Question about Kenmore Washing Machines
I have a kenmore 70 series top loader it is not draining or spinning. But when I depress the lid closed (hole) it works fine .What could this be ? LORI
  • 1,998 Answers
Its due to having a bad lid switch or a bad lid pin here is a video on how to replace the lid switch http://www.youtube.com/user/RepairClinic?v=MFsvLiuTniU&feature=pyv&ad=5454771221&kw=lid%20switch&gclid=CMn9h7G746cCFQ10gwodsQcW_Q
you can also find the part if you go to www.marcone.com under contact us there is a 1800 number sec just need some clarification on one thing when you close the lid it works fine the lid switch needs to be activated for the unit to work unless you were to jump the connection of the lid switch with a jumper wire. also check that the small pin that depresses the lid switch is intact on the machine as well if you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Posted on Mar 23, 2011
    Champion:
  • 239 Answers
The lid switch is worn internally and is not activating properly when the lid activator hits it. You will need to replace the switch. I have posted a link to a video on how to repair it.
Video
Kelly
  • Kenmore Master
  • 8,220 Answers
I have a kenmore 70 series that wont drain. It washes and agitates, but wont drain what could be the problem
It sounds like the lid switch. Open the lid and depress the switch (with a pencil or similar) until it clicks. Then see if it spins. If it does not, replace the switch. If it does spin, check the plastic "pin" on the lid to be sure it hasn't broken off. It has to depress the switch when the lid is closed. The pin should be about 5/8" long.
Dec 31, 2009 | Kenmore Washing Machines
I got kenmore 70 series. it doesnot spin but it
You have a bad lid switch . This is the piece , the lid actuator piece , goes down onto , in the hole on the top . Try putting a screwdriver into the hole , to activate the switch , to drain the water and to spin the clothes dry enough to remove , until the switch can be replaced .
Nov 26, 2009 | Kenmore Washing Machines
Kenmore 70 Series Washer
The lid switch is bad . You can either replace it , or bypass it under the control panel . Try putting a pencil down into the hole on the top where the lid actuator goes into to see if it drains and spins .
Aug 20, 2009 | Kenmore 22422 Top Load Washer
Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Aug 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series Washer will not drain and spin
You have a bad lid switch . Try inserting something into the hole on the top and see if that starts the machine in drain/spin . If not , still bad lid switch . If so , tells you still bad lid switch .
Jul 26, 2009 | Washing Machines
Why My Kenmore 70 Series Washer Won't Drain Or Spin?
You need to replace the lid switch. This is located under the case. you have to take the case off to change this part. This is done by taking the 2 screws out of the front of the control panel. Then flip the panel back and remove the 2 brass clips that hold on the case. Then you can remove the whole washer case to get acces to the lid switch. This is a very common problem and an easy problem to fix.
Feb 13, 2009 | Kenmore 24932 Top Load Washer
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Washer will wash and drain but not spin
Sounds like the lid switch is not working.It is a safety feature to prevent the washer from spinning if the lid is open.If you look a the lid,you will see a small point that sticks out,The switch is locate under the rim,right where that point would contact with lid closed.
Jan 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Series 70 Top loader won't spin
it is a problem with the lid switch. check for continuity. if the lid is close , it should have continuity, if you open the lid, it should be open also.
tnx 4 using fixya,
drcool
Oct 31, 2008 | Kenmore 23822 Top Load Washer
Most likely you need to replace the lid switch.
Open the lid and make sure the actuator that pushes the switch is still attached to the lid. Use a pen or screwdriver to depress the switch through the hole in the top of the cabinet, you should hear a click as the switch closes. I usually find that the switch has actually broken off from the cabinet and is hanging loose in the machine.
To replace the switch
Remove the screws that hold the console to the cabinet. Flip the console up and back like opening a car hood. unplug the wire connector for the lid switch. Pop out the two clips that hold the cabinet to the rear panel of the washer. The cabinet will tilt forward and slide off the machine base. You can now replace the switch from inside the cabinet.
If you need further help, please post the complete model number from the washer so I can see exactly how your washer is set up.
Mike
Apr 11, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
79 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
