Question about Whirlpool 24 in. GU3200XTP Built-in Dishwasher
The dishwasher will not draw water and fill up
  • perriwinkle4 Mar 23, 2011
    We solved our own problem. Our dishwasher was trying to draw water and fill up but not enough water was coming into the dw. Our problem was a water line that was no good. We replaced the water line with a new one and the dishwasher works fine now! Look into that before you call a technician as it may be all the problem is....
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Posted on Mar 23, 2011
Draw wont fill with water
You have not provided the model number of the dishwasher.
If the inlet tap under kitchen is open fully and the problem is still there, there are two likely issues - the water pressure setting does not match mains pressure or the inlet water valve in the dishwasher is faulty.
Mar 01, 2013 | Fisher and Paykel Dishwashers
Hotpoint Super Plus 7821 dishwasher isn't drawing water, please help thank you
Hello
As water is filling your dishwasher, a float rises along with it. When the float reaches a predetermined level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Check your float assembly. Replace it if you need to.
Water Inlet Valve
Your dishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem.
Your dishwasher's drain valve is regulated by a drain solenoid. If the solenoid is malfunctioning, it may not allow the drain valve to funtion properly, which in turn could be the reason your dishwasher is not filling with water. Investigate your drain valve and test the solenoid. If the solenoid is faulty, replace it.
Aug 03, 2011 | Dishwashers
WHEN RUNNING A CYCLE ON TOP DRAW THE BOTTOM DRAW WILL FILL UP WITH WATER NOT DRAIN
The drain hose going to the kitchen sink is blocked. If you have an insinkerator in your kitchen sink then run it first. Otherwise take the dishwasher hose out from the sink outlet and run straight into sink to see if any difference.
Aug 17, 2010 | Fisher and Paykel 23 in. DD603H SS...
Whirlpool DU980QPDB3 will not draw water or start wash cycle.Time appeard to work and heat is felt during cycle
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Jul 21, 2010 | Whirlpool 24 in. GU980SCG Built-in...
13 year old daughter put liquid dishwashing soap in the rinse dispenser. Now all dishes come out covered in soap scum. How do I get liquid dishwashing soap out of the rinse dispenser?
Sorry but thats funny!!lol About the easiest way I know to tell you is take a turkey baster or marinade injector & draw as much as you can out of the reservoir,fill it with water & repeat until you get very little foam when putting water in it.Fill with rinse aid & the rest will just have to work its way through.Should be fine after a few wash cycles.
Jan 07, 2010 | Admiral 24 in. DWUA601 Built-in Dishwasher
Noritz tankless water heater/dishwasher not hot enough to clean
You are doing everything you can. Your dishwasher probably isn't drawing enough hot water to activate the unit so opening the faucet and flowing more water will activate the unit. Just try to adjust the flow from the faucet to a point it, plus the draw from the dishwasher, will activate the unit. This will come with trial and error as I am sure you have already experienced. Also, open the dishwasher when it does get filled and check the water temperature. You might have the unit set at a low discharge temperature. Do you have a touchpad to control the water temperature adjustment?
Feb 17, 2009 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
Low water level
One of 2 problems is causing this.  Either you have a bad float switch which is located on the left side of the dishwasher, or you have a water leak and is losing water when it is in the wash mode.  You will need to have it checked by a qualified LG technician.
Jul 21, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Neff dishwasher
If you don't think it's filling with enough water, it is most likely the water valve.
Mar 25, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirpool diswasher DU929PFGG2 wont draw water
The pump may be clogged or the motor start capacitor may be bad or the fill switch may be stuck or the timer may be bad. Fill the dishwasher by hand to just below the door level and close it then see if it will run. If it then runs correctly the problem may be the fill switch. If not, it could be the motor, the cap, or the timer
Nov 30, 2007 | Whirlpool 24 in. DU930PWP Built-in...
Whirlpool 24 in. GU3200XTP Built-in Dishwasher Logo
65 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
