Question about KitchenAid 36 in. KECC567KSS Electric Cooktop
Triple burner not working...Power light comes on. no heat...all other burner are working.
GE Profile mod. PP975bM3BB all lights work Burner will not heat
You have lost half of the circuit in the breaker, the lights work on one side of it but the burners need both sides of a 220 volt circuit. I would have the breaker tested first, and if it is good, look for a fuse, relay, breaker in the back of the stove. Hope this helps.
Mar 06, 2012 | GE Profile 36" Electric Induction Cooktop...
I have voltage to each side but the burners will not heat up. Indicator lite comes on and the blower comes on
Hello Gary,
Their is one of two things wrong why your surface burners are not working.
1) the block that the burners plug into it bad...it is very common for the burner block to be worn down and making very poor contact with the burners and thus their is power at the blocks and yet the burners will not work
2) the burners their self are bad
GENE
Oct 31, 2011 | Jenn-Air JED8230 Electric Cooktop
GE Profile glass top cooktop- burners do not heat, indicator lights do work
If none of the burners are working but the pilot light does you are having a power problem and only getting 120 volts to it. Check the breakers to make sure they are on correctly. 240 volts is needed to operate the cooktop. Hope this helps. Rick
Mar 09, 2010 | GE Cooktops
One of the four burners does not work. The light comes on but no heat. Can it be repaired?
Yes, you have a bad burner, sensor, burner switch, or wiring problem. The most likely is the burner switch. You should get this repaired asap, as this could be shorting out inside, and cause an electrical shock hazard. Unlikely but enough of a possibility that you should fix it soon.
Jan 29, 2010 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8345 one burner does not come on
The switch for the burner is bad and needs to be replaced.
Jun 25, 2017 | Jenn-Air JED8345 Electric Cooktop
Neff T1722SO Ceramic Hob - rings don't heat
Check the power supply to make sure it is getting 220V, the lights etc might still work if only getting 120V but burner won't without full power supply.
Mar 08, 2009 | Neff Cooktops
Whirlpool electric Cooktop's one burner not heating
Initially, it could either be:
  • open heating element (most likely);
  • open temperature limiter (least likely);
  • faulty/loose connection/wiring (a possibility).
Please confirm that it is a Whirlpool RCC3024 Electric Cooktop.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 11, 2008 | Whirlpool RCC3024 Electric Cooktop
Frigidaire Ceramic Cooktop PLEC36S9eca - Turns on but burners won't heat up
Check the power plug is their any separate plug on it / if none check the control panel some switch to power on .
Jan 02, 2008 | Frigidaire PLEC30S9EC Stainless Steel...
KitchenAid 36 in. KECC567KSS Electric Cooktop Logo
42 people viewed this question
Top KitchenAid Cooktops Experts
Dale Copeland
Dale Copeland
davenpdx
freddyfox
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
