Question about Hunter 33202 Humidifier
My humidifier won't turn on - Hunter 33202 Humidifier
Water to humidifer won't turn on.
Check if there is power to the solenoid valve, if ther is , then the solenoid is bad and must be replaced. If there is no power could be a bad humidistat or transformer.
Dec 19, 2012 | Aprilaire 600 Humidifier
Aprilaire model 50 current sensing relay won't close
If the relay is not closing then it must be replaced. It works by sensing the current through the common wire of the blower motor.
Dec 08, 2012 | Aprilaire 50 Current Sensing Relay...
Aprilaire 500 water won't stop running down to condensate pump
Hello, sounds like rhe solenoid valve is stuck open. This will keep water flowing through the humidifier even if the Furnace is off. The solenoid valve will have to be replaced.
Dec 01, 2012 | Humidifiers
Honeywell quietcare humidifier won't turn on
I am surprised that this answer isn't found anywhere, including in the manual from Kaz. If yours is the same version as mine, and your lights aren't even lighting up on top, most likely your float may have gotten bound up with gunk (the float rises up when the pan is full enough of water, which enables the motor to run. It is held into place by a plastic bracket with two phillips head screws, and looks a bit like a plastic bottle with a narrow neck in a small rectangular shape (not open at top). Remove the screws and the bracket, and take out the float and clean it and the reservoir (in the base) it sits in. Reinstall, and the float should move freely. Problem solved!
Oct 13, 2012 | Honeywell QuietCare HCM-630 Humidifier
Humidifier is full of water but the light shows it's empty. Since the humidifier thinks there isn't any water it won't run.
More than likely, the float valve in the top of the water collection bucket is broken or stuck in the DOWN position. Turn the unit OFF & unplug it. Remove the bucket for it's holder and empty any water that's in it. Inspect the float valve to see if it moves freely. Jiggle the arm of the float valve to see if it moves up and down freely. If it doesn't then it's stuck or broken. Hopefully, it's only stuck, because in most cases, purchasing a replacement bucket with the float valve installed is your only option.
Hope this helps you solve the problem. Thanks for choosing FixYa.
Sep 17, 2011 | Essick Air Humidifiers
I have a brand new hm500 humidifier and when I turn it on I can see the mist being produced in the reservoir but it won?t come out the top. How do I correct this?
If you can see the mist, then, it is working. The outlet
port of your humidifier could be closed/stucked up/clogged. Please check this the outlet port.
Jan 06, 2010 | Holmes Products HM500-UC 1 Gallon...
No water going to furnace humidifier
The furnace should be equipped with a #50 relay to turn the Humidifier on and off when only when the furnace blower is on. You should have a test mode on your humidistat. Do you have water coming up to the solenoid valve? Make sure that the saddle valve is turned on to supply the water to the humidifier. Is your humidistat set high enough to turn the humidifier on? Is it plugged in?
Good luch
HVAC Teacher
Mar 04, 2009 | AutoFlo 400BP Humidifier
Honeywell 360a humidifier
yes water should turn off solinoid is bad
Oct 24, 2008 | Honeywell HE360A1027 Whole House...
HM5081TG Reset Light won't turn off
Reset the unit once it is refilled by pushing the power button and holding it down for 5 seconds before releasing. This should reset your unit to factory settings.
Oct 21, 2007 | Holmes Products HM5080-U2 Humidifier
Hunter 33202 Humidifier Logo
91 people viewed this question
Top Hunter Humidifiers Experts
jdthefixer
ka4iup
ka4iup
Vernon Taylor
Are you a Hunter Humidifier Expert? Answer questions, earn points and help others
