Question about HP HEWLETT Compaq 515 QL-64 14 250/3GB Pc - FM948UTABA FM948UTABA (FM948UT) PC Notebook
Ok so i have a compaq515.. so i have 2 problems.. one that is the major one that bother me sooooo much is that my keyboard ramdomly stops working for some reason i try and go to control panel and check what it up there but nothing... i tried restarting it and that doesnt work either! pleaseeee help me so this stops happeningg! and the other one is that for some reason when i have headphones and log into skype the audio of everthing else just goes to my computer built in speakers and the skype works with my headphones..the only way for it to work right is for me to restart the computer so that i can hear with my headphones again! pleaseee help me fix thiss!
  • HP Master
  • 2,486 Answers
Old old COMPAQ the dead company and now HP dead.(new owners for 16 years ago (2001)
no operation system stated, how can any one help you lacking that.
nor if all Microsoft updates are loaded.?
XP or W7?
this LT works with any USB Desktop keyboard made, try that yet>?
one just plugs it in ,and goes dingg-dongg and it works. (PnP magic)
if that works that means the local keyboard is bad. or connectors loose. or virus infected,or HP drivers messing or messed up for KBD.
Phone: 101
we cant guess head phones.?
there are 2 kinds,
1: real with 2 plugs, mini phone jacks, mic/speaker,
2: USB (with hidden inside sound chips)
they are not even near the same technology.!
i can tell you that skype can choose either, or use control panel.
on my PC, the windoz task bar has a speaker ICOn
i click it and can pick , my internal sound chip sound
or pick the USB Head/phone sound system, yes, usb has a 2nd sound system
making it 2 systems now.. only you can pick. 1
IF this is XP, good luck. (the worst of the worst) here.
Posted on Apr 12, 2017
5 Suggested Answers
  • 47 Answers
SOURCE: built in speakers don't work.i have sound only when i plugg the headphones
Looks like there is some problem with the stereo headphone connector. As its a hardware issue, I would recommend sending it to the service center.
You may also use external speakers temporarily.
Posted on Apr 15, 2008
  • 71 Answers
SOURCE: internal speaker problem
connection frayed
um haard 2 fix if u want i can give u a step by step how 2 fix
just contact me at femi.amoo@gmail.com
Posted on Jul 30, 2008
kyo_ajis
  • 68 Answers
SOURCE: hp dv 2915nr windows xp sp2 sound problem
Install MS UAA first((required with a reboot before Conexant)):
http://www.mediafire.com/?4ben9zlesng
Conexant SmartAudio 221:
http://www.mediafire.com/?dg0cmmkm4y4
Posted on Jan 25, 2009
  • 111 Answers
SOURCE: keyboard on hp dv7-1130us stopped working
This sounds alot like a virus i once had!
try a system restore to the point before these problems occured. if that doesnt work run a full virus scan. If that doesnt fix the problem you may have to wipe the hard drive completly.
Posted on Apr 26, 2009
My Akira Pedestal Fan stopped working suddenly
the major problem with fans is the bronze bushes that the armature runs in get dry from use and seize on the shaft. IF you are capable get to the bushes and you may find a piece of felt next to the bushes . Put some machine oil into the felt and spin the fan with your finger until it loosens up. Otherwise scrap it
Dec 08, 2013 | Cars & Trucks
Tip
OMG ! IT WORKED! THANK YOU ! i just had a major appliance break and the...
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers. The problem is usually attributed to water supply temperatures being too low when filling. Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models). There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher. This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on the number of flashing lights in the sequence. Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
on Apr 04, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Eee pc r101 keyboard not working properly. Some of the keys won't type the correct letters and type the function letter or symbol instead or just random numbers. Also the touch pad and mouse click is...
The keyboard takes a lot of abuse and as durable as it is, they will eventually wear out. It is a very inexpensive part to replace and does not require a lot of skill. The fact that the touch pad is acting up could indicate that they are interconnected. I would replace both. The Touch pad is a more involved part to replace and I would suggest you get some help or pay to have it replaced.
You can order them off of sites like eBay, then watch a YouTube video on how to do it.
I punched in:
ASUS Eee keyboard and got several results like:
http://cgi.ebay.com/ASUS-EEEPC-EEE-PC-1001H-1001HA-1005HA-Keyboard-US-Black-/220660299406?pt=PCA_Mice_Trackballs&hash=item336060f68e
ASUS Eee touch pad:
http://cgi.ebay.com/Asus-EEE-PC-1005HAB-Palmrest-Touchpad-Cable-/330585537844?pt=LH_DefaultDomain_0&hash=item4cf86efd34
These are ramdomly selected:
Jul 24, 2011 | ASUS Eee PC 1000H Laptop
Keyboard stopped working completely.
To, Fix the problem, do the following. Shutdown the Computer, Disconnect the keyboard from the computer, and unplug AC (adapter) from power outlet. Reconnect in reverse order. Turn on the computer. Turn on the keyboard. Go, to Control Panel; click on Device Manager. Click to open Keyboards, in the (Keyboard Properties) Click on Driver (Box), next click to "Update Drivers!"Click OK. Restart the computer. Check keyboards’ functionality.
Jan 17, 2010 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
My Gateway computer shuts down ramdomly. This
Listen for fans coming on, as this sounds like overheating issue. If fans kick in and then stay constant or dont work at all.
The link is for Notebook hardware control, this will monitor the temp among other things (only reference as a guide any software can give you an indication but not exact temp) Generally if a laptop hits 90c it will auto cutout to stop major hardware failure normal running temp (40-55c upwards depending on use) http://www.pbus-167.com/
If the machine is overheating it could be due to blocked vents, faulty heatsink, fans not working or incorrect fitting and thermal paste.
In all honesty if this is due to overheat problems, as the machine has been cutting out my strong advice would be to do all the above ESPECIALLY re-apply thermal paste (arctic silver5) to cpu, it takes about 100-200 hours of use to start to work 100%.
hope this helps, let me know if i can be of further help
Nov 06, 2009 | Gateway T1623BU 14.1" Notebook PC PC...
Inland 601781 wireless keyboard stopped working.
Remove the battery of the keyboard and install new one and then press connect button from the keyboard side and the receiver side also.
Oct 20, 2009 | Inland u-Touch Multimedia Keyboard/Mouse...
Mouse
Scroll works where the page supports it. Although most programs or browsers support this feature some older programs may not, eg. DOS screen in XP. No need to change your mouse.
Jul 29, 2009 | Computers & Internet
Razr v3 blanked out randomly
if the back light for my lazor stopped working ramdomly means the cell was fall in the water and that cell mother board is gone thats why the problem will came ."THE CELL MOTHER BOARD IS GONE" thats why the back light for my razor stopped working ramdomly.ok bai sir
Feb 08, 2009 | Motorola Mobility RAZR V3
Edirol UA 4FX _Short Audio Signal dropout
try runing a cleaner ccleaner and ace utituies ok that stop those hickups give a atry make pc run alsot faster
Jan 28, 2008 | Edirol UA-4FX External Sound System
HP HEWLETT Compaq 515 QL-64 14 250/3GB Pc - FM948UTABA FM948UTABA (FM948UT) PC Notebook Logo
52 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
