Plug your Microwave oven to different areas (different electrical circuit) if the different circuit breaker still trips... your Microwave oven has a short - Most of them has a small ceramic fuse 15 amps fuse.-also check some inter lock switches at door .
2. If the Microwave oven works Ok then you may have:
2a. You may overload the existing electrical circuit, try to unplug some other appliances
2b. You may have bad electrical outlet receptacle (Replace it with the same type , - may need helps from licensed electrician)
2c. Weak or defect house hold circuit breaker. (Replace it with the same type , brand - may need helps from licensed electrician)
Jan 24, 2014 | Goldstar Microwave Ovens
I am looking for a belt placement diagram for a 42" murray riding mower-drive belt.
Use your model number & go online for Murray Riding Lawnmower & search. Most of the time you will find it. If not reply back with model numner & HP (horse power)
Aug 03, 2010 | Garden
I have a Murray panel and Bryant circuit breakers. the service is approximately 40 years old. I tried to replace the Bryant 15/15 and 20/20 with a Cutler hammer and Murray circuit breakers but they just...
It used to be you could never install more than 42 circuit breakers in a panel. If you have that many spaces you cannot install "twin" breakers in the panel. There is a rejection feature for this. Some panels will have a portion that allows twins in part of tha panel, but not all locations so you cannot exceed 42 breakers. You can sometimes tell by the legend that willshow a space divided on some positions and others not. There are many different brands that will "fit" into your panel (GE,Bryant,Murry,Arrrow Hart, Crouse Hinds, Siemens), but only use breakers listed to be used in your panel, or you will not have the protection intended. If it's 40 years old maybe it's time for an upgrade. Be careful in that panel and be aware of arc fault protection when working on engergized equipment.
Jun 24, 2010 | Bryant /murray Bj2200 Main Circuit Breaker...
The mower deck drive belt slipped off the idler pulley on my 42'' Murray riding mower deck because the idler pulley was worn out. I need to know how to loop the belt back around the pulleys after I replace...
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
Sep 30, 2009 | Garden
Need to find out how to wire starting system
1308d8d.jpg here is a typical starter/solenoid wiring diagram used on all ford lawn tractors and 99 percent of craftsman/ayp mowers hope this helps........
Jun 22, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Murray riding lawn mower
with switch off try crossing out the solenoid. take an old screwdriver and place it on the two metal contacts jetting out from the solenoid usually by the battery or close to the ignition. if strarter engages when this is donr replace solenoid. if not replace starter. hope this helps.
Sep 06, 2008 | Garden
Garden Logo
51 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
