Question about Maytag Dryers
I have a ancient maytag de90-306-406 dryer. The timer starts but it won't tumble. The screws came loose on the door hinge, when I replaced them, I developed this issue, please help
catriver
  • 878 Answers
SOURCE: Timer runs, but dryer will not start
Onry, the last 3 letters of the model number is missing. If this is an electric dryer the thermal fuse may be open. On electric dryers if the fuse is open the motor won't run. On gas, the motor will run but will not heat. There are two thermal fuses on the electric model. One on the front of the blower housing and the other on the element enclosure. Check the one on the blower housing first. You will need to remove the door by removing the 4 screws that hold the door hinge and spacers on the other side. Lift up on the door and pull out. Now the front panel will pull out and the blower cover will be visable. If this is a gas dryer we'll have to look elsewhere. Catriver..post back
Posted on Jan 05, 2007
  • 209 Answers
SOURCE: Tumble Dryer won't start
assuming what you say you checked is correct and working then the next place to look is the start relay, located behind the front timer control panel, this sis more often than not a cubed shape box made of clear plastic with about 6 spade connectors on it, look for burn marks inside it, replace if looks damaged, do not attempt to bypass or short out to test, as you will blow the timer or and control circuit board and cause extensive damage
Posted on Sep 26, 2007
  • 3 Answers
SOURCE: Whirlpool AWZ 3303 Tumble Dryer
You can usually download from Whirlpool website
Posted on Jul 10, 2008
rickzilla
  • 706 Answers
SOURCE: MAYTAG GAS DRYER TUMBLES BUT NO HEAT (FRONT LOADER 6 YRS. OLD)
Hello maryfitgera,
It certainly sounds like you are not getting a flame established in your dryer. That can be one of several components such as a non-resettable thermal fuse, gas valve assembly or control relay to that gas valve assembly. Unless you are well versed on how to work on these kinds of components, I suggest you just call in an appliance tech or.. let me know if you want to attempt diagnosing and repairing it yourself. Be advised that there are elements of danger in so doing. Let me know how you want to procede on this and I'd be happy to walk you thru it..
Regards,
Rick
Posted on Nov 24, 2008
  • 36 Answers
SOURCE: Timer runs continuously - Does not stop at all
There should be a timer motor on the timer. That is most likely burnt out and will cause the timer to not shut down. Just replace the timer and that will solve the problem
Posted on Jan 02, 2009
How do get into this dryer? Is there a secret to opening it?
1st remove outer door 17 by removing screws from 2 hinges so that you can remove front panel 24. Then remove drum support 6 (bottom pix) so that you can remove belt 18c9ql4ekhbnniaaaaaelftksuqmcc
6rdyt7bom98aaaaasuvork5cyii=
Jun 24, 2014 | Maytag Neptune MDE5500AY Electric Dryer
Electric Dryer starts and runs but won't heat.
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag Neptune MDE4000 Electric Dryer
Fin that tumbles clothing inside dryer coming loose, how can I tighten it?
These fins are usually screwed on from the outside of the drum. If you're up to it this is a simple but time consuming fix. Take the cabinet off the front of the dryer, the top will come off as well. be careful of the wires from the control console, they will stay attached to the dryer. Tighten the tumbler fins on the drum and then re-assemble the cabinet. Typically the screws you need to access are the same used for the door latch and hinges. They go back together easy ........
Feb 14, 2011 | Maytag Neptune MDE7500AY Electric Dryer
I have a Maytag dryer MDG6200AWW and at first the machine dried the clothes fine but never shut off. The second load got hot but not long enough to dry whole load. The timer does not advance at all. ...
Remove the front panel to get to the gas valve. To remove the panel remove both screws holding the door hinges and the screws on the opposite side from the hinges across the door opening.
Remove the metal bracket holding gas valve coils.
Replace both gas valve coils, part number 279834.
Good luck,
Vlad
First Choice Appliance
Aug 21, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
My tumbling bar in my dryer in coming loose - how do I fix it
Remove the 2 screws holding the dryer door hinges and remove the 2 screws on the opposite side of the hinged ( in the door opening ) . Then the front panel will pull out ( from the top ) and off . This will give enough room to use a driver to tighten the baffle screws .
May 23, 2010 | Maytag MDG7600AW Gas Dryer
Loose shelf in Maytag Neptune dryer
Hi, UNPLUG the dryer. There are two screws on each side of the door opening. Remove them screws and the front should pull toward you and release.The door can either lift off or remain on. You can reach under the drum and tighten the screws.
I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
May 31, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Gaining access to dryer
open door you see 2 screws holding hinge a a piece,,remove them now remove the 2 screws opposite them ..just let door stay for now...pull the front panel to you its just on 2 clips...now at each corner of the bottom of the top theres a upside down l shaped clip remove 5/16 inche nut driver...ok left the top...swing it up and back ,,so it will lean back,...remove 4 bulk head screw and the door switch connection..and your there..onthejob
Jan 28, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Jan 21, 2009 | Dryers
Tumbling vane screw came out - other is loose, banging as clothes tumble - how do i pry(?) open the lid (top shell) to access the drum exterior?
Hi and welcome...
You don't want to pry on anything, that top is secured by hooks and you have to do some dis-assembly to get the top open.
1. Open the door and remove the two screws that secure each of the door hinges to the dryer frame. With the door open so you can take a hold of it, simply pull the whole door out of the notches that the hinges fit into. (This is a reversable door designed for easy removal by the customer)
2. Remove the two screws on the opposite side of the frame where the door closes to. (along with the two white plastic trim pieces the screws go thru)
3. Once the door is off and the screws are out, pull the entire front panel forward and then it will lift off the tabs at the bottom and you can set it aside.
4. Look up near the top of the cabinet, on each side, for the metal hooks that secure the top to the cabinet. Remove the screw (5/16" nut driver) that secures each hook to the cabinet. Take the hook off, repeat for the other side.
Lift top.
Hope that helps.
Dec 21, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
184 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
