I just bought a new K750 sony ericsson and the battery goes down very fast i have bought 2 new batteries and its still the same thing please what can i do.
Thanks for that i have tried that but its still the same thing i did that all before coming on line. Thanks any way.Thanks for that i have tried that but its still the same thing i did that all before coming on line. Thanks any way.
You can't post conmments that contain an email address.
Decrease its brightness form the settings to 50% the battery gives more backup....or if u hear the songs through the speaker for long time the battery goes down fast & this prob with each & every set ...
short battery life is contributed to these, 1. Old battery 2. Lots of apps running in the background 3. Taking lots of photos 4. Charging the phone when it does not need a full charge 5. Leaving your phone in direct heat or cold 6. Dropping the phone 7. Leaking battery 8. 1 year or more old battery 9. Continuously talking and charging at the same time 10. Ensure to contact your insurance to see if the battery is protected under your plan.
How old is the Phone? Phone batteries usually only last a year. Go through the phone and make sure things like the gps wifi bluetooth are turned off. also a constant data connection for auto updates of facebook or email or weather will decrease battery life.
problem can be solved.Does the get hot?, if not that means it is the battery of the phone.
The cell of the battery is too weak and is dead and can power the fun anymore and needs to be changed.
Replace the battery and make sure you charge it until it shows 100 percent before you start using it otherwise the battery cell will run down so quickly.
heats up?do you mean the unit itself heats up fast?if that so.you unit has a short circuit inside on it thats why your battery drains so fast...,but if its not,the problem is on your battery.Not even a battery can charge is meaning that your battery is still good.If a battery has defect or let me say it is already weak,it will not already stored a longer life of a power.,becoz if that so,the current or well known as the ampere is already goes down than the given specification when it is new..and thats the reason why it is already fast draining.
I honestlty think that sony ericsson and motorola do have the very same issue with the battery life in the batteries.....so you are stuck with it that way unless you can but a generic battery some have a longer lasting life.
But also remember if you are in an area where the signal is not that stronger that als pulls the battery life being that the phone keeps searching for a stronger signal.
just today figured out that the battery supposed to be at least 17 hours and i bought it before 2 years too and even when i bought it was my battery left only for 2 hours and until today i thought it is supposed to be like that.
