Question about AudioBahn A8000T Car Audio Amplifier
My amp will come on like far as light up but the power light will not come on and nothin is comin out my subs
  • 5 Answers
Check your ground and the connection to your fuse blocks.
Posted on Mar 23, 2011
My power acoustik bamf 2200 amp keeps blowing its fuses, why?
another couple of things is a bad ground wire. a sub going bad( causing a different ohm load then before) ive run into a bad fuse link in the amp before as well
Aug 04, 2014 | Power Acoustik BAMF2000/1D Car Amp
Sub system won't play can't find in settings amo hooked up to subs yet still nothin help plz
Is the amp switching on? There are two 12v wires that have to be connected. One from a direct constant 12v supply source, and the other one from the ignition switch 12v source.Find a single 12v. supply which you can take from the lighter connection and then trace a 12v wire that runs from your ignition switch. This is mentioned in the amp manual.Double check. If the amp is coming on but no sound, then your wire connections from the amp are not correct.Or you have also connected the speaker wires incorrectly.Remmember not to connect the earth of the speaker wires to the direct earth(body of the car) but to the earth wires that are shown in the manual as this could blow the amp power IC. The earth wires of the speakers are marked -- and + respectfully and are also colour coded.You should have a RCA female plug connector from your amp to the subs. Check everything double and if still no luck their is a possibility that you could have blown an IC in the amp from wrongly connected wires. Hope this is not the case.
Apr 15, 2013 | Car Audio & Video
Hey i dont know to much about amps, but me and my friend (he knows a decent amount about amps) would plug the power into the amp and the green light would come on. Though when we plug it into the subs, the...
Are you connecting positive to positive and negative to negative from the sub to the amp? If so, try positive to positve (+) in the far left channel and then the negative to negative (-) on the far left channel to. If no luck do the same in the other channel with one sub at a time. Try one sub at a time, Dont try an connect 2 or more subs to one channel as this would cause the amp to go into protect mode (red light you describe). Usually the positive wire has either a line down the wire, writting on it or has a red seperate wire with it when wire end stripped to connect it. Hope this helps and please rate...
Mar 11, 2011 | Bazooka EL1500 Car Audio Amplifier
I got a sony xplod amp 1000 watt everything is connected good the ground wire is on a bare metal surface 12v wire good power fuse ALL wiring is as it should but there is no bass? the green light is on but...
Open your sub-woofer and check the continuity of your bass speaker. Chcek also the fuse of the sub-woofer amp...the fuse might be busted already.
Jun 05, 2010 | Car Audio & Video
00 kawasaki ninja zx6r my bike don have no power, no lights or horn, nothin is comin on whats wrong , i check battery and fuses plus starter relay everythin is ok i just dont have no signs of power, thanks
Hi and welcome to FixYa,
I understand that you have checked the:
  • battery - that it is fully charged and that the cables & terminals / connectors are clean and tight;
  • fuses - including the 30 Amp main fuse;
  • starter relay - there is +12 on the white wire.
Should the above hold true, then the only remaining components to suspect / check would be the always on +12 connectors and/or the ignition switch.
Good luck and thank you for asking FixYa.
Nov 18, 2009 | 2001 kawasaki ZX-6R Ninja
HiFonics txi4008 not working, partially lighting up
Sounds like your amp has some power supply compents shorted out. Maybe some of the power mosfets are shorted and your only getting a little bit of power. That why only the H is lighting and as far as the green light, it don't take much for it to turn on. If it was major it would go into protect mode but it is'nt. I repair amps for a living and I'm the cheapest you'll find. But if you know about electronics and think you can take a crack at it, check it out. Becareful you could do more damage. Let me know if your interested. skinnman33@gmail.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
Jun 06, 2009 | Hifonics Brutus BXi 1206D Car Audio...
Not working
maybe you should use 4 awg wire
Jun 24, 2008 | Rockford Fosgate Punch P5002 Car Audio...
High pitched noise comin out the sub
You may have a ground loop issue. Make sure your ground lead is as short as possible (<1ft, if possible) and that it is mounted to a nice, clean (unpainted) spot on the vehicle. If you have multiple amps, try and ground them to the same point.
Mar 07, 2008 | Fusion FEW12PK Car Subwoofer
Alpine MRP-M650 problem
The built in power supply is probably bad. This supplyds the voltage from the 12volts and inverts it up to 20 to 30 mvolts DC. You will need to get a manual to service this unless you know the inverter circuit really well. good Luck
Jun 30, 2007 | Alpine MRP-M650 Car Audio Amplifier
AudioBahn A8000T Car Audio Amplifier Logo
67 people viewed this question
Top AudioBahn Car Audio & Video Experts
Colin Stickland
Colin Stickland
Jerry Naidoo
Robert Rankin
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
