Question about Garden
The TI 10000 LXI purchased new 10 months ago ...hasn't been used until now. When attempting to start ...the battery was dead. The battery was removed and placed on a battery charger; however, the battery was defective and would not take a charge. So, I purchased a new battery and while attempting to install it; I encountered an arc when attaching the negative terminal to the negative cable ...(this indicated to me that there was a short somewhere in the equipment. I need information on where to look for possible trouble areas where such shorts night occur. Please advise.
  • jwnaff Mar 23, 2011
    My question and problem is not with a chain saw ...it is a 10,000 watts gas powered generator made by Tahoe Power Equipment. Do you have any suggestions for what to look for in what appears to be a short in this piece of equipment???
  • jwnaff Mar 25, 2011
    The response I received was for a chainsaw which was not even my equipment item ...actually, my question was for a TI10000 LXI Gas powered Generator (Tahoe Powerquip).
    The trouble I am having is with an electrical short in the equipment somewhere, because the battery arcs when trying to attach the negative cable. The generator is new and when used for the first time had a dead battery which would not take a charge and when a new battery replacement was installed the arc was discovered as to a problem with a short somewhere. What I am requesting is the possible areas that I need to investigate as to where the short could most likely occur. I have checked the most obvious places such as exposed wires and such.
    (I even placed a breaker between the ground and negative post on the battery so after starting I could switch off to eliminate battery drain when not in use ...but this is simply a temporary fix while waiting for an answer to the problem so it can be fixed permanently).
  • 43,501 Answers
There cannot be a whole lot of possibilities...
I would take off the positive wire...hookup the negative and then start tracing the hot or positive side with an electric meter...
If the unit is brand new I am thinking that a wire is hooked up wrong..
either on the starter soleniod or the start switch...
possibly even a defective start switch....unhook the hot wire there and see what happens...
then go from there...
heatman101
Posted on Mar 23, 2011
  • 927 Answers
Make sure that there are no bare wires anywhere from the positive terminal of the battery.
Check that the ON/OFF switch is truly open.
If there is a key switch, then that is the ON/OFF switch.
You can make a test light by taking a bulb and holder and connecting it between the positive terminal and the positive connector. If you get a light, keep looking for places that there could be shorts.
Gary
My 2010 corvette wont start.
And the antitheft is not activated ?
Nov 30, 2015 | 2010 Chevrolet Corvette
I have 2006 super glide I just picked up a teo months ago. I rode it for a few days. I was out on it last week in the heavy rain. When I went to start it yesterday it was dead. I put the battery...
The battery on most motocycles cant take much abuse.Most batteries on bikes with proper care last about three or four years.If the one you have is this age or older I would purchase a new one.Good Luck.
May 09, 2011 | 2006 Harley Davidson FXDI Dyna Super Glide
My TI-89 will not turn on or respond in any way. The last time I used the calc was 4 months ago. I tried to turn it on a few days ago but it would not work so I changed the batteries. That didn't work and...
Take out one battery. While holding the "On" button, put the battery back in. I can honestly not explain what happened, but it has happened to me multiple times as well. You might have to do this more than once, but within a few attempts, it should start working again. Tell me how it works out, and hope this helps!
Oct 10, 2010 | Texas Instruments TI-89 Calculator
Engine wont turn over at start
Hi, Do you have an alarm & Immobiliser fitted on your bike as these drain the battery on your bike very quickly? If so i would recommend removing your battery and fully charging it with a decent amp-age charger. If you have your garage attached to your house then i would definitely recommend purchasing a trickle charger and when not using your bike keep this plugged into the mains and you should not have this problem again. all motorbike shops sell these chargers If after this the battery goes flat again i would suggest purchasing a new battery. This is a common fault as most motorbikes sit in the garage through the winter months and if not kept on charge will deteriorate. Hope this helps.
Apr 09, 2010 | 2006 Yamaha V Star 1100 Custom
Phone does not hold ''charge'' when removed from the charger
hi
it seems that the battery in the phone is dead. replace it with new batteries, always go for rechargeable alkaline batteries.
hope it helps
RAhUL_hunk
Mar 10, 2009 | Uniden Cordless Phone
TI-84 Plus BIG PROBLEM!
hey i just had this problem, but just solved it!
take out one of the AAA batteries, and press+hold the delete button. while holding it, insert the AAA battery and it'll say something like waiting.. blah balh install system. u dont have to. just press second+on=off then start it again. its working fine now!
i was prepared to be murdered by my mom but i guess i'll live! good luck TI-84 users!
May 19, 2008 | Texas Instruments TI-84 Plus Calculator
Garden Logo
515 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
